Thanks for the info, I am leaning this way ... have to get something soon.ramv wrote:I have 20 lb power tank. Works awesome if you need to pop a bead on, run an impact wrench or air up quick. Great tool. CO2 is amazing in this application.
Big, heavy, can run out are the downsides.
Portable Air Compressor
Re: Portable Air Compressor
I recently got the portable ARB twin pump setup
2012,2600 stall CircleD converter,MYoung locker bypass,Dynatrac bjs,Dynatrac no-spin kit w/Dynaloc hubs,Thuren 3" coils,trackbar,shackles and Kings(3"F-2.5"R) shocks,Thuren Alien arms,Synergy steering,Thuren/King steering stabilizer,Carli diff guard,White Knuckle sliders,Thuren bumper,37" Cooper STT Pros,Corsa exhaust
You get the "kit" or just the twin compressor & hard mounted it ?
I got the Powertank regulator and accessories and then got an aluminum CO2 tank at my local Airgas on lease. Cheaper and easy to swap out. Not as pretty as the Powertank powder coated one, but easier to deal with if you have a local air gas.rkgzx9leftcoast wrote:Thanks for the info, I am leaning this way ... have to get something soon.ramv wrote:I have 20 lb power tank. Works awesome if you need to pop a bead on, run an impact wrench or air up quick. Great tool. CO2 is amazing in this application.
I have actually considered going to 5 lb cylinders and just get a couple from my local liquor store. Easier yet!
- Stickman
I got the twin ARB in the hard case a couple months ago, but haven't really had the time or gotten the chance to use it yet. It is a very nice piece though, very well made and put together. Only thing it needs is a tire pressure gauge thrown in with it.
Stick man why don't you let me give that thing a trial run? I'll do a nice writeup and let you know the ins and outs of it
I got the kit in the portable caseTwinStick wrote:You get the "kit" or just the twin compressor & hard mounted it ?
Thanks man, I may do the same thing, makes sense!!ramv wrote:I got the Powertank regulator and accessories and then got an aluminum CO2 tank at my local Airgas on lease. Cheaper and easy to swap out. Not as pretty as the Powertank powder coated one, but easier to deal with if you have a local air gas.rkgzx9leftcoast wrote:Thanks for the info, I am leaning this way ... have to get something soon.ramv wrote:I have 20 lb power tank. Works awesome if you need to pop a bead on, run an impact wrench or air up quick. Great tool. CO2 is amazing in this application.
- Stickman
Lol, I would almost let you if I didn't have such random things pop up every now and then. I'll buy something after I need it, then never need it again for 3-6 months it seems like.DamageWagon wrote:Stick man why don't you let me give that thing a trial run? I'll do a nice writeup and let you know the ins and outs of it
I've been looking at air systems for my 3g non-PW ram 2500 Hemi truck as well. I have all the parts, and most of the fabrication done to put a big displacement York piggy-backed off the alternator like Jeepspeed does it. However, every time I hold it up for positioning of the compressor, I just can't find a place between the airbox and the alternator that I'm happy with. I had a K&N Cold air intake on it at one point, to give me more mounting room, but the intake noise was defeaning so I took it back off there. I had actually given up and was looking at a PUMA PD1006 compressor from Buzzard offroad. The specs on it look good, and there are lots of favorable reviews in the offroad forums about it.
On another note, I modified a Chrysler RV-2 for my 48' with the LA318, that will flat out stomp a big displacement York ( I can run two 3/8" lines off it airing up two tires at once, and maintain 90psi system pressure, just off idle). If I could figure out a way of putting one of those on there, I would. They're bigger an bulkier than a York though.
Dylan
Dylan
I'm trying to figure out a mounting solution for my York as well. I've even looked underneath the engine... There's not really anywhere good. But you should be able to throw the Jeepsoeed kit in and call it done. It should bolt right in. I don't think you get an option of where it goes.
I can't find the pictures of it now, but I believe it was mounted on a Hemi engine that had been transplanted into a Jeep of some kind, with a non-stock air box setup. Think it was a link on Dodgetalk. Either way I remember for sure the compressor was to the left of the alternator laying on its side. In my truck with the compressor in that position I don't have much room for the fittings coming out of the compressor head, not to mention any kind of belt adjustment leeway. I haven't looked at it in awhile, but I vaguely remember thinking if I set the compressor slightly higher over the alternator, and left myself enough room for the fittings and belt adjustment It would barely have enough room to clear the hood when it closes. I remember thinking that the mount was uncomfortably close to the "hot" stud on top of the alternator too.
Dylan
Dylan
Here's the pictures I saved from Jeep Speed Shop about a year ago.
York compressor mount on a 5.7 Hemi conversion in a Jeep: I ended up buying a Smittybilt compressor and mounting it behind my grill, courtesy of Ducky's Dad for the inspiration. (Thanks D.D.
I just couldn't justify the expense for a York system, for something I would only use a couple times a year.
I still need to do a tank and plumbing, but I'm in no hurry.
2008 Quad Cab - Stock RTI = 655, curb weight = 6081 lbs. Abel Components Plug & Play Locker Bypass®, Abel Components Sway Bar Bypass®, Abel Components Nanny Kill Switch®, Trailer Hitch Storage, MOLLE Door Panels, Wilton Hitch Vice, Locking Under Seat Storage Drawer, Smittybilt 2781 Air Compressor, 14K PullPal, Hi-Lift First Responder Jack, 25' Jumper Cable System, Slip Yoke Eliminator in a Can, Evolution vs. God, Share the Umbrella, Make sure you're right with God before you meet him!
Boy....that's a tight fit.
My build thread. viewtopic.php?f=13&t=2826
Ya, with the stock airbox I wasn't real happy with the amount of room I had around the compressor, and I wasn't real happy with the CAI when it was on the truck. The main reason I was going the York route to begin with, was because I already had all the parts, fittings, etc. It kind of got put on the back burner for a bit though. It would be handy to be able to run a half inch impact, as well as airing up the tires, etc.
Dylan
Dylan
I used to maintain a fleet of tow trucks and they all had York OBA with 9 gal. tanks and they got used everyday and were awesome. The problem with a York system is that it's not truly portable. If I remove 3 bolts and disconnect a wire connecter, my Smittybilt is portable again and self contained in a canvas bag. When I buy my new 7th gen. retro flat fender PW, I'll already have an air compressor for it. I think It also has the same or better CFM numbers than a Viair, if I remember correctly.
Numbers on the 2781 model are pretty good. 5.65CFM @ 0psi, 40min, duty @75deg. Portability would be nice too. Now ya got me looking again.
Anybody running the Masterflow MF-1089??
Dylan
Dylan
BLM you don't need your compressor, Mopar already announced that the retro flat fender Wagons are getting onboard air. They even come with tire chains now too.
I run Puma 3/4 HP continuous duty. Very capable. http://www.aircompressorsdirect.com/Pum ... 13972.html
Ya, I got a Puma in my watch list on ebay $234 free shipping. Lots of good reviews on the web. Haven't given up on the York setup yet, but its been in the same half finished state for close to a year now.
Dylan
Dylan
DamageWagon wrote:BLM you don't need your compressor, Mopar already announced that the retro flat fender Wagons are getting onboard air. They even come with tire chains now too.
That's the one I have. I think I paid $140. Very happy so far.Dylan Robinson wrote:Numbers on the 2781 model are pretty good. 5.65CFM @ 0psi, 40min, duty @75deg. Portability would be nice too. Now ya got me looking again.
Dylan
That's the one that Coder said he has on page #1 of this thread. He said it's served him well.Dylan Robinson wrote:Anybody running the Masterflow MF-1089??
Dylan
Nice!Retired BLM Rig wrote:
So do you have a jumper cable connection wired up to a 50 amp quick disconnect so you can use it as portable setup, or is more or less permanent mounted?
I've read good things about the various MasterFlow compressors out there, like the MF-50, and the 1089, which is a jumbo version of the MF-50. They put out a new kit recently w/in the last year called the M240, it's a compressor & accessories built into a .50Cal ammo can:
https://www.amazon.com/gp/aw/d/B00VROSS ... PDKIKX0DER
It's a 2.18cfm, but 50% duty cycle compared to 40% like most others. The Smittybuilt has the highest volume rating at 5.65cfm.
Smittybuilt 2781: 5.65cfm, 40% D.C, 1/3HP, 30A fuse, $156
MF-1078: dual piston, 3.18cfm, 40%D.C., 45Afuse, $149
M240: 2.11cfm, 27pc kit, ammo can, 50%D.C., $199
Viair 400P: 2.3cfm, 33%D.C., 40A fuse, $215
Viair 450P: 1.8cfm, 100%D.C., 40A fuse, $256
ARB CKMP: 2.6cfm, ?%D.C., ?A fuse, $325
