FilterMag questions/ found loose part in rear diff. 3400 mi.
Re: FilterMag questions
OP here.
So I changed my fine synthetic snobby wine . What came out at 3400 miles was dark dark brown. In a clear cup you cant see though it.
Did the diffs too. Front was like new since Ive hardly been in 4wd. Installed filtermag, wiped magnet by sensor with qtip only got color. Rear fluid was dark grey and inside of cover got wiped clean. Filtermag installed. magnet by sensor covered in metal, took 4-5 qtips to clean debris. Attached to the inside magnetic end of the fill plug was this piece of bent metal:
Now I wish I would have taken a picture of the inside of the diff, but I didn't. It got windy as hell as soon as I had the diff cover off and all kinds of crap was flying on the wind.
When we found this piece of metal, we of course looked into diff to see if we could find a break in a part or something. We could see what looks like this same piece of metal about 5/16" wide and 3/4" long, but not bent and still in place. It looks like this piece (When not broken off and bent) is flat and installed to the left of the ring gear as like a flat finger that orients the assembly left of the ring gear. Clearly the piece I have broke off a different area than what we could see.
Looks like a trip to the dealer. I am glad to find it before it's a bigger issue or something gives way.
Anyone have a clue what it is ?
That almost looks like a spot weld in the middle of it. I have no idea what it is.
Dealer time.
Dealer time.
Agreed on both. That piece of metal does not appear to have any ragged broken edge, but it does have a circle pattern on it with a little pit in the center of the circle.Retired BLM Rig wrote:That almost looks like a spot weld in the middle of it. I have no idea what it is.
Dealer time.
Sure glad I found it now. Hope the dealer can get me in soon. I can't think it's smart to drive it with a piece/part missing
Well, wagon goes into dealer next Monday.
While not real definitive, dealer said that part is from the locker. They also said they have seen it come off before.
- chromedragon
Re: FilterMag questions/ found loose part in rear diff. 3400
Hope they take good care of your PW. I am getting a bit concerned about the build quality on the newer rigs. especially the axles I keep seeing seals going way early in life. It could be infant mortality and with in the curve but the traffic of bad low millage parts on the FB group is a bit scary to watch.
Special Licenses:
FAA Airframe and Power Plant
FCC Technician (Ham) KK6YCI
Robert A. Heinlein
Special Licenses:
Robert A. Heinlein
Wow. A dealer that not only knows that a PW has a locker, but one that has actually had the rear end torn apart on one and seen this issue before? Thats flippin amazingJD 500 wrote:Well, wagon goes into dealer next Monday.
Hope they figure it out and treat you right. Sounds to me like you are off to a good start!
Man, I hope you're right, but he actually said it was from the POSI !!olyelr wrote:Wow. A dealer that not only knows that a PW has a locker, but one that has actually had the rear end torn apart on one and seen this issue before? Thats flippin amazingJD 500 wrote:Well, wagon goes into dealer next Monday.
I translated it to locker !!
Rear axle has a limited slip (some people call it a posi) in addition to the locker, so he might be right.JD 500 wrote:Man, I hope you're right, but he actually said it was from the POSI !!
Looks like the fill plug magnet did it's job to catch metal shavings and large chunks of random scrap metal inside the axle housing!JD 500 wrote:
I thought it looks like the piece that holds the locker wires in place inside the pumpkin. Curious to find out what it actually is.
For those who have installed the transmission FilterMag (TM360), where did you install it? I pretty much put it right in the middle since that was really the only place it was completely flush on the pan with all the curves and crevices on the pan. Any troubles with shifting after installing? This is on my 2016 PW.
2016 Laramie Power Wagon
Does your auto trans have a drain plug ? Just curious.
I would assume it does but I didn't locate it while I was under there.TwinStick wrote:Does your auto trans have a drain plug ? Just curious.
My 2004 Dodge Ram 2500 w/auto trans did not have a drain plug. I bought a new oil pan from dealer for $35, drilled a hole in the front pass side of it, took it to a welding shop & had them weld a nut on the outside of the hole (dealer said if it was inside the pan, it would void the warranty---but my dealer is the worst) I removed the old oil pan in my driveway & installed the new one with the drain & put a bolt in it. I did get a few drips on the driveway but some teflon tape on the bolt & brass washer stopped the drips. Every year I would drain & refill with fresh ATF+4 (only 3.5 qts came out). No trans issues on that truck. It towed a 10,500 lb camper on & off. Traded it in on my PW. 04' had 36,000 miles when i traded.
I'll have to take a look. I thought all transmissions had a drain plug. I've never actually changed my own tranny oil.
They did used to have trans oil drain plugs back in the day.
Including my 2011, 2001 and 1992, no drain plugs. Just the old fashioned ATF-shower method.
Sent from my safe space
Thats where I put mine. No shifting issues at all so far.Hammerballs wrote:For those who have installed the transmission FilterMag (TM360), where did you install it? I pretty much put it right in the middle since that was really the only place it was completely flush on the pan with all the curves and crevices on the pan. Any troubles with shifting after installing? This is on my 2016 PW.
No trans drain plug on my 16
I paid $26 for the Dorman pan that comes with a drain plug. https://www.amazon.com/gp/product/B00GH ... UTF8&psc=1
Same gauge metal as O.E., seems like good quality. I'm happy!
I put one on a few months ago. Used gasket maker that came with it (I think). Drain leaked. Also leaked around seal area . Finally had to take it off and reuse stock pan. No leaks.
Damage Wagon & Hammerballs,Retired BLM Rig wrote:I paid $26 for the Dorman pan that comes with a drain plug. https://www.amazon.com/gp/product/B00GH ... UTF8&psc=1
Well, there's the answer to your problem right there ! And, only $26 !!!
Ding ding ding - We have a winner !TwinStick wrote:I thought it looks like the piece that holds the locker wires in place inside the pumpkin. Curious to find out what it actually is.
Good guess TwinStick ! That's what they say it is, and they said I really shouldn't notice it missing. Said they wouldn't expect it to cause any issues at all and that all it is /does is provide a guide for the wiring. Hell I've got 30k+ miles of warranty left, I'm gonna skip doing anything about it now besides the tech would have had to drain that brand new fresh unicorn blood (I mean Amsoil) from the diff.
"Could not replicate issue. Part not necessary for operation."
Felt like that when I was talking to the service writer.DamageWagon wrote:"Could not replicate issue. Part not necessary for operation."
Then I talked to the tech, and better yet he came out to the truck and showed me how they get the lockers to work.
So tech says those clips don't have any function because they are there to keep the wires out of the way during assembly of the rear end.
So then he climbs into the drivers seat and says the following:
4Lo
swaybar disco button
then he turns locker dial all the way to both front and rear locked without stopping at rear only.
cranks the steering wheel back and forth, drives forward 5 feet and bam, both lockers locked, took 5 seconds.
He said the instructions in manual are crap.
JD 500 wrote:Ding ding ding - We have a winner !TwinStick wrote:I thought it looks like the piece that holds the locker wires in place inside the pumpkin. Curious to find out what it actually is.
Not for nothing, but I would want it there & in place, the way it's supposed to be. Could save you grief down the road, chasing a short or wondering why your locker wont lock, or worse yet, frying the locker after warranty is up ! $$$$$
Just sayin.'
