37s
Re: 37s
Post by nts007 » Thu Jul 02, 2015 11:54 am
So where's your 37's! I'm working mine till they die. Have a set on hold with deposit now. Safer than wanting and not being able to get
2011TXPowerWagon
Re: 37s
Post by 2011TXPowerWagon » Thu Jul 02, 2015 12:09 pm
Mine are still on back order, or so they say. I am beginning to think I am going to get screwed over...ordered them on May 20th. I am stuck between a rock and a hard place. I don't want to push to hard and lose the deal but I am starting to think maybe just suck it up and buy elsewhere..
Re: 37s
Post by nts007 » Thu Jul 02, 2015 1:51 pm
2011TXPowerWagon wrote:Mine are still on back order, or so they say. I am beginning to think I am going to get screwed over...ordered them on May 20th. I am stuck between a rock and a hard place. I don't want to push to hard and lose the deal but I am starting to think maybe just suck it up and buy elsewhere..
It wouldn't hurt to call around.
2011TXPowerWagon
Re: 37s
Post by 2011TXPowerWagon » Thu Jul 02, 2015 1:57 pm
I have and everyone tells me the same. 4-6 weeks out still. :angry: :angry: :angry: :angry:
Re: 37s
Post by nts007 » Thu Jul 02, 2015 2:58 pm
That sucks. I could order you a set here. But shipping would suck
stubiePW
Re: 37s
Post by stubiePW » Thu Jul 02, 2015 11:20 pm
Tire store called today. I'll be getting them installed tomorrow after I finish putting the control arms on
Re: 37s
Post by nts007 » Thu Jul 02, 2015 11:24 pm
Awesome!! Pictures pictures pictures!!
2011TXPowerWagon
Re: 37s
Post by 2011TXPowerWagon » Fri Jul 03, 2015 9:48 am
stubiePW wrote:Tire store called today. I'll be getting them installed tomorrow after I finish putting the control arms on
Did you lift it at all? or just the control arms?
stubiePW
Re: 37s
Post by stubiePW » Fri Jul 03, 2015 12:28 pm
Just control arms. No lift so I'll see how this goes. They look huge, but I'm excited. No turning back now
stubiePW
Re: 37s
Post by stubiePW » Fri Jul 03, 2015 2:17 pm
So here they are guys. I think the really make the truck look good. I have some rubbing on the upper contol arm on both sides at full lock and some of the driver rear fender line (cut). I am also rubbing a little on the sway bar on both sides at full lock. It flexes great no rubbing from what I've seen
The tires are quiet and behave well for only driving 18 miles
stubiePW
Re: 37s
Post by stubiePW » Fri Jul 03, 2015 2:18 pm
Also the second to last pic is full articulation
w2dodge
Re: 37s
Post by w2dodge » Fri Jul 03, 2015 2:35 pm
Nice...those tires don't look too wide..I like that
...give us update on how they perform...
Mr.Smith
Re: 37s
Post by Mr.Smith » Fri Jul 03, 2015 2:36 pm
Nice! Well done Sir! Definitely want to try these after my MTs wear out. What load ranges are available? D...E...???
stubiePW
Re: 37s
Post by stubiePW » Fri Jul 03, 2015 2:40 pm
In a35 I believe you can get D and E. 37 are D only
2011TXPowerWagon
Re: 37s
Post by 2011TXPowerWagon » Fri Jul 03, 2015 2:57 pm
:rockon: :rockon: :rockon:
Mr.Smith
Re: 37s
Post by Mr.Smith » Fri Jul 03, 2015 3:39 pm
Haha! Now I remember someone saying this same thing, thank you!
Re: 37s
Post by nts007 » Fri Jul 03, 2015 6:29 pm
Beautiful!! Sticking with stock rims they fit perfectly. They don't look stupid sticking out and you can use them!! You get used to the rubbing. It only takes one look over and down at the 6" lifted Chevy on 33's beside you to make you forget the rubbing...
stubiePW
Re: 37s
Post by stubiePW » Fri Jul 03, 2015 7:13 pm
Yea. I have to get used to not turning full lock, but that's easy. I have to pull back the liner a bit on the front driver side but so fat I love these tires. I also updated my intune for 37s.
Bluchalk
Re: 37s
Post by Bluchalk » Sat Jul 04, 2015 9:58 pm
Nice lookin truck... :rockon:
I'm partial to the color. :cheers:
With Thuren diesel coils and his track bar you will only rub on right side sway bar at full lock.
DT Pro Fab sway bar end links
Rugged Ridge floor mats
AMP bed step
37" Toyo RT's
stubiePW
Re: 37s
Post by stubiePW » Sat Jul 04, 2015 10:30 pm
Hmmm. Gears are turning. And thanks. I really like the 37s so far
Re: 37s
Post by 2wagons1driveway » Sun Jul 05, 2015 12:15 pm
Of just ditch the bar and get a Thuren fab swaybar. Image move your module to around the airbox. So your lockers still work this brings the module up and out if harms way so no more water ingress issues.... Looks awsome man ImageImageImagewe just finished kens truck with 3" overland set up. Pretty swayey with no swaybar and the moderately valved overland shocks but rides awsome on the highway. Used his level shackles to give it a good stance
"Escalators are never really broken...their just stairs for alittle while... "
SnakeEyes
Re: 37s
Post by SnakeEyes » Sun Jul 05, 2015 12:49 pm
How much lift was involved to fit those tires?
stubiePW
Re: 37s
Post by stubiePW » Sun Jul 05, 2015 1:30 pm
My tires? None. I'm running stock
Jack187
Re: 37s
Post by Jack187 » Sun Jul 05, 2015 2:33 pm
stubiePW wrote:My tires? None. I'm running stock
Did the tire dealer give you any flack about putting those 37" tires on 8" wheels?
I've been wanting to run certain 35" inch tires on my factory rims but they always start at 8.5" minimum rim width.
stubiePW
Re: 37s
Post by stubiePW » Sun Jul 05, 2015 4:08 pm
No flack at all. They put them on without question.
