What's wrong with my Hemi?
Re: What's wrong with my Hemi?
Post by RustyPW » Mon Jan 22, 2018 8:42 am
The rear upper exhaust manifold stud is a problem child for most any 5.7's. :angry:
Mods to the PW; Nerffed Mopar RockRails, Wheel Well Liners, Bushwacker Pocket Fender Flairs, Garvmin dezl 560LMT GPS, Power Wagon Winch Kit, Line X Ultra Bed Liner, PIAA Headlight Bulbs, PIAA 580 Driving Lights (135 watt), PIAA 520 Fog Lights (135 watt), PIAA 520 ATP Off-Road Lights (135 watt), Locker Bypass, Modifed Rockcrusher Diff Covers, Mopar Utility Bed Rails and Tool Box, Warn Winch Wireless Remote Control, "el-cheapo" Inclinometer, Airaid CAI, Winch TPS Bypass, 35" Toyo's, Mopar Spare Tire Lock, 'T' Steering Linkage, Modifed PSC Steering Brace, P3 Brake Controller, Modifed Fusion "mall crawler" rear bumper , PIAA 1500 Back-Up Lights, 1Ton HEMI Tranny Cooler, Leer 100XR Bed Cap, Factory Tow Mirrors, CenterLine Rims 17x9-5.25 BS, Mag-Hytec Tranny Pan, AutoMeter Gauges, PSC Extreme Hydro Assist Steering, Carli G2 Track Bar, Carli Ball-Joints, Dynatrac FreeSpin Hubs, Snorkel, RCV Axles, EBC Pads & Rotors, Aluminess Front Bumper, BIG Pul-Pal, 60" Extreme Hi-lift Jack, and more riggin' equipment, Carli Long Travel Air Bags, Bilstein 7100 Shocks - Carli Valving, Carli Control Arms, Thuren 3" SoftRide Springs, Thuren Rear Shackles, MagnaFlow Muffler, Crown Stainless Brake Lines, MORE STUFF COMIN'.
Russ NRA Benefactor Member
FordyceCreekTrail
Post by FordyceCreekTrail » Mon Jan 22, 2018 9:18 am
Unbelievable. Same thing on my 2005 Nissan Titan at maybe 180K as well. Started having engine performance issues, check engine lights even the damn cruise control would conch out. I thought maybe fuel pump.(figured cruise control was another issue) When the shop told me it was cracked exhaust manifolds I told them they were crazy. Never had a glitch since. I guess its all the modern sensors that start getting bad readings somehow with the back pressure loss?
BoldAdventure
Post by BoldAdventure » Mon Jan 22, 2018 9:37 am
What's funny is we had to replace the same bolts on our 2010 1500 5.7 Hemi. And after we had them replaced, about I'd say 11 months later they'd backed out again.
Post by DamageWagon » Mon Jan 22, 2018 1:28 pm
I believe it’s two things going on that cause issues when the manifold leaks. One is that the oxygen sensors think it is running lean and it overfuels, this wasting fuel and fouling the plugs faster. Second it loses backpressure which seems to be very important for scavenging on the Hemi.
I used a few new factory exhaust bolts but I’m switching everything to Class 10.9 hardware that reaches deeper in the bore than the stock stuff. I’m hoping the hardware is a higher quality than what came on the truck. I used red loctite 273 on the hardware. We will see how that lasts, it’s onky rated to 450f if I recall but that’s the highest loctite offers that I found.
