RIP Front Propeller Shaft :(
Posted: Sat Mar 18, 2017 12:02 pm
by pdavey
So over 202,000 miles and my front propeller shaft started failing (squeaking and grinding). Probably due to the salt this winter and not enough lubrication.
Instead of rebuilding I am just going to have the whole thing replaced at this point given all the wear.
Just going with the NAPA part. Supposedly it is easier to grease then the stock one.
Re: RIP Front Propeller Shaft :(
Posted: Sat Mar 18, 2017 2:29 pm
by RustyPW
Over 200,000 miles......yeah I think stuff is going to start to fall apart.
Posted: Sat Mar 18, 2017 3:03 pm
by pdavey
We will build it better and stronger
Posted: Sat Mar 18, 2017 5:11 pm
by pdavey
All back in one piece with no squeak. The new prop shaft has greasable fittings all over. Much like the original should have had.
Posted: Sat Mar 18, 2017 6:49 pm
by TwinStick
Posted: Sat Mar 18, 2017 11:15 pm
by FirerescuePW
Well damn, Peter...
It's nice having you out front doing recon for me. I just hope I remember what went wrong for you when I finally put some miles on mine!
Posted: Sun Mar 19, 2017 1:45 pm
by pdavey
Thanks TwinStick. Here are a few pics of the new one.
Look visible zerks!
Posted: Sun Mar 19, 2017 7:52 pm
by flattire
I see them!!
Might be worth getting this even if old one is still good. With all the time wasted trying to find the "hidden" fitting.
Posted: Mon Mar 20, 2017 1:11 pm
by TwinStick
For the current NAPA price in my above post, the NAPA prop shaft price is the same or cheaper than having my current rusty one rebuilt by a driveshaft shop, at least by me. (Meaning---3 new u-joints & a new double cardan joint).
https://www.mapquest.com/us/new-york/bu ... de-1809760
Posted: Mon Mar 20, 2017 10:58 pm
by FirerescuePW
I see zerks on the u-joints... is there one on the double cardan joint?
Posted: Tue Mar 21, 2017 9:31 pm
by pdavey
I will check when I am home this weekend. I didn't see it immediately but also haven't inspected it that closely yet.
Posted: Sun Mar 26, 2017 7:47 pm
by 2wagons1driveway
pdavey wrote:So over 202,000 miles and my front propeller shaft started failing (squeaking and grinding). Probably due to the salt this winter and not enough lubrication.
I've been through three prop shafts already man your doing great! Haha my trucks got alittle over 70,000 miles on it too :/
Posted: Sun Mar 26, 2017 8:48 pm
by Reloaderguy
2wagons1driveway wrote:pdavey wrote:So over 202,000 miles and my front propeller shaft started failing (squeaking and grinding). Probably due to the salt this winter and not enough lubrication.
How many wheels have you been through?
Posted: Sun Mar 26, 2017 11:27 pm
by 2wagons1driveway
Reloaderguy wrote:2wagons1driveway wrote:pdavey wrote:So over 202,000 miles and my front propeller shaft started failing (squeaking and grinding). Probably due to the salt this winter and not enough lubrication.
five now. Lol
