Page 2 of 3
Re: 35" tires including spare in factory 2015
Posted: Sat Apr 08, 2017 8:00 am
Reloaderguy wrote:I drove my truck today for the first time in two weeks. 35's are lame.
I drove my truck twice today. 37's are lame.
Posted: Sat Apr 08, 2017 10:17 am
by DamageWagon
Time for 33's?
Posted: Sun Apr 09, 2017 2:08 am
by TankerZak
Numbnuts wrote:I just put the R/T Toyos 35x12.5x17 on a factory rim at stock height.
She rub at less than full lock on the control arm
What year truck? My 16 doesn't rub at all. Same tires...
Re: 35
Posted: Sun Apr 09, 2017 8:46 am
TankerZak wrote:Numbnuts wrote:I just put the R/T Toyos 35x12.5x17 on a factory rim at stock height.
He stated control arms, so I would assume he has a '13 or older (newer ones have radius arms). The control arm trucks are even more prone to rubbing than the newer radius arm ones.
Posted: Sun Apr 09, 2017 5:58 pm
by TankerZak
olyelr wrote:TankerZak wrote:Numbnuts wrote:I just put the R/T Toyos 35x12.5x17 on a factory rim at stock height.
That was my suspicion as well from the way he said it. That reminds me... i still need to go see if i can get Les Schwab to shove a full size spare in there...
by TankerZak
That was my suspicion as well from the way he said it. That reminds me, i still need to go see if i can get Les Schwab to shove a full size spare in there!
Posted: Sun Apr 09, 2017 10:52 pm
by Bluchalk
+1 37's
Posted: Sun Apr 09, 2017 11:01 pm
by DamageWagon
Do you use your brakes much? Holy crap dude
On a serious note, it is amazing how large of s tire you can fit in these trucks and somehow still clear. Good lookin truck!
Posted: Sun Apr 09, 2017 11:07 pm
by TankerZak
DamageWagon wrote:Do you use your brakes much? Holy crap dude
Thats what happens when you use round fenders and wheel wells to cover the round things that go around. Instead of square. /facepalm
Posted: Sun Apr 09, 2017 11:08 pm
by TankerZak
Thats what happens when you use round fenders and wheel wells to cover the round things that go around. Instead of square. Smdh
Posted: Sat Apr 15, 2017 1:17 pm
by dkjager
MPG seems about the same, but I've not reflashed the computer. Of course it reads lower, but speedo is off about 8-10mph now. I do offroad and tow a lot.
Posted: Sun Apr 16, 2017 10:07 am
dkjager wrote:MPG seems about the same, but I've not reflashed the computer. Of course it reads lower, but speedo is off about 8-10mph now. I do offroad and tow a lot.
Its off by a percentage. Probably around 10% or so. So at 20 mph its not that far off, but at 80 mph, yeah quite a ways off.
Posted: Tue Apr 18, 2017 2:52 pm
by dkjager
Had to trim a lot of the wheel well plastic, had to beat back the corner of the metal, trimmed the bumper as well. I only added a 1.5" leveling spacer (for now). I do off road a lot and get full flex when disconnected. In that case, it does still rub a little. 37x12.50 I've heard have less rubbing. THE LOOK is perfect though. Here's the latest, since adding the rear bumper.
35" spare in factory 2015
Posted: Wed Apr 19, 2017 9:05 pm
by dkjager
Here's more detail on my spare: It's about 1.5" shorter than the Toyo's I have mounted (see photo). My "plan" is to air it up to 70lb which will bulge it out. I run 30-40 normally on the Toyo's, 15-18 off road. That should put them about 3/8" apart which I think is fine for dead heading home. Now, for mounting, you can see not much room at all. First you have to bend back the heat shield a bit (I laid on my back and pushed with my feet to get it done). Next, when you jack it up, be sure it is flat to slightly up towards the hitch (back) and frame (driver side). To mount a 37x12.50, a worn down one, moving the hitch back may work, plus, you'll be touching the heat shield and muffler for sure.
Posted: Wed Apr 19, 2017 11:20 pm
by TheDirtRoad
That looks really good. Is that a GO Rhino rear bumper?
Posted: Wed Apr 19, 2017 11:50 pm
by nts007
Bumper looks awesome
Posted: Thu Apr 20, 2017 2:38 pm
by dkjager
Yes go rhino bumper.
Posted: Fri Apr 21, 2017 12:04 am
by adeluca73
Really like the looks of your new wheels & tires. That rear bumper is BA!!!
Posted: Thu May 04, 2017 12:38 pm
by dkjager
Thanks! I'm still struggling with the truck driving to the right. It is worse under braking and towing (with EQ hitch). I've micro adjusted it 50 times. Going to get it up on a rack soon but I wonder if something else is stressing the suspension causing it to drift to the right. Thuren adj track bar made no difference. New rims made no difference, tire size no difference. It was from the 1.5" spacer and/or shock extension that did it.
Posted: Thu May 04, 2017 2:12 pm
by Reloaderguy
Did you loosen all of the radius arm bolts before installing the spacers and then tighten them with the full weight of the truck on the ground?
Posted: Thu May 04, 2017 2:40 pm
I have a 1.5" spacer and dont have any issues with veering. Drives just like it did without the spacer. I did not loosen the radius arm bolts either.
On a side note, I did not use the shock spacers they sent. Why they send 2.5" shock extensions with a 1.5" spacer kit is beyond me. When I ran the numbers, it appeared the shocks would bottom out long before the stock bumpstops would be used. Sounds like a recipe for damaged shocks and/or ripped off shock mounts.
Posted: Fri May 05, 2017 11:23 am
by rkgzx9leftcoast
dkjager wrote:Thanks! I'm still struggling with the truck driving to the right. It is worse under braking and towing (with EQ hitch). I've micro adjusted it 50 times. Going to get it up on a rack soon but I wonder if something else is stressing the suspension causing it to drift to the right. Thuren adj track bar made no difference. New rims made no difference, tire size no difference. It was from the 1.5" spacer and/or shock extension that did it.
A lot of good info on Thurens Tech Page. I dont have all the info on what you have tried, but these trucks are very sensitive to alignment issues, and some tires do have a pull built into them. Thuren also has a really nice king dampener as well??
https://www.thurenfabrication.com/tech/ ... dling.html
Posted: Wed May 24, 2017 3:48 pm
by dkjager
got the alignment done, however, the settings ended up being beyond what thuren recomended. I didn't do anything with the radius arms, might do that as well. The tech that did the alignment also installed an offset ball joint but I'm still not sure why that fixed it, but it did.
Posted: Wed May 24, 2017 3:53 pm
by dkjager
Finished with the build out (for now)
Posted: Thu May 25, 2017 11:08 am
by rkgzx9leftcoast
Bumper looks great! On the ball joint I know a few companies make a 1 Degree offset Ball Joint for Camber, meaning you can lean the top of the tire in or out. Mine has more Camber on the 1 side, top is leaned out, but everyone keeps telling me it within spec for these trucks. It drives fine so for now ill live with it.
I know I have read threads in other forums before where to much Camber on these trucks eats front tires, but not much you can do, let us know after some time how the Ball Joint is holding up, do you know what make it is ? I know Carli is testing there ball joints for the newer trucks now, I am hoping the have a little Camber adjust ability to them...
Truck looks great!!
