Wireless winch controller
cell4soul
Post by cell4soul » Mon Aug 25, 2014 10:38 am
I just bought my 2006 PW and it didn't have the winch controller. Can anyone confirm if the Warn wireless controller will work with this winch. From what I've read on this forum and on. Warn's website, it appears as though it will, but I would like to confirm before ordering. Also, how are people liking their wireless controller? Any issues? Thank you in advance.
Re: Wireless winch controller
Post by RustyPW » Mon Aug 25, 2014 10:50 am
I got one. No issues with it. Works good. :rockon:
Russ NRA Benefactor Member
dogcar3
Post by dogcar3 » Mon Aug 25, 2014 11:12 am
I like mine. Only complaint is that there is a small delay from hitting the button to the winch moving, so you have to plan for this.
2012 Beast.
vanished
Post by vanished » Mon Aug 25, 2014 11:52 am
Also use and like mine...
Cactus Red
Post by Cactus Red » Mon Aug 25, 2014 4:54 pm
Having the ability to work from anywhere within range is so handy. Being able to check the line as things get tensioned for kinks, binding, or being cut on something really helps solo operators.
Sent from my DROID RAZR HD using Tapatalk
cell4soul
Post by cell4soul » Tue Aug 26, 2014 12:14 am
Perfect, thank you for the replies gentlemen. Sounds like the wireless controller is the way to go, cheaper than the wired controller.
Fred
Post by Fred » Mon Oct 27, 2014 11:49 am
Anyone have correct part numbers? Both wireless and wired?
MIne is 2012 PW. Thanks/Fred
In addition the Support team at WARN say that the Chrysler winch "called" warn will not work with the remote. So any info on where you got a working wireless remote and part number is much appreciated.
Thanks
Post by Will » Tue Oct 28, 2014 7:35 pm
One of the best things you can do, can get away from the truck, control it from the end of the rope, just way better all around
Cactus Red
Post by Cactus Red » Tue Oct 28, 2014 11:22 pm
Fred wrote:Anyone have correct part numbers? Both wireless and wired?
Thanks
BS...
It's 100% Warn.
I use the old style remote, WARN 76080 Winch Wireless Control. Works great!
Warn 72567 Remote Control Assy. Should be the wired control.
Sent via Carrier Pigeon
Post by Will » Wed Oct 29, 2014 12:01 pm
TonkaPW
Post by TonkaPW » Wed Oct 29, 2014 1:54 pm
I picked up one of the new style wireless remotes and love it. The receiver plugs in to where the wired one would. Simple plug and play.
White Knuckle Rock rails
2" lift
35" Duratracks
Thuren control arms
Fred
Post by Fred » Thu Nov 06, 2014 9:03 am
Thanks for the input.
FourWheelParts had the wireless controller WARN 76080.
One minute installation and we were up and running.
Throttle 8
Post by Throttle 8 » Fri Nov 07, 2014 2:26 pm
There is an even newer model out. It is the Warn 90287. I just bought it on Amazon.com for $113.
2007PW, black, quad cab, G56 6spd, heated leather, sunroof, dual zone climate, Mickey Thompson Baja MTZ (315/70/17), Locker Bypass, TPS Bypass, Lund tonneau, N Fab nerfs, wheel wheel liners, K&N filter, bedliner, PIAA headlights, PIAA foglights, 24" LED lightbar behind grill, Carli Diff guard, Dodge Off Road steering brace, Carli High Clearance Control Arms, Carli Trac Bar, Bilstein 5100 shocks, Carli ball joints, updated "T" style linkage, Odyssy battery, recovery gear, Studded Goodyear Duratrack 315/70/17 for winter
Post by 04Ram2500Hemi » Fri Nov 07, 2014 2:58 pm
Throttle 8 wrote:There is an even newer model out. It is the Warn 90287. I just bought it on Amazon.com for $113.
I just saw that on Amazon. It looks like it's a plug and play kind of thing. Thoughts: http://www.amazon.com/Warn-90287-Wirele ... image_auto
GunniPWguy
Post by GunniPWguy » Fri Nov 07, 2014 5:23 pm
I am going to get that one over the older model with the need for wiring and remote sensor mounting location. You can just unplug it when not in use. Keep it simple.
Post by 04Ram2500Hemi » Fri Nov 07, 2014 6:21 pm
GunniPWguy wrote:I am going to get that one over the older model with the need for wiring and remote sensor mounting location. You can just unplug it when not in use. Keep it simple.
Exactly what I was thinking! Looks like I have something to tell my wife I want for Christmas.
Throttle 8
Post by Throttle 8 » Fri Nov 07, 2014 6:30 pm
I like simple! I will review it when it arrives---unless anyone that already has one wants to chime in. :cash:
Dark84
Post by Dark84 » Fri Nov 07, 2014 6:50 pm
I love it. Got it about a month ago. Plugs right in out of the box and is ready to go.
Sent from my mind to yours.
GunniPWguy
Post by GunniPWguy » Fri Nov 07, 2014 6:58 pm
DITTO! :idea:
Post by adeluca73 » Sat Nov 08, 2014 3:07 am
It's sweet, just don't leave the wireless module plugged in all the time. It might work it's way loose, keep it in the glove box till needed. That's the only pro of the older style wireless controllet, you permanently wired & mounted the transmitter to the winch & inside the engine compartment.
Post by Will » Mon Nov 10, 2014 11:40 am
adeluca73 wrote:It's sweet, just don't leave the wireless module plugged in all the time. It might work it's way loose, keep it in the glove box till needed. That's the only pro of the older style wireless controllet, you permanently wired & mounted the transmitter to the winch & inside the engine compartment.
That's what I did, I ordered the one that plugs right into the winch but looked at it and said, "I will loose that" so I returned it and got the one with the cable and mounted the receiver portion behind the air box permanently. Put some silicone in the plug and plugged it in for good.
hammer40
Post by hammer40 » Mon Nov 10, 2014 9:40 pm
Too cool. Had to buy my truck a return home present.
Thanks for the link.
Throttle 8
Post by Throttle 8 » Fri Nov 14, 2014 6:28 pm
Got my Warn wireless winch controller in the mail today. It works FANTASTIC!
Total install time was 30 seconds----- and that includes the time it took me to drink a beer after I got it hooked up!!!! :chug:
Post by 04Ram2500Hemi » Thu Dec 25, 2014 1:47 pm
Just got the new wireless contol for Christmas. Going to have to mess around with it later. Way to go wife!!!
dale dalueg
Post by dale dalueg » Fri Dec 26, 2014 2:02 am
I love mine
