Another Government Wagon Auction
Re: Another Government Wagon Auction
Post by DamageWagon » Wed Dec 06, 2017 8:24 pm
I paid $13k for my '11
Post by FordyceCreekTrail » Thu Dec 07, 2017 8:37 am
That seems pretty reasonable. Thats the trick with auctions, sometimes things go low, sometimes high. Just have to know your limit.
Post by olyelr » Thu Jan 18, 2018 6:21 am
Retired BLM Rig wrote:
Thu Jan 18, 2018 3:07 am
A clean looking 08 in El Dorado Hills, CA.
Closes on 1/20/18. Maybe I should buy it for spare parts! :idea: :lol: :run:
Almost looks like it just rolled off the assembly line.... nice!!
Post by Retired BLM Rig » Sun Jan 21, 2018 1:06 am
The government shutdown caused all these auctions to be put on hold. :doh:
If I was one of the bidders... :angry: :box:
EasyDoesIt
Post by EasyDoesIt » Mon Feb 26, 2018 2:28 pm
I bid on several before I bit the bullet on my 2018. I really wanted a 2012 but bids kept going over $20k which was too much in my mind.
I wonder what the 2014s will go for once they start showing up?
Post by Retired BLM Rig » Tue Feb 27, 2018 9:39 am
I bet that 2010 goes pretty cheap. It looks a little rough around the edges and has 153K on the clock, I'll be surprised if it hits $10K. It's ready for retirement and civilian life (someone to give it a little TLC). :patriot:
Post by Retired BLM Rig » Thu Mar 08, 2018 1:42 am
An 07 in Sparks, NV. Sold for $13200.00
A 12 in San Antonio, NM. Sold for $8241.00
Both auctions end on 3/14. :patriot:
Last edited by Retired BLM Rig on Tue Apr 03, 2018 9:17 am, edited 1 time in total.
Post by DamageWagon » Thu Mar 08, 2018 1:50 am
That 2012 is an exact copy of my 2011 and came from only a few hours away from where mine did. I guess they like PW’s in New Mexico
Post by Retired BLM Rig » Thu Mar 08, 2018 10:21 am
That one needs a T-case too. :sick: There must be some connection. ;)
Post by Retired BLM Rig » Mon Mar 19, 2018 3:13 am
This 2005 is in Brewerton, NY, so you east coast guys have a chance on this one.
It says that the battery is dead and may need other repairs. With only 83285 miles, I bet if you put a battery in, it would drive away. If nothing else it could be a good parts truck for someone.
Current bid $3510.00, ends in 3-1/2 days.
Edit: This ended up selling for $8915.00
Last edited by Retired BLM Rig on Tue Apr 03, 2018 9:12 am, edited 1 time in total.
Post by adeluca73 » Wed Mar 21, 2018 12:15 am
Says the winch is rusted and cable won’t come out...wonder if a good dousing in PB Blaster would free the winch cable? Current bid $5K...tempting
Post by coder » Wed Mar 21, 2018 1:20 pm
If the winch goes in but not out it's most likely the thermal disconnect switch is not working it can be easily bypassed. It's a common problem on early 3rd Gen PW's. I did the bypass as a preventative measure not to long after I got my truck, see my signature below "Winch Thermal Protection Bypass".
Post by adeluca73 » Wed Mar 21, 2018 3:45 pm
It’s now at $5500, much higher and that 13yr old truck suddenly gets far less attractive
yooper68
Post by yooper68 » Thu Mar 22, 2018 1:07 pm
Wow! - That 2005 is almost the same as my 2003 except I don't have the PW package.
I do have more rust on the body/fenders but the interior & topper on mine are nicer.
I would say it is worth $5500 if that is the price range someone is looking for.
Trucks: 2003 4x4 Dodge 3/4 ton, 1972 4x4 Ford 3/4 ton (factory hi-boy), shopping for new Power Wagon (or may wait for 2020 model? - 75th year special edition?)
Post by TwinStick » Thu Mar 22, 2018 4:11 pm
If the lockers work, it is worth more than current bid in spare parts !
Post by Retired BLM Rig » Sun Mar 25, 2018 5:18 pm
Next vehicle for your consideration: A 2010 with a lovely three tone paint scheme, high milage and missing parts, in Eldorado Hills, CA. :vomit:
This ended up selling for almost $15K. :jawdrop:
Maybe the brown stripes were just vinyl stickers.
Post by Retired BLM Rig » Sun Apr 08, 2018 2:22 am
Here's a 2012 in West Valley City, UT. with Ramboxes. 135K miles.
I see a winch cradle but no hook or cable.
Post by DamageWagon » Sun Apr 08, 2018 4:02 am
I wasn’t planning on buying another truck but man that could be a solid deal
stooper
Post by stooper » Mon Apr 09, 2018 10:37 am
When i got mine the winch cable was still zip tied to the drum.
Post by adeluca73 » Thu Apr 19, 2018 1:03 pm
Sat Apr 14, 2018 12:34 am
Less than 12 hours to go, holding at $9700 for the last couple days.
2012 DODGE RAM 2500
Sale-Lot Number:
81QSCI18155015
City, State:
Current Bid:
17,890 USD
Bidders:
13
Close Time:
04/14 12:11 PM CT (Closed)
Time Remaining:
Sold for below fair condition book value...
Post by Retired BLM Rig » Thu Apr 26, 2018 10:59 pm
Another 2010 in Eldorado Hills, CA.
Lower miles than the last one, but it has a dimpled tailgate, tweaked front bumper and a missing console/seat, just to name a few obvious things.
Post by Retired BLM Rig » Sun May 13, 2018 6:12 pm
A 2011 in Taos, NM.
This one may go cheap due to the holes in the body, unless you got creative with stickers, emblems, massive fender flares or a wrap to cover them up.
It looks like one of DamageWagon's siblings.
Or there's this 2012 in Coeur D Alene, ID. that appears to be intact.
