4-Wheel Drive Light
MOPARManiac
4-Wheel Drive Light
Post by MOPARManiac » Mon Apr 04, 2016 8:44 pm
Riddle me this Bat Man. I wanted to check my lockers out today after changing diff fluids/cleaning the magnets over the weekend. Everything worked fine until I went back to 2-Wheel Drive. Now when I am shifted in 2 Wheel Drive the light says I am in 4 HI, when I shift to 4-Hi the light goes off. When I am in Neutral the light says I am in 4-Low and when I am in 4-Low that is the only time the light is correct and says I am in 4-Low. The Service 4-Wheel Drive light also came on. I disconnected the battery and that went off but the 4-Wheel Drive lights are still wrong.
I don't think it is the smartbar because the lockers/sway bar are working correctly.
Any ideas?
Re: 4-Wheel Drive Light
Post by nts007 » Mon Apr 04, 2016 8:52 pm
T case position sensor buggy? It's what gives the resistance reading to the comp. it could be buggered. Easy to change. I don't know how to test it though aside from moving the tcase position and using a multi meter to directly read off the sensor
waldo
Model Year: 2019
Post by waldo » Mon Apr 04, 2016 8:54 pm
Yeah, T case position indicator most likely.
2007 and 2019 Power Wagons
MOPARManiac
Post by MOPARManiac » Mon Apr 04, 2016 8:58 pm
That's what I was wondering, is this located under the leather boot on the shifter or is it on the T-Case?
Thanks for the quick replies.
Post by RustyPW » Mon Apr 04, 2016 9:06 pm
You have to get to it from under the PW. It's located by the linkage.
MOPARManiac
Post by MOPARManiac » Mon Apr 04, 2016 9:07 pm
RustyPW wrote:You have to get to it from under the PW. It's located by the linkage.
Awesome, thanks I'll go take a look. I'm wondering if my linkage is maybe out of adjustment. I have to be in neutral to shift into 4 low.
MOPARManiac
Post by MOPARManiac » Mon Apr 04, 2016 9:51 pm
I went out, took the electrical connector off, unscrewed it, sprayed it down with brake cleaner and depressed the plunger several times, put it on and it works like it's supposed to. Crazy little electrical gremlin I guess.
Thanks for the advice, that's what I really like about this forum.
Post by coder » Mon Apr 04, 2016 9:56 pm
Here's a thread on the t-case position sensor everything you need to do the job:
http://forum.powerwagonregistry.org/vie ... sor#p41845
MOPARManiac
Post by MOPARManiac » Mon Apr 04, 2016 10:05 pm
coder wrote:Here's a thread on the t-case position sensor everything you need to do the job:
I remember reading that thread now, I was desperately searching for it and couldn't find it so started this thread. It is bookmarked, fortunately it doesn't look like I will have to replace it right now. It must have just got binded up and through a fit. All I did was go from the shop to the house around a 100 yards. Damn thing anyway.
Post by RustyPW » Mon Apr 04, 2016 10:11 pm
A little tip. Put dielectrical grease inside the plug. Help seals out the water.
Mule
Post by Mule » Tue Apr 05, 2016 1:15 am
Mine did the same till it shit out completely and the 4WD light just stayed on. It's the T-case position sensor.
MOPARManiac
Post by MOPARManiac » Tue Apr 05, 2016 9:56 pm
Yep, that's it. It worked fine yet today so hopefully I get some mileage out of it before I have to replace it.
Post by nts007 » Tue Apr 05, 2016 9:58 pm
Awesome to hear. I remember at one point a few guys were having problems with the sensor and then there was nobody having issues for quite some time. At least nobody was popping up.
MOPARManiac
Post by MOPARManiac » Thu Oct 05, 2017 7:17 pm
Word of advice.......when you have a problem with the Transfer Case position sensor go ahead and just change it. That or you can be on top of a mountain deer hunting a year and a half later and it completely dies. When it dies it also doesn't allow the smart bar to work and I was unable to engage the lockers when I really, really needed them.
Post by coder » Thu Oct 05, 2017 7:35 pm
waldo wrote:Yeah, T case position indicator most likely.
x2 that what it is...
Post by Retired BLM Rig » Sun Oct 08, 2017 12:32 am
One of the benefits of a locker bypass is TCPS override, so when the sensor goes belly up you can still get the lockers to work.
Glad you lived to tell about it! :rockon:
Post by Ducky's Dad » Sun Oct 08, 2017 12:47 pm
New sensor is about $84 from the dealer. My 4WD light stuck on last time I used the lockers, so I have a new sensor riding around with me until I can get around to changing it.
MOPARManiac
Post by MOPARManiac » Wed Oct 11, 2017 10:38 pm
Anyone building the locker bypass so I can buy one?
GunniPWguy
Post by GunniPWguy » Tue Oct 24, 2017 2:12 pm
Well this is a timely thread! I Just experienced the same exact scenario as MOPARmaniac. I disconnected my locker bypass and went back to stock to see if it was that. Nope. I will have to get back under there and replace the TCPS so I can hook my locker bypass back up and get rid of the 4wd light in 2wd feature. Thanks for the info as always! You guys rule!
