rust treatment?
radc
rust treatment?
Post by radc » Tue Feb 09, 2016 7:55 am
Hey northeast owners, or anywhere were rust is an issue - what are you guys using to protect your frames? I have some minor rusting, and want to wire brush as much as possible, but am on the fence on what to apply over top.
Re: rust treatment?
Post by Will » Tue Feb 09, 2016 8:59 am
Us folks in Florida love Corrosion X, we use it on anything and everything that gets close to the salt water. It's some awesome stuff. Not sure if you're looking for a more permanant solution but spraying a coat of this on it every now and again will definitely keep it from and stop it from rusting.
waldo
Model Year: 2019
Re: rust treatment?
Post by waldo » Tue Feb 09, 2016 9:47 am
I'm going to pull the bed on my 07 once the weather warms up this spring and do the frame. I'm thinking POR15 after blasting.
2007 and 2019 Power Wagons
GunniPWguy
Re: rust treatment?
Post by GunniPWguy » Tue Feb 09, 2016 10:23 am
I use Fluid Film for rust prevention and waterproofing undercarriage parts.
Limamikemike
Re: rust treatment?
Post by Limamikemike » Tue Feb 09, 2016 12:05 pm
Corrosion x or lps3 for waterproofing, POR15 or Chassis Saver for bare metal or rust
w2dodge
Re: rust treatment?
Post by w2dodge » Tue Feb 09, 2016 12:11 pm
Re: rust treatment?
Post by TwinStick » Tue Feb 09, 2016 12:38 pm
GunniPWguy wrote:I use Fluid Film for rust prevention and waterproofing undercarriage parts.
Re: rust treatment?
Post by RustyPW » Tue Feb 09, 2016 12:52 pm
When I got mine new. I had it Ziebert undercoated. Touch it up now with fluid film.
radc
Re: rust treatment?
Post by radc » Tue Feb 09, 2016 9:57 pm
Thanks for the responses - will definately be reading up on these.
Limamikemike wrote:Corrosion x or lps3 for waterproofing, POR15 or Chassis Saver for bare metal or rust
I was looking at the chassis saver previously as it can be applied over existing rust. Have you used it? If so how has it held up?
NovA ProspekT
Re: rust treatment?
Post by NovA ProspekT » Wed Feb 10, 2016 7:57 pm
I went with Fluid Film
I have had it a couple of months, so far so good.
If you have an air compressor, THIS kit is hard to beat. Includes everything you'll need to do your whole truck several times over.
The big advantage, to me, is that it can be sprayed pretty much anywhere(Rocker panels, door panels, inside of frame, inside of fenders, etc.). It will somewhat absorb into the metal, preventing corrosion. It will need to be touched-up every year, mainly on areas that are exposed to road-spray, or anywhere it can be rubbed off.
Mule
Re: rust treatment?
Post by Mule » Thu Feb 11, 2016 2:58 pm
Might check out "Chassis Saver" paint.
Expensive, at ~$100/gal, but supposedly real good.
We covered the new sled trailer in it, top-to-bottom.
Go light on the stuff - if you slap it on real heavy it'll bubble up and won't adhere well to the frame. A light coat, enough to cover everything, is all it needs.
And if you want it off, you'll need to get a grinder out.
Trailer needed some work when we got it, quite a bit of rust on the frame. Ended up replacing and welding in some additional support in some areas due to rust.
5 or 6 gallons to do the entire trailer... a truck shouldn't take more than 1gal.
leo72987
Re: rust treatment?
Post by leo72987 » Fri Feb 12, 2016 2:33 pm
I have used POR15 in the past alot of prep work!! But it held up great against the New England winters. Oh and wear gloves... I decided to be a dumb ass and didn't... Took WEEKS for it to come off my hands :lol:
