Head Gasket
Re: Head Gasket
Post by Reloaderguy » Fri Aug 19, 2016 11:04 pm
The prudent thing to do would be to pull the block, install some lower compression forged pistons, a fat cam, full port/polish/valve job/grind, and then put on a Arrington blower. Anything less is probably unreasonable.
pdavey
Re: Head Gasket
Post by pdavey » Tue Aug 30, 2016 10:43 pm
Ok so an update. Now have a Comp 260 cam, upgraded valve springs, forged push rods, JBA shorties and new lifters to install.
Hope to take on most of that work this weekend.
Additionally I ordered a 6.1 valve cover and coil conversion kit that will allow me to get rid of the spark plug wires.
Keep you all posted.
Performance Mods:
Other Mods:
Suspension/Protection Mods:
Style/Other Mods:
Re: Head Gasket
Post by FirerescuePW » Wed Aug 31, 2016 6:33 am
Sounds great, Peter! Save the part numbers for me. In 20 years, when I hit your mileage, I may need them.
Re: Head Gasket
Post by Colibri » Wed Aug 31, 2016 8:31 am
Wow, sounds promising! Can't wait for you to get it buttoned up!
jswider
Re: Head Gasket
Post by jswider » Wed Aug 31, 2016 1:10 pm
How much is a coil conversation kit and does that require a tune or reflash of the ecm?
pdavey
Re: Head Gasket
Post by pdavey » Wed Aug 31, 2016 1:45 pm
It's not cheap. About $800, if you want the valve covers. But gives you the new composite valve covers ignition pieces and the wiring you need. No ECM flash needs. 3rd Strike Performance sells them and if you are a member of Hemi Truck Club you get a discount. I will post pics of the parts and install when I get them as well as a link to the site.
Performance Mods:
Other Mods:
Style/Other Mods:
pdavey
Re: Head Gasket
Post by pdavey » Sun Sep 04, 2016 10:29 am
So I changed the springs on my heads last night. I found something lurking under my cylinder 4 exhaust spring that can only be described as a ticking time bomb.
The job went pretty well though. Nice shiny new springs. Valves and valve seats were in good shape.
Mac (Snowflake) came down to help.
Performance Mods:
Other Mods:
Style/Other Mods:
Re: Head Gasket
Post by Colibri » Sun Sep 04, 2016 11:42 am
That's scary finding loose pieces of steel in an engine. Bravo for taking this job on sir, it's looking really good. What springs did you end up getting? Are those the psi?
w2dodge
Re: Head Gasket
Post by w2dodge » Sun Sep 04, 2016 1:07 pm
sure thing that little piece would of did some damage...why not do some porting and polishing ?
flattire
Re: Head Gasket
Post by flattire » Sun Sep 04, 2016 1:11 pm
In the top photo (showing broken piece) what is the piece that is broken off? This is the bottom of stock valve spring?
pdavey
Re: Head Gasket
Post by pdavey » Sun Sep 04, 2016 3:30 pm
Yeah it is the bottom of the cage for the stock spring. The new springs don't have cages. Yes they are the PSI springs equivalent to the 6.1's.
Performance Mods:
Other Mods:
Style/Other Mods:
pdavey
Re: Head Gasket
Post by pdavey » Sun Sep 04, 2016 3:35 pm
Got to the point of where I need to install the new camshaft today and it hasn't come yet Image
That said got a lot of other things done.
The hydraulic tappets looked really good as well as the old camshaft. Nice to see everything looking good.
Hope to have the new camshaft and tune next week then I will begin reassembly.
Still waiting on new valve covers.
Performance Mods:
Other Mods:
Style/Other Mods:
Re: Head Gasket
Post by FirerescuePW » Sun Sep 04, 2016 3:46 pm
I'm trying to figure out where the potting soil goes...
Oh, Hi Mac!
pdavey
Re: Head Gasket
Post by pdavey » Sun Sep 04, 2016 3:55 pm
Hahahahahahaha. I thought you ran that through the radiator before start up in order to dry the system out. Is that not true? Why would the FSM say get a 20lb bag otherwise?
Performance Mods:
Other Mods:
Style/Other Mods:
Re: Head Gasket
Post by RustyPW » Sun Sep 04, 2016 5:59 pm
Since you are down this far. Now's a good time to replace the oil pump too.
Re: Head Gasket
Post by FirerescuePW » Sun Sep 04, 2016 6:16 pm
Not a bad idea, with the mileage on it.
Re: Head Gasket
Post by coder » Sun Sep 04, 2016 10:38 pm
I still think you should pull the engine and rebuild the bottom end you're already halfway there!
pdavey
Re: Head Gasket
Post by pdavey » Sun Sep 04, 2016 11:48 pm
I think that makes sense Rusty.
Performance Mods:
Other Mods:
Style/Other Mods:
pdavey
Re: Head Gasket
Post by pdavey » Sun Sep 04, 2016 11:49 pm
We also did a side project today and got the A/C working in Snowflake. Ended up being a missing vacuum line and a bad relay. All good now.
Performance Mods:
Other Mods:
Style/Other Mods:
pdavey
Re: Head Gasket
Post by pdavey » Wed Sep 14, 2016 4:36 pm
Camshaft arrived today. Time to start putting the truck back together this weekend. Pics to come on Saturday.
Performance Mods:
Other Mods:
Style/Other Mods:
Re: Head Gasket
Post by Colibri » Wed Sep 14, 2016 6:20 pm
Fantastic! Can't wait to see her breath fire!
Re: Head Gasket
Post by RustyPW » Wed Sep 14, 2016 6:55 pm
Damn it. I want to see the up-date and see it running. But I will be in Mexico next week.
pdavey
Re: Head Gasket
Post by pdavey » Wed Sep 14, 2016 7:14 pm
Likely will take me two weekends to get it all together so you will probably be ok
Performance Mods:
Other Mods:
Style/Other Mods:
Re: Head Gasket
Post by RustyPW » Wed Sep 14, 2016 8:05 pm
You replacing the oil pump?
I'm leaving tomorrow for LA. Saturday jumping on a cruise ship. :cash: :cash: :cash: Be back on the 25th. So no cell phone or internet. But lots of liquor. :chug:
pdavey
Re: Head Gasket
Post by pdavey » Wed Sep 14, 2016 8:09 pm
Have fun. Yes oil pump should be here this weekend too. I ordered a new timing cover gasket but it hasn't been delivered yet.
Performance Mods:
Other Mods:
Style/Other Mods:
