2wd Low Range
2wd Low Range
Re: 2wd Low Range
No way. How is that even possible?
When you pull the lever into 4 high or low the tcase spins the front and rear outputs. How in the hell does some wiring prevent that from occurring.
Or does it prevent the CAD from engaging????
Re: 2wd Low Range
Prevents CAD yes. Honestly I've been sitting scratching my head for an hour trying to figure out why anyone would possible want to do this. Maybe someone has a reason but when you want the slow real low gearing usually you want to be locked up in full 4wd so..... This doesn't seem valuable to me unless you want to run 6th gear at 15mph
And if it's to get a truly massive weight moving well 2wd would be useless as you would just spin anyway so you want all 4 tires...... I just don't get it. For really slow tight turning?
Re: 2wd Low Range
Yeah. Like when i am moving my travel trailer around in the driveway. Or in a tight trail where you are using low range moreso for slow, fine movement rather than traction.
Re: 2wd Low Range
I have a g56. Just bought parts to do this on my own, now I have plug and play option. Awesome for backing up and spotting trailer without smoking clutch. Also awesome for cruising crap roads without binding everything up. Stoked for this. Makes sense for a MT truck
Re: 2wd Low Range
laramieskibum wrote:I have a g56. Just bought parts to do this on my own, now I have plug and play option. Awesome for backing up and spotting trailer without smoking clutch. Also awesome for cruising crap roads without binding everything up. Stoked for this. Makes sense for a MT truck
If you have a g56 i dont think this is going to work for you. Your front axle dosnt have a CAD does it?
Re: 2wd Low Range
A free spin kit would do the same thing if you don't have CAD, just costs more. But it provides other benefits.
- Bigskyguy1976
Re: 2wd Low Range
I had a land rover discovery that could do this. It was very handy for towing my 8000# boat on hills. Primarily to utilize braking though gear reduction and engine compression.
Curtis B.
Location (near) Butte, MT
2016 Power Wagon 6.4L Tradesman
2012 Power Wagon 5.7L SLT (sold)
2004 Land Rover Discovery (sold)
2000 Hummer H1 (sold)
Re: 2wd Low Range
Is there a free spin kit for the cad trucks? I hadn't seen one yet. Manual trucks still get the cad.
I like 2 low for towing even with an auto.
Main thing on this truck, I would use it to unlock the sway bar on rough trails with good traction.
- Trouble Maker
Re: 2wd Low Range
"Designed to allow the operator to manually disable the front wheel drive mechanism by holding the hubs in the free (2WD) mode with the transfer case in 4WD low range"
WHAT HUBS?
Not going to work on anything without cad yet they list 2009 and up. What a bunch of Maroons.
Black 09 purchased Dec 21/13
180K kms on the clock
Re: 2wd Low Range
Did you have a kit on your D2? My D1 could lock and unlock 4 high and 4 low. As for 2 low the advantage is when you are on tight trails. You still have the low gearing but no bind when making tight turns.Bigskyguy1976 wrote:I had a land rover discovery that could do this. It was very handy for towing my 8000# boat on hills. Primarily to utilize braking though gear reduction and engine compression.
Zane
Re: 2wd Low Range
I could certainly see where it would be handy for positioning trailers or towing heavy loads (like 2 grain wagons full, from the field to the farm, on the blacktop). Or hay wagons or equipment.
Re: 2wd Low Range
No. Read it again. 2500's are 14' and up. Damn MAROONS hahahaha.Trouble Maker wrote:"Designed to allow the operator to manually disable the front wheel drive mechanism by holding the hubs in the free (2WD) mode with the transfer case in 4WD low range"
WHAT HUBS?
The "hubs" part... yeah they effed up there. Should have said CAD.
Re: 2wd Low Range
They havnt offered a manual trans with a PW in years... and I am pretty sure it was back far enough before they had CAD too. Thats why I was saying I dont think it will work with his truck.ramv wrote:Is there a free spin kit for the cad trucks? I hadn't seen one yet. Manual trucks still get the cad.
- Trouble Maker
Re: 2wd Low Range
My mistake BUT I don't remember the 1500s of that vintage having the cad anymore either. It went away and stayed away for a long time on most mopar vehicles.olyelr wrote:No. Read it again. 2500's are 14' and up. Damn MAROONS hahahaha.Trouble Maker wrote:"Designed to allow the operator to manually disable the front wheel drive mechanism by holding the hubs in the free (2WD) mode with the transfer case in 4WD low range"
WHAT HUBS?
- Low_Sky
Re: 2wd Low Range
This. I can think of exactly the roads I would have loved to have this on back in Utah. I used to drive miles of rough, rocky roads, bone dry with great traction, limited to 10-15 mph by the lousy road conditions. Swaybar disco really smoothed the ride out, but 4WD was completely unnecessary.ramv wrote:Main thing on this truck, I would use it to unlock the sway bar on rough trails with good traction.
Re: 2wd Low Range
Need to update my signature. I have a 2014 2500 g56. Lurk here as we want a lot of the same things.olyelr wrote:They havnt offered a manual trans with a PW in years... and I am pretty sure it was back far enough before they had CAD too. Thats why I was saying I dont think it will work with his truck.ramv wrote:Is there a free spin kit for the cad trucks? I hadn't seen one yet. Manual trucks still get the cad.
I want a wagon but fuel range and towing at altitude pushed me to 6.7.
Re: 2wd Low Range
Yup. Perfect for the wagon owners. Aev was rumored to be looking at this. I bought a relay to do this on my own as it's super useful for what you describe.Low_Sky wrote:This. I can think of exactly the roads I would have loved to have this on back in Utah. I used to drive miles of rough, rocky roads, bone dry with great traction, limited to 10-15 mph by the lousy road conditions. Swaybar disco really smoothed the ride out, but 4WD was completely unnecessary.ramv wrote:Main thing on this truck, I would use it to unlock the sway bar on rough trails with good traction.
- MOPARManiac
Re: 2wd Low Range
My 47 and 58 Willys can do this.......
I used to feed cattle out of an old 50's International pickup. Would put in in 2wd low and hop in the back and scoop out the feed to the cattle. The old Binder would just crawl. Funny how things some of the first 4 wheel drive vehicles had and then disappeared are coming back again.
Re: 2wd Low Range
I have the free spin hubs. And I've done the unlocked front hubs and stuck the transfer case in 4Lo and drove like that for a while at work. Came in handy.
Re: 2wd Low Range
Not sure what you guys mean by disappeared & came back again. Manuals were avail for 2005-2008, w/Hemi, w/Power Wagon. I can still do that. 1st gear, Lo range, hop out & do what ever & hop back in. The advantage of having a 78:1 crawl ratio ! I would LOVE 2wd Lo range. For backing up my camper.
Manuals are STILL available but only with the CTD & the engine is de-tuned to around 610 lb ft of torque.
- MOPARManiac
Re: 2wd Low Range
So you were just in 1st gear and in 4-Lo......TwinStick wrote:Not sure what you guys mean by disappeared & came back again. Manuals were avail for 2005-2008, w/Hemi, w/Power Wagon. I can still do that. 1st gear, Lo range, hop out & do what ever & hop back in. The advantage of having a 78:1 crawl ratio ! I would LOVE 2wd Lo range. For backing up my camper.
I was referencing the old 4 wheel drives that had two levers. One for 2wd/4wd and one for low/high range.
Nevermind......
Re: 2wd Low Range
What's the difference if you are in 4lo. So long as you are not on pavement.
Re: 2wd Low Range
I assume many want 2Lo specifically for use on pavement.PWRider wrote:What's the difference if you are in 4lo. So long as you are not on pavement.
Re: 2wd Low Range
I'm still very unsure about this. I have never been in a situation where 4lo wouldn't work. If you truly need that much 2wd torque yore way over loaded. Like way way. If you need the pure traction and slow wheel speed then you use 4lo. I just can't see it being worth it. But that's my opinion. Can't think of any situation where 2lo would have ever been an advantage. Purely you would have little to no traction if your load requires that much power to move so you want the front wheel assist. Tho only think is a tighter turning radius. Just don't see value sry
