09 locker bypass
- Sumbeach84
09 locker bypass
Anyone make a plug and play kit for this year? I've read the articles and it doesn't seem hard to do but finding the resistor and switch have been kind of an issue lol
- Cactus Red
Re: 09 locker bypass
I have one of the resistor type I'll give you if your interested. PM me, I'll send you my info, you send a pre-paid envelope, and it's yours.
Socialism: A stage of society in Marxist theory transitional between capitalism and communism and distinguished by unequal distribution of goods and pay according to work done.
Now thats what Im talking about!Cactus Red wrote:I have one of the resistor type I'll give you if your interested. PM me, I'll send you my info, you send a pre-paid envelope, and it's yours.
Is your's plug and play Cactus Red? If not, I can provide the connectors from a Toyota coil to make it plug and play.Cactus Red wrote:I have one of the resistor type I'll give you if your interested. PM me, I'll send you my info, you send a pre-paid envelope, and it's yours.
http://forum.powerwagonregistry.org/vie ... f=2&t=3953
- Cactus Red
It's just the resistor and toggle switch. Had to pull it prior to the current service work to fix the lockers, and won't be putting it back in.
Honestly it's the one mod I used the least. The resistor type bypass does allow you to use the lockers in 2hi/4hi, but the truck thinks it"s in 4lo, so the remapped throttle kicks in. It is quite noticeable. The throttle response is slow until roughly 3K, then it comes on hard. And I've found the limited slip differential we have rarely requires the need for the rear locker in most situations encountered in high range. I will miss having the option tho.
- Sumbeach84
Sorry I've been super busy with work and haven't been on to reply lately! Yea id take it if you wanna get off of it that would be great I gotta install my new sway bar and end links soon anyways
- Cactus Red
It's easy to install now too - http://forum.powerwagonregistry.org/vie ... f=2&t=3953
PM me, and we'll get the mailing figured out.
- Sumbeach84
Thanks for the help pm sent
