Are 2008 and 2015 pw wheels the same?
powwagkup
Post by powwagkup » Mon Nov 28, 2016 11:49 pm
Does anyone know if the wheels from a 2015 are the same as a 2008? I'm looking to put pw wheels on my Kamparoo and found a set of 2015s. I would like to be able to use them as spares in an emergency.
Thanks!
Sent from my SM-G900T using Tapatalk
ramv
Re: Are 2008 and 2015 pw wheels the same?
Post by ramv » Tue Nov 29, 2016 12:06 am
Same bolt pattern and size I believe. The 2015s have cost center sections so won't work with aftermarket manual hubs with out modification.
Post by olyelr » Tue Nov 29, 2016 6:48 am
No, not the same. Completely different look. But as ramv stated, should work the same as long as you dont have manual hubs.
Post by FirerescuePW » Tue Nov 29, 2016 5:12 pm
Somewhere in there they changed lug size-standard to metric. I imagine there is a difference in the hole size, I just can't remember what year.
powwagkup
Post by powwagkup » Wed Nov 30, 2016 11:29 pm
Thanks everyone. They would be great, but the more research I'm doing, it looks like a lot more upgrading is going to be needed. Axle, hubs, spacers, etc. I may keep the 14 inchers on it for now or some rubicon stockers.
Post by olyelr » Wed Nov 30, 2016 11:54 pm
powwagkup wrote:Thanks everyone. They would be great, but the more research I'm doing, it looks like a lot more upgrading is going to be needed. Axle, hubs, spacers, etc. I may keep the 14 inchers on it for now or some rubicon stockers.
Maybe you could find some spacers which adapt the different lug patterns together.
