RIP Front Propeller Shaft :(
pdavey
Post by pdavey » Sat Mar 18, 2017 10:02 am
So over 202,000 miles and my front propeller shaft started failing (squeaking and grinding). Probably due to the salt this winter and not enough lubrication.
Instead of rebuilding I am just going to have the whole thing replaced at this point given all the wear.
Just going with the NAPA part. Supposedly it is easier to grease then the stock one.
Performance Mods:
  • Green Cold Air Intake, Gibson Dual Cat Exhast (Side Swept), DiabloSport Predator U7137 Tuner
Other Mods:
Suspension/Protection Mods:
Style/Other Mods:
Re: RIP Front Propeller Shaft :(
Post by RustyPW » Sat Mar 18, 2017 12:29 pm
Over 200,000 miles......yeah I think stuff is going to start to fall apart.
Russ NRA Benefactor Member
pdavey
Post by pdavey » Sat Mar 18, 2017 1:03 pm
We will build it better and stronger
Performance Mods:
Other Mods:
Style/Other Mods:
pdavey
Post by pdavey » Sat Mar 18, 2017 3:11 pm
All back in one piece with no squeak. The new prop shaft has greasable fittings all over. Much like the original should have had.
Performance Mods:
Other Mods:
Style/Other Mods:
Post by TwinStick » Sat Mar 18, 2017 4:49 pm
Post by FirerescuePW » Sat Mar 18, 2017 9:15 pm
Well damn, Peter...
It's nice having you out front doing recon for me. I just hope I remember what went wrong for you when I finally put some miles on mine!
pdavey
Post by pdavey » Sun Mar 19, 2017 11:45 am
Thanks TwinStick. Here are a few pics of the new one.
Look visible zerks!
Performance Mods:
Other Mods:
Style/Other Mods:
flattire
Post by flattire » Sun Mar 19, 2017 5:52 pm
I see them!!
Might be worth getting this even if old one is still good. With all the time wasted trying to find the "hidden" fitting.
Post by TwinStick » Mon Mar 20, 2017 11:11 am
For the current NAPA price in my above post, the NAPA prop shaft price is the same or cheaper than having my current rusty one rebuilt by a driveshaft shop, at least by me. (Meaning---3 new u-joints & a new double cardan joint).
https://www.mapquest.com/us/new-york/bu ... de-1809760
Post by FirerescuePW » Mon Mar 20, 2017 8:58 pm
I see zerks on the u-joints... is there one on the double cardan joint?
pdavey
Post by pdavey » Tue Mar 21, 2017 7:31 pm
I will check when I am home this weekend. I didn't see it immediately but also haven't inspected it that closely yet.
Performance Mods:
Other Mods:
Style/Other Mods:
Post by 2wagons1driveway » Sun Mar 26, 2017 5:47 pm
pdavey wrote:So over 202,000 miles and my front propeller shaft started failing (squeaking and grinding). Probably due to the salt this winter and not enough lubrication.
I've been through three prop shafts already man your doing great! Haha my trucks got alittle over 70,000 miles on it too :/
Post by Reloaderguy » Sun Mar 26, 2017 6:48 pm
How many wheels have you been through?
Post by 2wagons1driveway » Sun Mar 26, 2017 9:27 pm
five now. Lol ImageImageImage
