2013 Rear End
2013 Rear End
Are these holes in the rear end center section supposed to have welds in them?
2012 PW - gone
2005 PW - gone
'03 Kawasaki Prairie 650
2012 PW - gone
2005 PW - gone
Re: 2013 Rear End
Yea. The axle tubes are pressed into the dif. And then they are plug welded.
It the right situation, you can break the welds and soin the dif up........ Don't ask me how I know that!!! Lol
2006 Power Wagon. "Stockish"
Re: 2013 Rear End
This was a factory order and they are not welded. Wonder if I should take it to dealer?
2012 PW - gone
2005 PW - gone
2012 PW - gone
2005 PW - gone
Re: 2013 Rear End
The plugs can come out if it's unpainted inside the hole I bet that's what happenen.
Re: 2013 Rear End
Those holes are for what is called a coconut spreader. It's a tool that has dowel pins that fits into those holes. Used for assembly.
Re: 2013 Rear End
Thanks, that makes sense!RustyPW wrote:Those holes are for what is called a coconut spreader. It's a tool that has dowel pins that fits into those holes. Used for assembly.
2012 PW - gone
2005 PW - gone
2012 PW - gone
2005 PW - gone
Re: 2013 Rear End
- diff spreader.jpg (15.34 KiB) Viewed 2121 times
