Board index General Power Wagon Talk
Re: Rigid Dually Fog assembly
Postby scoutermike » Wed Sep 14, 2016 5:35 pm
joshet89 wrote:There was someone asking about if any one has installed the rigid dually fog light bracket. I installed the brackets and 2 sets of duallys (1 set of spot and 1 set of flood) on my 2013 and then removed and re-installed on my 2014 as well. I have been very happy with them and use them on my commute home from work which is mostly dark county roads and almost always driven after dark, at least that is what it feels like this time of year :angry: . The install was very easy and took less than an hour. I wanted to make sure they worked with the factory fog light switch so I purchased a fog light extension so I could solder the 2 connectors from the duallys to the extension and then just plug the whole assembly into the factory plug. The extension I purchased needed some extra water proofing so I put liquid electrical tape around the back of the wires going into the plastic housing. When attaching the duallys to the bracket I installed the spot on the inner part of the bracket and the floods on the outer part. I had marked my factory fog light beams on my garage door and made sure the spots where a little below the factory spots and have very even and wide disbursement.
Where did you buy the fog light extension?
Many thanks in advance,
Mike
scoutermike
Re: Off and On Road Lights
Postby scoutermike » Wed Sep 14, 2016 7:41 pm
FOUND IT. 8lugperformance.com
scoutermike
Postby scoutermike » Thu Nov 10, 2016 7:25 am
Bought them from 8lig and they work for about 2 seconds before the CANBUS shuts them down. That's on my 2016. Earlier models might work.
scoutermike
Postby olyelr » Thu Nov 10, 2016 5:13 pm
scoutermike wrote:Bought them from 8lig and they work for about 2 seconds before the CANBUS shuts them down. That's on my 2016. Earlier models might work.
Well dang.
Postby Explorin Sonoran » Mon Dec 19, 2016 3:37 pm
Threw this light bar on the other day. Just an ebay special, $150.00 240w. I like it because it is low profile and has a dark finish to it. Seems to put out decent light. I still need time to dial in the angle.
Test Fitting
Mounted
Just brights
Brights and bar
2016 Power Wagon Tradesman Granite Crystal Metallic
Explorin Sonoran
Postby Spikethedog » Sun Feb 05, 2017 6:06 pm
Heres my setup, cheapest 52" curved i could find on amazon. Mounted in my own made brakets (1/8" steel plate)
Then i realised it was stupid and useless cause it would glare so much inside thru the windshield on the dash. So I thought about solutions for a while and a simple glareshield deal right under the light is what i ended up doing. I like the look of it, poeple tell me it reminds them of the old school visor that guys would put above their windshields. And it works perfect, no more glare inside whatsoever!
Spikethedog
Postby Colibri » Sun Feb 05, 2017 8:13 pm
Nice job!
Postby NovA ProspekT » Wed Feb 08, 2017 12:28 am
Looks great man!
I like how low the light bar sits, every set of brackets I've found online sets the light bar up high enough to block the roof marker lights.
-------- 2007 Dodge Power Wagon | Vengeance --------
- Cooper S/T MAXX 37x12.5R17 | Carli Ball Joints
- Uniden Bearcat 980SSB CB Radio | 4-ft. Firestik Red, White & Blue CB antenna | PA Speaker
- Factory REC Radio W/ PAC iSimple Aux. Input Interface
- BackRack Original Rack | BackRack Siderails | Truxedo Lo Pro QT Tonneau Cover | Pop N Lock Tailgate Lock
- White Knuckle Offroad Rock Sliders | Aluminess Front Bumper | Carli Front Diff. Guard
- Spintech Super Pro Street 9000 Muffler | QTP E-Cutout
- Bosch Compact 100 Fog Lights | J.W. Speaker TS4000 LED Driving Lights
- Grote 30" Off-Road LED Light Bar | Grote BriteZone Slim Rear Work Lights
- ARB CKMTA12 Twin air-compressor w/2.5gal. tank
My build - My Flickr
Freedom is the miles I'm rolling on...
NovA ProspekT
Postby Spikethedog » Sun Feb 12, 2017 9:31 pm
Thanks man! Yeah that bothers me too about all the brackets ives seen on the market, you might be able to install them at the height you want im not sure.. i wanted to see the marker lights and also i only have a few inches between my roof and the top of my garage door so i couldn't put it up above
Spikethedog
Postby TwinStick » Tue Mar 07, 2017 7:02 pm
Curious if anyone has any experience with AUXBEAM LED bars ? https://www.auxbeam.com/?gclid=CMjWy4ra ... swodLcIHHw
Everything I have read on the "cheaper" light bars seems to be the same. Buy them new. Get them. Take them apart. Silicone backside of plastic lens so no condensation occurs. I'm liking the 54" curved light bar w/spot-flood combo. https://www.auxbeam.com/led-light-bars/ ... s/70019592
Postby votedave » Sun Mar 26, 2017 10:50 pm
04Ram2500Hemi wrote:Four Vision X Lights mounted behind the front grill out front, and in the back I have flush mounted LED lights in the rear bumper. I never seem to get good night pictures, but I'll try again and update the post down the road.
I absolutely love the look of your bumpers and grill sprayed with Linex!! I'm thinking of doing the same to my 2012 PW SL. Is it expensive and if you could, would you do it over again (how is it holding up over time)?
votedave
Postby nts007 » Sun Apr 02, 2017 6:03 pm
For anyone with over the windshield led bars take notes!!!
08 ctd--mini max--thuren 3" coils and shackles--4.56 gears and lockers in pw axles--some lights--afe intake system--bd super b turbo--Banks w/m Injection--Dynatrac Balljoints--bilstein 7100s--37" Nitto trail grapplers--DOR Long arms--Custom emf track bar--Manual T-case swap--Full PW Under armor--PSC Hydro Assist
Postby olyelr » Sun Apr 02, 2017 6:35 pm
Lmao!
Postby StormRider » Mon Apr 03, 2017 7:47 pm
Reminds me of the welcome wagon from Independence Day
StormRider
Postby nts007 » Tue Apr 04, 2017 9:27 pm
The welcome wagon array had a more usable beam pattern with less hood glare
Postby TwinStick » Fri Jun 09, 2017 5:10 pm
Finally placed my order to Auxbeam. 2 of these for the A-pillar lights: https://www.auxbeam.com/driving-light/77704267 . And 1 of these: https://www.auxbeam.com/led-light-bars/ ... d%20Bar%5D for the bumper.
Postby FirerescuePW » Fri Jun 09, 2017 7:54 pm
Anyone looking for lights may want to watch Pitslave. His new company is releasing their first round of off road lights soon.
Postby DamageWagon » Fri Jun 09, 2017 8:38 pm
So it's not just a DTX release huh? :poke:
Postby FirerescuePW » Sat Jun 10, 2017 2:50 pm
Oh, I left out the part about joining DTX...
Postby TwinStick » Sat Jun 10, 2017 5:23 pm
Does his company have a website ?
Postby 2011bigred » Tue Jul 11, 2017 4:26 pm
2wagons1driveway wrote:Nice! I'm happy with those comb-flood spot sanmak LED 42" bar. The outter two ambers are on a seperate circuit for really dusty or foggy times the thing (centre section of white LEDs ) is crazy bright
Way brighter than my entire china dual row 40" bar.
Sent from Canada
Lee where did you get your light bar
2011bigred
Postby 04Ram2500Hemi » Wed Jul 12, 2017 7:31 am
Sorry for the late response- my account is goofy and won't let me post pictures so I don't visit much anymore. With that said, the Line-X on the bumpers and the grill (as well as the rockers and my headache rack) are holding up great. I think each bumper was around $250 and the grill was $200, so not cheap, but not oober expensive. I was just getting tired of having to spend hours each spring on my bumpers and grill after a long winter. If I was buying a new truck today it would be one of my first mods.
Previous
Return to Power Wagon Talk
Who is online
Users browsing this forum: Google [Bot] and 5 guests
