Post
by Reloaderguy » Mon May 16, 2016 11:17 pm
adeluca73 wrote:loveracing1988 wrote:
One small change, the pcm unlock is only required on 15 and newer trucks. If you have a 14 you are fine with just a tuner. If you do go that route when I changed mine it always said it failed but it actually did correct it. It even stayed corrected after I pulled my tuner off.
So what's your opinion on the best/cheapest route to go for speedo only vs. speedo & shift points?
Maybe this is relevant to your interests.
http://www.ramforumz.com/showthread.php?t=208722&page=2
Post
by adeluca73 » Mon May 16, 2016 11:53 pm
Yep thanks --as soon as I decided to re-gear, I read that whole thread, & about a 100 more like that over the last few weeks from CTD guys trying to recal for lifts, gears, tires.
So far, I hadn't noted a big shift point difference, at least not enough for me to run out & buy something to correct the PCM/ECM gear ratio until I decide on which & what size new tires.
Post
by Reloaderguy » Tue May 17, 2016 12:32 am
It's probably less of a concern for you. At some point I'm going to recalibrate but I have to prioritize projects right now.
Post
by OffroadTreks » Fri Jun 23, 2017 8:46 pm
So it seems AAM no longer makes the 4.88 R&P set at all. Your only two options are 4.88's from Yukon or Nitro gears. AAM still makes a 5.13 but only for the rear 11.5 axle. You will need aftermarket to go bigger up front on the 9.25. So the best from AAM you can really get is what we all have 4.10.
Post
by Colibri » Fri Jun 23, 2017 9:42 pm
Post
by Colibri » Fri Jun 23, 2017 10:02 pm
Google the part number and they're available. You use the gm/chevy front gear set with a ring gear spacer.
Post
by OffroadTreks » Fri Jun 23, 2017 10:34 pm
Ok, but that's not 4.88's it's 4.56. And still just the fronts.
Post
by Colibri » Fri Jun 23, 2017 10:55 pm
I'm sorry, I remembered you saying in another thread you were going 5.13 and 40's so I thought you were looking for aam 5.13's which are available. Brain fart on my end, I know nothing about 4.88's. But if you're contemplating regearing for 37's or 40's you're much better off with the 5.13 ratio. I have trucks with both and the lower geared truck is better in every way. I'm not trolling you or anything, legit trying to help out.
Post
by OffroadTreks » Sat Jun 24, 2017 11:03 am
Yeah,I know 5.13's are out there. I wanted to update this thread on the 4.88 because it seems like they were offering it. USMC and adeluca73 both mention buying AAM 4.88 gears. And now I can't find them. Anywhere. Seems like the current offerings are just aftermarket.
Also on the newer 2014+ trucks the only known programmer that will change gears you can buy now is the AEV ProCal. But it only goes up to 4.88's. So that is something to be aware of. If there is another programer out there, someone post up.
But the AEV is a much cheaper investment.
OffroadTreks on Sat Jun 24, 2017 12:03 pm, edited 1 time in total.
Post
by Reloaderguy » Sat Jun 24, 2017 12:02 pm
MikeKey wrote:Yea I know 5.13 out there. I wanted to update this thread on the 4.88 because it seems like they were offering it. And now I can't find them.
I've heard reprogramming for gears is unimportant, have you heard differently?
Post
by OffroadTreks » Sat Jun 24, 2017 12:04 pm
I've heard the complete opposite.
Post
by Reloaderguy » Sat Jun 24, 2017 12:16 pm
Tell me what I'm missing? What does it do? Apparently shift and mileage is controlled by the wheel sensor calibration. Several RAM techs have commented on CF that it doesn't do anything now that there are more wheel sensors. Older generations were not the case and needed gear ratio updates.
Post
by DamageWagon » Sat Jun 24, 2017 1:18 pm
Does the Diablo tuner not have the ability to change gears on the new trucks like it did the old trucks?
Pit Slave
Post
by Pit Slave » Sat Jun 24, 2017 3:04 pm
this is good...
Post
by DamageWagon » Sat Jun 24, 2017 3:23 pm
It's amazing you stay so thin with all the popcorn you've been consuming lately
Post
by OffroadTreks » Sat Jun 24, 2017 6:28 pm
I don't read CF, just ramforums and the FB group, so maybe I'm wrong. I was under the impression that you still needed to adjust the computer for the gearing. The comments were about it still being related to the transmission and that the patterns aren't just tire size, but gear specific. ¯\_(ツ)_/¯ But if the shift is based on wheel sensor, and that seems the case for tire size why then even offer gear programming if it doesn't matter?
Has to be a reason. I just don't know it. But if you're saying dozens of techs told you that then ¯\_(ツ)_/¯
Pit Slave
Post
by Pit Slave » Sat Jun 24, 2017 6:30 pm
Sometimes it's hard to tell the difference between fake and real snake oil.
Post
by OffroadTreks » Sat Jun 24, 2017 6:49 pm
Right after tire settings.
Pit Slave
Post
by Pit Slave » Sat Jun 24, 2017 7:16 pm
Looks to me like they're just intercepting the pulse counter and changing the calculated pulse count to compensate for the difference in gearing. What's options setting?
Post
by Bill2014 » Sat Jun 24, 2017 7:45 pm
Setting both the gears and tire size will give the computer the final drive ratio...
Post
by Reloaderguy » Sat Jun 24, 2017 8:03 pm
Bill2014 wrote:Setting both the gears and tire size will give the computer the final drive ratio...
The truck already has that information based on RPM, transmission gear selection, wheel speed, and tire calibration. The gear ratio is redundant.
Post
by nts007 » Sat Jun 24, 2017 8:10 pm
Reloaderguy is right. Resetting for gear ratio is pointless. Tire size adjustment does exactly the same thing. Re interprets the wheel speed sensor. Transmissions are programmed on wheel speed and rpm. Not gear ratio. It doesn't care what the gear ratio is. If it wants to know it can take wheel speed/rpm/trans gear and call it a day. This is another snake oil aev mumbojumbo
Post
by Bill2014 » Sat Jun 24, 2017 8:41 pm
It all depends on which inputs the coder used when they set up maps for shifting and other controlled features. Sure there's lots of redundant sensors in modern vehicles... and there are different ways to calculate the same values - based on these different sensors.
If you have the option to set gear ratio - there's no sensible reason not to do it. Chances are, there is something in the controller logic that will use it.
Post
by Reloaderguy » Sat Jun 24, 2017 9:09 pm
If I'm not mistaken it is a holdover setting from older generation trucks that had a single rear wheel speed sensor mounted to the axle center. The newest (best) generation trucks have two rear wheel speed sensors on the ends of the axle. Again, the older gen needed the axle ratio because it was measuring input speed into the axle instead of output wheel speed.
Again, this is how I understand it and breakdowns for new trucks seem to support it.
