Tire Feedback
Re: Tire Feedback
Post by olyelr » Sat Nov 25, 2017 11:39 am
Also, where ya got the spare tire?
Laramiewagon14
Re: Tire Feedback
Post by Laramiewagon14 » Sat Nov 25, 2017 11:53 am
Sat Nov 25, 2017 9:01 am
:rockon:
Do they measure 36” with the truck on them, or 36” before they are installed on the truck?
Depending on air pressure, I think it is pretty normal for a tire to loose an inch in height with an 8000 pound truck sitting on them.
My 35” bfg’s measured 33.5” with the jeep on them, but were more like 34.25” before they were mounted (still quite undersized in my mind).
36” under the weight of the truck sorry for the confusion
Right now includes at 50 psi front 45 rear
2014 Laramie PW died '16
17+ PW grille
Laramiewagon14
Re: Tire Feedback
Post by Laramiewagon14 » Sat Nov 25, 2017 11:55 am
Strapped under the tonneau to the front tie downs
17+ PW grille
Laramiewagon14
Yokohama UPDATE
Post by Laramiewagon14 » Sat Nov 25, 2017 2:05 pm
So I got on the interstate today hit 65 front end starts shaking like hell. Rode to the mall where the wife wanted to shop and pulled into sears.
Guys hooked me up. Removed the bead balancing shit and balanced the tires. 3 of the tires took 4oz. The 4th took 4.5oz. Rides like butter now at highway speed. No vibe in the steering wheel.
17+ PW grille
Re: Tire Feedback
Post by nts007 » Sun Nov 26, 2017 10:01 am
Whew!! Happy to hear you got them properly balanced. I argue with so many people about beads I gave up. Lots of shops try to do it but always say no.
There are some tires that just won't balance well at all
IIIOIISTER
Re: Tire Feedback
Post by IIIOIISTER » Sun Nov 26, 2017 10:47 am
Great looking Yokos! What axle ratio are you running? 4.10?
'17 Power Wagon
35" Yokohama Geolander G003
Carli
-King 2.5 Pintop
-3” coils
-Front diff cover
Thuren
-Rear track bar
-Rear sway bar links
-King steering damper
Laramiewagon14
Re: Tire Feedback
Post by Laramiewagon14 » Sun Nov 26, 2017 2:46 pm
Factory 4.10’s still. Not a huge change in felt acceleration however it is Procal’ed and I have a pedal commander
17+ PW grille
Re: Tire Feedback
Post by olyelr » Sun Nov 26, 2017 4:39 pm
Wth is a pedal commander?
Laramiewagon14
Re: Tire Feedback
Post by Laramiewagon14 » Mon Nov 27, 2017 8:00 am
https://www.pedalcommander.com
It’s a throttle response programmer that removes the electronic pedal lag you plug it in between you pedal and the computer under the dash. I got a hell of a deal on one so I figured I’d try it. It has multiple settings under different driving options. From economy to sport +, I run mine in sport setting 2/4 I tried the sport plus but I tend to spin the tires more than I wanted so I backed it off to the next level down.
When you bring it to the dealer you turn it off and it doesn’t appear with the scan tool
17+ PW grille
Re: Tire Feedback
Post by olyelr » Mon Nov 27, 2017 10:10 am
Wow, interesting. I will have to check it out.
Re: Tire Feedback
Post by DamageWagon » Mon Nov 27, 2017 12:19 pm
It is an expensive device that replicates you moving your toe about 1/2" farther. Just buy a damn tuner that modifies trans behavior and actually helps your engine if you're going to the spend money.
Laramiewagon14
Re: Tire Feedback
Post by Laramiewagon14 » Mon Nov 27, 2017 8:42 pm
Depending on the price you pay it could be expensive, mine wasn’t to bad and at the time I couldn’t afford a full on programmer. It does what it’s meant to do. One day I’ll get a programmer. But so far I haven’t found one I’m totaly in love with. While we’re off topic what do you recommend as far as a full on tuner.
17+ PW grille
Re: Tire Feedback
Post by DamageWagon » Mon Nov 27, 2017 9:41 pm
I can't recommend anything for the newer trucks. I've never run a tuner. I'll be getting a DiabloSport for my 11' so I can tune the trans and torque management. I have heard it makes a big difference in the bottom and mid on the 5.7 which is where it needs the most help right now. I need to tune the trans before I smoke it, these soft shifts are terrible on the clutch packs off-road at speed.
Laramiewagon14
Re: Tire Feedback
Post by Laramiewagon14 » Fri Dec 08, 2017 7:01 pm
Did some trail riding today with the munchkin. Tires dig really well did 2 water crossings some icy frozen patches and some dirt trail climbing. No issues at all no slipping still want to do some further testing but since it’s muzzleloader season I couldn’t get down the trails without interfering with the hunters.
He was all smiles crossing the water. But wouldn’t put his fish down.
Photobomber extraordinaire
17+ PW grille
Re: Tire Feedback
Post by olyelr » Fri Dec 08, 2017 8:29 pm
Like me, you must have got the laramie because of the interior... its quite obvious you didnt want the exterior of the laramie :lol:
Laramiewagon14
Re: Tire Feedback
Post by Laramiewagon14 » Fri Dec 08, 2017 9:22 pm
Exactly, not a huge chrome fan. But the interior package gave me all the heated options that help with long rides and bad days. Don’t want to have to give up driving a truck and wheeling because I got all busted up. Plus all the conveniences are nice.
17+ PW grille
HammerTime
Re: Tire Feedback
Post by HammerTime » Tue Dec 19, 2017 2:30 am
Had 315/70R17" ProComp MT2s put on my truck a few weeks ago. Have not did a lot of wheeling with them yet, but have towed my boat about 100 miles and they felt fine. They have done very well during the little off roading I have gotten in. So far, after about 750 miles, they get a thumbs up. Oh, and no rubbing turn-to-turn or during the mild 4x4ing I've done.
My other babe is a Black 392 Scat Pack Challenger, and it is a major pain to keep clean living in the desert! But it's so worth if for about 2 hours after I wash it.... LOL!
:cheers:
2017 White/Black Power Wagon
The Avatar is my previous 2013 Power Wagon. I also had a White 2010 Power Wagon.... :D
Re: Tire Feedback
Post by olyelr » Tue Dec 19, 2017 5:45 pm
:cheers:
:rockon:
My friend has 40” mt2’s on his jeep and they seem to do phenomenal in just about everything. Only issues we have come across is cutting them while up in Canada in some severely rocky terrain.
DocPaulo
Re: Tire Feedback
Post by DocPaulo » Wed Dec 20, 2017 11:03 pm
Just put on falken wildpeak at3w in 315.70.17
so far so good... no rubbing... nice tread profile... no offroad yet
Auxbeam 42 curved lightbar
RANCHO 9000XL suspension
EMF ball joints
HammerTime
Re: Tire Feedback
Post by HammerTime » Sun Dec 24, 2017 11:44 pm
I almost went with the Falken MTs but I caught a really good deal for the ProComp MTs and ran with it. $1200 installed with 40K road hazard warranty. So far, so good. If I don't get the same type deal again, I'll be giving the Falkens a shot next time around! Let us know how they do for you! Towed the boat to the bay this morning and I enjoyed the MT hum there and back again! LOL! On another note, have I mentioned that San Diego is an awesome place to live?! 73F, perfect calm on the bay and 2ft swells on the ocean... On Dec 24th..... :D
Easttnrhino
Re: Tire Feedback
Post by Easttnrhino » Mon Jan 22, 2018 4:56 pm
I have 35" nitto ridge grapplers on my 17 and like them they balanced well so far have done good off road and in light snow and we'll mannered on the road. I am fixing to go to 37" tires i hope. Does anyone have the nitto ridge grapplers in 37" on stock rims and did they balance? I keep reading how good Toyo balance I like the looks of the R/T any feedback on them. Thanks
2017 wagon in beautiful east tn
Re: Tire Feedback
Post by olyelr » Mon Jan 22, 2018 5:33 pm
adeluca73 has them on his factory wheels....
http://forum.powerwagonregistry.org/vie ... &start=225
TommyG
Re: Tire Feedback
Post by TommyG » Tue Jan 23, 2018 11:09 am
I have 37x12.50 Toyo R/Ts on my factory wheels on my 2012. Got them over the summer and this is my first winter on them. So far I couldn't be happier. I fell for the balance beads when i got them and they were a little rough but it was easily corrected with good old fashioned balancing.
No squishy sidewalls or goofy handling characteristics. The only real change was getting used to driving with a heavier/taller tire. They have been great in the ice and snow that we have had here this winter.
I pulled our 30 foot travel trailer all summer and drive the truck every day. My only gripe has been the balance beads and that had nothing to do with the Toyos. I will be up for another set when these are done. They just plain work.
yellowranger1
Re: Tire Feedback
Post by yellowranger1 » Wed Jan 24, 2018 1:37 pm
Got a picture of them on the truck? Thats likely going to be my next tire, loving my 35" RTs :cash:
TommyG
Re: Tire Feedback
Post by TommyG » Wed Jan 24, 2018 2:43 pm
Sorry, not the best pics but it will give you an idea.
