Hi lift jack ideas
Re: Hi lift jack ideas
Post by olyelr » Sat Mar 17, 2018 12:26 am
Nice thanks for the pics!
Easttnrhino
Post by Easttnrhino » Sat Mar 17, 2018 8:50 pm
I like, good idea. Thanks
Enjoying beautiful east TN
Post by adeluca73 » Sun Mar 18, 2018 11:52 pm
Low_Sky wrote:
Fri Mar 16, 2018 9:32 pm
I know this thread is old, but here's how I just mounted mine in a RamBox truck. Took the jack apart to its major pieces: jack bar, foot (replaced the bolt with a 1/4" pin), handle (replaced the cotter pin with a single leg snap button), and running gear. I built plywood dividers and a jig to hold the jack bar and handle. The handle's held on with Quick Fist clamps, and the jack bar is on 1/2" bolts with wing nuts.
That’s a slick way to shoehorn that monster in there!!!
Post by Reloaderguy » Mon Mar 19, 2018 12:14 am
My wife said the same thing this morning.
Post by adeluca73 » Mon Mar 19, 2018 8:17 am
Figured it was you would chime in....I couldn't have teed it up any better aside from subtitling "that's what she said" after. Nice to see we conform to expectations....
HOBBES
Post by HOBBES » Mon Sep 21, 2020 5:14 pm
2015 Jeep Wrangler JKU Rubicon Hard Rock
2006 Dodge Ram Power Wagon
2004 Yamaha FJR1300A
JRHPWRWAGON06
Post by JRHPWRWAGON06 » Sat Sep 26, 2020 7:11 pm
Those things weigh a ton. I would keep it in the garage unless i was Wheeling. Save on gas.
OPTIONS-
MODS-
Lifetime Sirius SAT Radio, 285/70-17E Firestone MT's on Power Wagon wheels, Mopar EVS Alarm,
Line-X bedliner, Mopar Rock Rails w/CARR steps, Gibson Dual Exhaust,
Locker Bypass, Winch TPS Bypass, EZ-Down tailgate damper,
Tailgate lock, Mopar wheel locks, Mopar spare tire winch lock,
Air-Ram Jet stream scoop, Deflecta-Shield 60" Low Profile Toolbox,
Mopar: Winch Accy Kit, Wheel well liners, Mudflaps, Engine block heater.
2 NATO 20L Jerrycans custom removable mount in-bed.
Post by Bill2014 » Mon Sep 28, 2020 2:55 pm
You will only need it if it is in your garage :poke:
Post by KevinABQ » Mon Sep 28, 2020 11:01 pm
Nobody ever forgets their recovery gear on a shelf in their garage. Particularly if it stays in the truck.
Mule
Post by Mule » Mon Sep 28, 2020 11:37 pm
A good checklist and pre-trip inspection goes a long ways!
(Going through a checklist for the moto for a ride tomorrow... helmet, gloves, boots, radio(s), camelbak, FAK... batteries charged? Oil change good? Bike fuel'd? Coolant check'd?
I forget a lot of things, but I don't "forget things" with a checklist+pretrip! 8-) )
btsbarton
Model Year: 2019
Post by btsbarton » Sun Oct 11, 2020 9:16 pm
You’re aware how much these things already weigh right? lol what is an extra 50 pounds
Oilbrnr
Post by Oilbrnr » Wed Oct 14, 2020 11:33 am
What are you using as lift-points on the PW and what do you expect to achieve with that Hi_lift?
:popcorn:
'16 with '17 FWC
EasyDoesIt
Post by EasyDoesIt » Wed Oct 14, 2020 12:49 pm
:popcorn:
In a pinch you can use the front tow hooks. I've done it, I wouldn't get under the truck but to change a tire or get the tire out of a hole, id do it again.
Also the rear hitch would work.
Or get one of those wheel straps.
Post by Retired BLM Rig » Sat Oct 17, 2020 9:46 am
I carry a Hi Lift for the same reason I carry a fire extinguisher and a first aid kit. The Boy Scout motto is "Be Prepared".
phpBB [video]
Clickable link for Tapatalk
HOBBES
Post by HOBBES » Tue Oct 20, 2020 7:38 pm
:popcorn:
I wish I had a set of MOPAR factory rock rails installed to lift from. Instead, I have the lift-mate wheel strap, bumper lift, off road base, winch kit, etc. I like the idea of it being capable of being used as a spreader. The Jackmate allows me to pry open a car door like a can opener, if necessary.
btsbarton
Model Year: 2019
Post by btsbarton » Sat Oct 24, 2020 1:29 pm
:popcorn:
If you have rock sliders, they are good lift points for a HiLift.
If you get the “Lift Mate” wheel lift kit, it’s great for lifting one corner to place a traction board or rocks to fill a hole you’re stuck in, even without rock Sliders. Same concept if you need to break suction of a stuck vehicle framed out in mud/ice.
You can use the instability of the jack to its advantage to “cast off”...jacking it up and pushing or driving off the jack to reposition a vehicle. This isn’t for beginners/faint of heard though, as it can be dangerous if done wrong.
Hilift can also be used to press bearings, break tire beads, and It can be used as a winch in a pinch (slow, not much travel before having to reset)
I think the bigest misconception is HiLifts are for changing tires on lifted vehicles.... they are not! They CAN be as a last resort, but the MUCH SAFER route is to use the (stock) bottle jack under the axle and a 4x4 block of wood to gain the extra height if needed.
