Off and On Road Lights
scoutermike
Re: Rigid Dually Fog assembly
Post by scoutermike » Wed Sep 14, 2016 7:35 pm
joshet89 wrote:There was someone asking about if any one has installed the rigid dually fog light bracket. I installed the brackets and 2 sets of duallys (1 set of spot and 1 set of flood) on my 2013 and then removed and re-installed on my 2014 as well. I have been very happy with them and use them on my commute home from work which is mostly dark county roads and almost always driven after dark, at least that is what it feels like this time of year :angry: . The install was very easy and took less than an hour. I wanted to make sure they worked with the factory fog light switch so I purchased a fog light extension so I could solder the 2 connectors from the duallys to the extension and then just plug the whole assembly into the factory plug. The extension I purchased needed some extra water proofing so I put liquid electrical tape around the back of the wires going into the plastic housing. When attaching the duallys to the bracket I installed the spot on the inner part of the bracket and the floods on the outer part. I had marked my factory fog light beams on my garage door and made sure the spots where a little below the factory spots and have very even and wide disbursement.
Where did you buy the fog light extension?
Many thanks in advance,
Mike
scoutermike
Re: Off and On Road Lights
Post by scoutermike » Wed Sep 14, 2016 9:41 pm
FOUND IT. 8lugperformance.com
scoutermike
Post by scoutermike » Thu Nov 10, 2016 8:25 am
Bought them from 8lig and they work for about 2 seconds before the CANBUS shuts them down. That's on my 2016. Earlier models might work.
Post by olyelr » Thu Nov 10, 2016 6:13 pm
scoutermike wrote:Bought them from 8lig and they work for about 2 seconds before the CANBUS shuts them down. That's on my 2016. Earlier models might work.
Well dang.
Explorin Sonoran
Post by Explorin Sonoran » Mon Dec 19, 2016 4:37 pm
Threw this light bar on the other day. Just an ebay special, $150.00 240w. I like it because it is low profile and has a dark finish to it. Seems to put out decent light. I still need time to dial in the angle.
Test Fitting
Mounted
Just brights
Brights and bar
2016 Power Wagon Tradesman Granite Crystal Metallic
Spikethedog
Post by Spikethedog » Sun Feb 05, 2017 7:06 pm
Heres my setup, cheapest 52" curved i could find on amazon. Mounted in my own made brakets (1/8" steel plate)
Then i realised it was stupid and useless cause it would glare so much inside thru the windshield on the dash. So I thought about solutions for a while and a simple glareshield deal right under the light is what i ended up doing. I like the look of it, poeple tell me it reminds them of the old school visor that guys would put above their windshields. And it works perfect, no more glare inside whatsoever!
Post by Colibri » Sun Feb 05, 2017 9:13 pm
Nice job!
NovA ProspekT
Post by NovA ProspekT » Wed Feb 08, 2017 1:28 am
Looks great man!
I like how low the light bar sits, every set of brackets I've found online sets the light bar up high enough to block the roof marker lights.
| 2007 Dodge Power Wagon |
Flame Red - 5.7L Hemi V8 - COOPER S/T MAXX(37x12.5R17)
Aluminess Front Bumper - Back Rack w/ Side-rails - Truxedo LoPro QT Tonneau Cover
Carli High Clearance Control Arms - Carli HD Ball-joints - Stock suspension
JW Speaker TS4000 Driving Lights - Grote 30" LED Off-road Light Bar - Bosch Compact 100 Fog Lights
| 2004 Jeep Grand Cherokee Overland |
Inferno Red - 4.7L High Output PowerTech V8 - Quadra-Drive - 17" Rubicon Hard Rock wheels
1.5" Lift OME HD Coil Springs - Bilstein 5100 Shocks - JKS HD Trackbar
| 1998 Jeep Grand Cherokee 5.9 Limited |
Deep Slate - 5.9L Magnum R/T V8 - Quadra-Trac - 1.5" Lift OME HD Coil Springs - Bilstein 5100 Shocks
Doug Thorley Tri-Y Long-tube headers - MOPAR M1 Intake - BBK Power Plus twin 52mm Throttle Body
[ My Flickr ]
Spikethedog
Post by Spikethedog » Sun Feb 12, 2017 10:31 pm
Thanks man! Yeah that bothers me too about all the brackets ives seen on the market, you might be able to install them at the height you want im not sure.. i wanted to see the marker lights and also i only have a few inches between my roof and the top of my garage door so i couldn't put it up above
Post by TwinStick » Tue Mar 07, 2017 8:02 pm
Curious if anyone has any experience with AUXBEAM LED bars ? https://www.auxbeam.com/?gclid=CMjWy4ra ... swodLcIHHw
Everything I have read on the "cheaper" light bars seems to be the same. Buy them new. Get them. Take them apart. Silicone backside of plastic lens so no condensation occurs. I'm liking the 54" curved light bar w/spot-flood combo. https://www.auxbeam.com/led-light-bars/ ... s/70019592
votedave
Post by votedave » Mon Mar 27, 2017 12:50 am
04Ram2500Hemi wrote:Four Vision X Lights mounted behind the front grill out front, and in the back I have flush mounted LED lights in the rear bumper. I never seem to get good night pictures, but I'll try again and update the post down the road.
I absolutely love the look of your bumpers and grill sprayed with Linex!! I'm thinking of doing the same to my 2012 PW SL. Is it expensive and if you could, would you do it over again (how is it holding up over time)?
Post by nts007 » Sun Apr 02, 2017 8:03 pm
For anyone with over the windshield led bars take notes!!!
Post by olyelr » Sun Apr 02, 2017 8:35 pm
Lmao!
StormRider
Post by StormRider » Mon Apr 03, 2017 9:47 pm
Reminds me of the welcome wagon from Independence Day
Post by nts007 » Tue Apr 04, 2017 11:27 pm
The welcome wagon array had a more usable beam pattern with less hood glare
Post by TwinStick » Fri Jun 09, 2017 7:10 pm
Finally placed my order to Auxbeam. 2 of these for the A-pillar lights: https://www.auxbeam.com/driving-light/77704267 . And 1 of these: https://www.auxbeam.com/led-light-bars/ ... d%20Bar%5D for the bumper.
Post by FirerescuePW » Fri Jun 09, 2017 9:54 pm
Anyone looking for lights may want to watch Pitslave. His new company is releasing their first round of off road lights soon.
Post by DamageWagon » Fri Jun 09, 2017 10:38 pm
So it's not just a DTX release huh? :poke:
Post by FirerescuePW » Sat Jun 10, 2017 4:50 pm
Oh, I left out the part about joining DTX...
Post by TwinStick » Sat Jun 10, 2017 7:23 pm
Does his company have a website ?
2011bigred
Post by 2011bigred » Tue Jul 11, 2017 6:26 pm
2wagons1driveway wrote:Nice! I'm happy with those comb-flood spot sanmak LED 42" bar. The outter two ambers are on a seperate circuit for really dusty or foggy times the thing (centre section of white LEDs ) is crazy bright
Way brighter than my entire china dual row 40" bar.
Sent from Canada
Lee where did you get your light bar
Post by 04Ram2500Hemi » Wed Jul 12, 2017 9:31 am
Sorry for the late response- my account is goofy and won't let me post pictures so I don't visit much anymore. With that said, the Line-X on the bumpers and the grill (as well as the rockers and my headache rack) are holding up great. I think each bumper was around $250 and the grill was $200, so not cheap, but not oober expensive. I was just getting tired of having to spend hours each spring on my bumpers and grill after a long winter. If I was buying a new truck today it would be one of my first mods.
kidney514
Post by kidney514 » Tue Aug 15, 2017 12:34 am
Here is my install
And video of the result
phpBB [video]
Clickable link for Tapatalk
StubbleJumper
Post by StubbleJumper » Sun Sep 03, 2017 2:22 pm
Anyone have more pics of off-road lights on a 2017? Just starting to look around for ideas, would like some to light up the ditches to watch for bambi.
On car id they have some hinge mounts, anyone use these? Or have any input?
https://www.carid.com/2017-ram-2500-off ... on#reviews
Rodeoflyer
Post by Rodeoflyer » Sun Sep 10, 2017 1:35 pm
There are several guys on here running the sdhq pillar lights. My truck is a '16 but I have four rigid d2 driving hi/lows in the stock fog light location I can use onroad on low setting providing major extra coverage out to the sides of the road for deer spotting. Not to mention the pack of pigs that ran out in front of me even with the lights. If an animal or packs running full blast lights won't really save you. If I slow way down it gives me a degree of extra time to react. The behind the grill lights are rigid r46 round spot/hyperspot I picked up on sale for $200 for the pair. I can't even describe the range they provide. I'm guessing a good 1/4 mile if not more.
https://i.imgur.com/a8rDPva.jpg
