Krown...Rust Check.... Fluid Film
Re: Krown...Rust Check.... Fluid Film
Post by olyelr » Mon Dec 10, 2018 7:15 pm
Well I am a little late to the party this year (already had out fair share of snow and salty roads), but the 3rd application is now complete (this is the trucks 3rd winter).
Post by olyelr » Mon Dec 10, 2018 7:17 pm
This is sand squirting out of one of the drain ports in the rockers after spraying a bunch of fluid film in there.
Post by DamageWagon » Mon Dec 10, 2018 7:22 pm
I’ve never seen someone try to aerosolize peanut butter before
Post by olyelr » Mon Dec 10, 2018 8:02 pm
While it does indeed look like soupy pb, it certainly dosnt smell like it! :lol:
Post by Reloaderguy » Mon Dec 10, 2018 8:41 pm
Yep, there are drain ports all along the bottom of the rockers. There is also a divider panel down the center of the rocker, you need to peel back the tape and look for the additional access ports inside. If not there is a good chance you're only spraying the inboard half of each rocker.
Post by olyelr » Mon Dec 10, 2018 9:08 pm
Well shit, I was not aware of that. I sure hope I have been getting everything....
Is there just one divider panel? Like in the center? If so, when I am spraying from each end and shoving the wand to the center, I would still be getting everything. I swear I would stick that two foot wand in ever one of those damn ports and go in both directions and never hit anything.
Post by Reloaderguy » Mon Dec 10, 2018 10:41 pm
Look at the first page of my build thread, I posted a picture of the rocker cut open. When I closed the rocker up I had to spray rust inhibitor in the cavity. The only way to access the outer chamber was through holes ported in the divider close to the holes taped closed from the factory. You should be able to see inside the rocker sitting under the truck looking into the back of the rocker at the front of the cab.
Post by olyelr » Mon Dec 10, 2018 11:57 pm
Alright I will check it out, thanks for the heads up.
Post by olyelr » Tue Dec 11, 2018 12:17 am
Damnit, I’m pickin’ up what your throwin’ down now. You are talking about a barrier down the center of the rocker, LENGTHWISE. Shit. I have probably never been spraying much of anything on that side.
Post by Bill2014 » Tue Dec 11, 2018 8:48 am
Have you pumped any of that "special" fluid into your tail pipe? :rofl:
Post by KevinABQ » Tue Dec 11, 2018 2:40 pm
That's how you keep your engine from rusting, right? :wink:
Post by olyelr » Tue Dec 11, 2018 4:26 pm
So on the outer side of the rocker panels are several small rectangular rubber plugs. I pulled one off on each end, and one off in the middle. Inserted spray nozzle (connected to aerosol cans of fluid film) and coated all areas. (This is also how I do the door seems). I noticed a few of the plugs I pulled off already had fluid film on them on the inside, so it must get in there a little bit somehow from the back side. But I feel much better now.
Thanks for that heads up Reloader!
Post by olyelr » Tue Dec 11, 2018 4:32 pm
Maybe my friends moms tailpipes, but never my truck.
Post by Bill2014 » Tue Dec 11, 2018 6:59 pm
Well don't let your exhaust butterfly valve seize. I'd squirt some up in there too :poke:
Post by Reloaderguy » Tue Dec 11, 2018 7:28 pm
I think my friend's parents are in their 60s and 70s. You're really knocking the rust off those old broads.
Post by RustyPW » Tue Dec 11, 2018 7:40 pm
All this talk about anal. Sticking it up your tail pipes. :wtf: I don't know about some of you guys. :digahole:
Post by olyelr » Tue Dec 11, 2018 7:53 pm
Jeeeezuz Rusty, get your mind out of the gutter!! :lol:
Post by RustyPW » Tue Dec 11, 2018 8:32 pm
ME! You guys started it by talking about putting stuff in your tail pipes!
Post by olyelr » Tue Dec 11, 2018 9:06 pm
Actually Bill started it! Hes the culprit!
Post by Reloaderguy » Tue Dec 11, 2018 10:19 pm
Bill was worried your trombone was getting rusty.
Post by Bill2014 » Wed Dec 12, 2018 9:54 am
Just looking out for my fellow PW owners and the well being of their trucks. :rockon:
Post by Bill2014 » Wed Dec 12, 2018 9:59 am
Rusty - WHOA! that was a big leap to "anal" :doh:
However, I have noticed that she (my PW) gets rather excited and wet - and starts dripping from the tail pipe a minute after I get her started! hmmm :popcorn:
Post by Colibri » Wed Dec 12, 2018 12:50 pm
Post by RustyPW » Wed Dec 12, 2018 3:29 pm
No it's not with you guys. When you's started talking about sticking things up the tail pipes. My first thoughts was alien anal probing. :shock:
