LOCKER BYPASS KIT 2015
ANDY
Post by ANDY » Mon Jan 16, 2017 5:42 pm
Hello all,
Please don't yell at me But were do I find a bypass kit for a 2015?
Thank you, Andy
stamm20
Re: LOCKER BYPASS KIT 2015
Post by stamm20 » Mon Jan 16, 2017 9:13 pm
In the vendor area myyoung makes em and sells them his stuff is quality.
Post by olyelr » Mon Jan 16, 2017 9:43 pm
ANDY wrote:Hello all,
Thank you, Andy
Andy, HOW ABOUT YOU FIND THE SEARCH BUTTON AND FIGURE IT OUT ON YOUR OWN!
:lol:
Welcome to the PWR. :winchmob: There are a few smartasses around these parts, but most are very nice and helpful.
Like stamm stated, there is a list to get on... but good luck with that. I emailed him long ago, what seems like a half year ago, and still havnt heard boo. I guess hes a real busy man.
gtomike60
Post by gtomike60 » Tue Jan 17, 2017 5:11 am
He stopped making them a couple of years ago shortly after he traded his Power Wagon.
CajunPW took over production,but don't know if he's still making them
2012
LumberZach
Post by LumberZach » Tue Jan 17, 2017 1:29 pm
Let me know what you find. I'd be interested in the bypass kit for a 2015 since this thread is going.
Post by adeluca73 » Tue Jan 17, 2017 4:37 pm
-Morgan (myyoung) designed and start fabbing the by-pass, then one day he sort of fell off the grid. After putting considerable $ in mods/upgrades, he sold his PW, bought a 1500 Outdoorsman, and poof was gone.
- Cajun and maybe Pit Slave started making them on sporadic intervals, but nothing sustainable. I think Cajun got all the plans and schematics from Morgan to make his version, not sure where it stands as of now. Starting to look like the by-pass is becoming hen's teeth....should probably hold on to mine... :mrgreen:
NickPic83
Post by NickPic83 » Tue Jan 17, 2017 6:00 pm
How much were they selling for?
LumberZach
Post by LumberZach » Tue Jan 17, 2017 8:41 pm
Is it just a computer controller you plug into the truck, or is there more to it than that?
Post by Low_Sky » Tue Jan 17, 2017 11:18 pm
Guys, use the search function and do some reading. The information is all there. Nobody is making them currently anyway, so it's not like you need to inform your decision on whether or not to get one.
Rodeoflyer
Post by Rodeoflyer » Wed Jan 18, 2017 7:33 pm
Here's the cliff notes: crawl under your truck and clip the wires to your transfer case then wire in a resistor or potentiometer (because the exact ohm resistor that's required is still up in the air). Easy peasy and won't affect your warranty in any way :-). j/k, proceed at your own risk. I would like to do the mod, however my lockers lock right up with the combination of 4lo and throwing the tranny into neutral then drive. It WOULD be nice to have the ability to fully lock up in 4hi or rear in 2wd but I'm assessing the risk/reward at this point.
NickPic83
Post by NickPic83 » Wed Jan 18, 2017 9:09 pm
Rear locker in 2Hi would be nice. I use it now and used it alot on my raptor.
Post by Retired BLM Rig » Wed Jan 18, 2017 10:37 pm
NickPic83 wrote:Rear locker in 2Hi would be nice. I use it now and used it alot on my raptor.
Does the Raptor have any limitations on their locker system like the PW does (speed limit, 4 low, throttle mapping)?
Was it quick to lock up?
Just wondering.
NickPic83
Post by NickPic83 » Thu Jan 19, 2017 4:43 am
Just wondering.
Only safety was that it unlocked over 30 mph.
The raptor and my superduty rear locker locks up almost instantly and it doesn't require any dancing. Sometimes I just have to creep forward slightly.
NickPic83
Just wondering.
ANDY
Post by ANDY » Thu Jan 19, 2017 11:01 am
Why Cant we just find the 4low wire on the t-case and run a small switch on the dash so it thinks it is in 4low? Or is that way to easy.
PS. I have done a lot of looking around and there is no definite answers.
Vee
Post by Vee » Thu Jan 19, 2017 11:10 am
ANDY wrote:Why Cant we just find the 4low wire on the t-case and run a small switch on the dash so it thinks it is in 4low? Or is that way to easy.
It works on the 3rd gens. I would think if you found the right resistor ohms it would work. I have one on my 07 and it works great.
ANDY
Post by ANDY » Thu Jan 19, 2017 12:55 pm
Why do we need to have a resistor in the line to a switch?
Vee
Post by Vee » Thu Jan 19, 2017 1:09 pm
ANDY wrote:Why do we need to have a resistor in the line to a switch?
The computer knows what position it is in from the ohms coming from the sensor. http://powerwagonregistry.org/locker_bypass.php
Post by olyelr » Thu Jan 19, 2017 1:24 pm
The other thing that was kind of nice about the myoung kit is that is was plug and play and utilized the factory knob on the dash.
But I am all for an added switch for it to function too!
Vee
Post by Vee » Thu Jan 19, 2017 1:53 pm
If there is no option for a plug and play kit, this option if it works on newer trucks is less than 20 bucks. Took me about an hour. It still limits the speed on the swaybar disco, but I have lockers in 2hi and 4hi.
Vee
Post by Vee » Thu Jan 19, 2017 2:00 pm
I would wager that there is a good chance that the ohms are the same as the earlier trucks. Same T case, and probably the same sensor. Someone with a new truck needs to be brave...[FEARFUL FACE]
Vee
Post by Vee » Thu Jan 19, 2017 2:28 pm
Vee wrote:I would wager that there is a good chance that the ohms are the same as the earlier trucks. Same T case, and probably the same sensor. Someone with a new truck needs to be brave...[FEARFUL FACE]
Never mind, I forgot they changed transfer cases. Somebody still needs to try it.
Post by Retired BLM Rig » Fri Jan 20, 2017 12:54 am
Someone did try it. ACBoomer16 did it at the end of this thread. http://forum.powerwagonregistry.org/vie ... f=2&t=3953
He said he adjusted his variable potentiometer to 49.2 ohms. Radio Shack has a 47 ohm 5% tolerance resistor that may do the trick, or just do what ACBoomer16 did with a potentiometer.
Yes you too can have your own homemade plug and play locker bypass on your new truck for $20 and you don't have to cut the factory harness. :patriot:
