35" tires including spare in factory 2015
Re: 35" tires including spare in factory 2015
Post by olyelr » Sat Apr 08, 2017 6:00 am
Reloaderguy wrote:I drove my truck today for the first time in two weeks. 35's are lame.
I drove my truck twice today. 37's are lame.
Post by DamageWagon » Sat Apr 08, 2017 8:17 am
Time for 33's? [emoji3]
Post by TankerZak » Sun Apr 09, 2017 12:08 am
Numbnuts wrote:I just put the R/T Toyos 35x12.5x17 on a factory rim at stock height. :rockon:
She rub at less than full lock on the control arm :jawdrop: :angry:
What year truck? My 16 doesn't rub at all. Same tires...
2016 Granite Crystal Metallic Power Wagon Laramie, no graphics, debadged, Thuren front and rear coils, Traxada rear 1 inch spacer, Thuren rear swaybar links, Thuren rear trackbar, King 3.0 (Stage 4) front shocks, King 2.5 (Stage 3) rear shocks, Boogie front bump stops, Toyo RT 37x12.5R17 on Raceline Avenger 17x9 +20 wheels, DOR steering brace, White Knuckle rock sliders, Dethloff skid plate, Purple Cranium Half Spider front and rear diff guards, Airlift Ultimate airbags with Daystar cradles, Bakflip Revolver X2 tonneau, AMP BedStep, Factor55 Ultrahook with 100ft 7/16 synthetic winch line, Magnaflow 19200 modified with upgraded resonator and after axle dump, tinted front windows 35%.
Re: 35
Post by olyelr » Sun Apr 09, 2017 6:46 am
He stated control arms, so I would assume he has a '13 or older (newer ones have radius arms). The control arm trucks are even more prone to rubbing than the newer radius arm ones.
Post by TankerZak » Sun Apr 09, 2017 3:58 pm
That was my suspicion as well from the way he said it. That reminds me... i still need to go see if i can get Les Schwab to shove a full size spare in there...
That was my suspicion as well from the way he said it. That reminds me, i still need to go see if i can get Les Schwab to shove a full size spare in there!
Bluchalk
Post by Bluchalk » Sun Apr 09, 2017 8:52 pm
+1 37's :rockon:
Synergy 1" rear lift shackles, Bilstien 5100 shocks
DT Pro Fab sway bar end links
Rugged Ridge floor mats
AMP bed step
37" Toyo RT's
Post by DamageWagon » Sun Apr 09, 2017 9:01 pm
Do you use your brakes much? Holy crap dude
On a serious note, it is amazing how large of s tire you can fit in these trucks and somehow still clear. Good lookin truck!
Post by TankerZak » Sun Apr 09, 2017 9:07 pm
DamageWagon wrote:Do you use your brakes much? Holy crap dude
Thats what happens when you use round fenders and wheel wells to cover the round things that go around. Instead of square. /facepalm
Post by TankerZak » Sun Apr 09, 2017 9:08 pm
Thats what happens when you use round fenders and wheel wells to cover the round things that go around. Instead of square. Smdh
dkjager
Post by dkjager » Sat Apr 15, 2017 11:17 am
MPG seems about the same, but I've not reflashed the computer. Of course it reads lower, but speedo is off about 8-10mph now. I do offroad and tow a lot.
2015 PowerWagon
Maximum Steel with Ram Box
37x13.50r17 Toyo MT
American Outlaw Buckshot +15 offset
GoRhino rear bumper
Marathon Seat covers
Traxda 1.5" leveling kit with shock extensions
Thuren adjustable track bar
ADD "PowerWagon" front bumper
Factor 55 ProLink
White Knuckle OffRoad rails
T Rex grill
Post by olyelr » Sun Apr 16, 2017 8:07 am
dkjager wrote:MPG seems about the same, but I've not reflashed the computer. Of course it reads lower, but speedo is off about 8-10mph now. I do offroad and tow a lot.
Its off by a percentage. Probably around 10% or so. So at 20 mph its not that far off, but at 80 mph, yeah quite a ways off.
dkjager
Post by dkjager » Tue Apr 18, 2017 12:52 pm
Had to trim a lot of the wheel well plastic, had to beat back the corner of the metal, trimmed the bumper as well. I only added a 1.5" leveling spacer (for now). I do off road a lot and get full flex when disconnected. In that case, it does still rub a little. 37x12.50 I've heard have less rubbing. THE LOOK is perfect though. Here's the latest, since adding the rear bumper.
2015 PowerWagon
37x13.50r17 Toyo MT
GoRhino rear bumper
Factor 55 ProLink
T Rex grill
dkjager
35" spare in factory 2015
Post by dkjager » Wed Apr 19, 2017 7:05 pm
Here's more detail on my spare: It's about 1.5" shorter than the Toyo's I have mounted (see photo). My "plan" is to air it up to 70lb which will bulge it out. I run 30-40 normally on the Toyo's, 15-18 off road. That should put them about 3/8" apart which I think is fine for dead heading home. Now, for mounting, you can see not much room at all. First you have to bend back the heat shield a bit (I laid on my back and pushed with my feet to get it done). Next, when you jack it up, be sure it is flat to slightly up towards the hitch (back) and frame (driver side). To mount a 37x12.50, a worn down one, moving the hitch back may work, plus, you'll be touching the heat shield and muffler for sure.
2015 PowerWagon
37x13.50r17 Toyo MT
GoRhino rear bumper
Factor 55 ProLink
T Rex grill
TheDirtRoad
Post by TheDirtRoad » Wed Apr 19, 2017 9:20 pm
That looks really good. Is that a GO Rhino rear bumper?
Post by nts007 » Wed Apr 19, 2017 9:50 pm
Bumper looks awesome
dkjager
Post by dkjager » Thu Apr 20, 2017 12:38 pm
Yes go rhino bumper.
2015 PowerWagon
37x13.50r17 Toyo MT
GoRhino rear bumper
Factor 55 ProLink
T Rex grill
Post by adeluca73 » Thu Apr 20, 2017 10:04 pm
Really like the looks of your new wheels & tires. That rear bumper is BA!!!
dkjager
Post by dkjager » Thu May 04, 2017 10:38 am
Thanks! I'm still struggling with the truck driving to the right. It is worse under braking and towing (with EQ hitch). I've micro adjusted it 50 times. Going to get it up on a rack soon but I wonder if something else is stressing the suspension causing it to drift to the right. Thuren adj track bar made no difference. New rims made no difference, tire size no difference. It was from the 1.5" spacer and/or shock extension that did it.
2015 PowerWagon
37x13.50r17 Toyo MT
GoRhino rear bumper
Factor 55 ProLink
T Rex grill
Post by Reloaderguy » Thu May 04, 2017 12:12 pm
Did you loosen all of the radius arm bolts before installing the spacers and then tighten them with the full weight of the truck on the ground?
Post by olyelr » Thu May 04, 2017 12:40 pm
I have a 1.5" spacer and dont have any issues with veering. Drives just like it did without the spacer. I did not loosen the radius arm bolts either.
On a side note, I did not use the shock spacers they sent. Why they send 2.5" shock extensions with a 1.5" spacer kit is beyond me. When I ran the numbers, it appeared the shocks would bottom out long before the stock bumpstops would be used. Sounds like a recipe for damaged shocks and/or ripped off shock mounts.
rkgzx9leftcoast
Post by rkgzx9leftcoast » Fri May 05, 2017 9:23 am
dkjager wrote:Thanks! I'm still struggling with the truck driving to the right. It is worse under braking and towing (with EQ hitch). I've micro adjusted it 50 times. Going to get it up on a rack soon but I wonder if something else is stressing the suspension causing it to drift to the right. Thuren adj track bar made no difference. New rims made no difference, tire size no difference. It was from the 1.5" spacer and/or shock extension that did it.
A lot of good info on Thurens Tech Page. I dont have all the info on what you have tried, but these trucks are very sensitive to alignment issues, and some tires do have a pull built into them. Thuren also has a really nice king dampener as well??
https://www.thurenfabrication.com/tech/ ... dling.html
dkjager
Post by dkjager » Wed May 24, 2017 1:48 pm
got the alignment done, however, the settings ended up being beyond what thuren recomended. I didn't do anything with the radius arms, might do that as well. The tech that did the alignment also installed an offset ball joint but I'm still not sure why that fixed it, but it did.
2015 PowerWagon
37x13.50r17 Toyo MT
GoRhino rear bumper
Factor 55 ProLink
T Rex grill
dkjager
Post by dkjager » Wed May 24, 2017 1:53 pm
Finished with the build out (for now)
2015 PowerWagon
37x13.50r17 Toyo MT
GoRhino rear bumper
Factor 55 ProLink
T Rex grill
rkgzx9leftcoast
Post by rkgzx9leftcoast » Thu May 25, 2017 9:08 am
Bumper looks great! On the ball joint I know a few companies make a 1 Degree offset Ball Joint for Camber, meaning you can lean the top of the tire in or out. Mine has more Camber on the 1 side, top is leaned out, but everyone keeps telling me it within spec for these trucks. It drives fine so for now ill live with it.
I know I have read threads in other forums before where to much Camber on these trucks eats front tires, but not much you can do, let us know after some time how the Ball Joint is holding up, do you know what make it is ? I know Carli is testing there ball joints for the newer trucks now, I am hoping the have a little Camber adjust ability to them...
Truck looks great!!
