New Member
New Member
I just wanted to say HI!
My name is Jason. I'm from Northwest Ohio. I have a 1974 and a 2006 Powerwagon. My 74 was purchased new on July 6, 1974 by my great uncle. I purchased it from him when I was 15 and did a complete restore on it. A couple years ago, I decided to build the 360 into a pulling motor. It lasted 4 pulls and then decided to drop a valve while coasting to a stop sign. I purchased my 06 in 07 from the dealer. After I got it, it got a Rancho 4" lift and 37" mud grapplers. I wheeled it a few times, but truck didn't fit my needs anymore.
So the lift came off and snowplow went on. I have now built the truck for sled pulling. I have pulled it the past 3 years and have done very well with it.
Details on the truck are G56, custom traction bars, cold air intake, Diablo, custom hitch, and some other add-ons.
I also have a 2005 Dodge 3500 with a twin turbo Cummins that I'm building into my work truck/drag truck. Shooting for 850 at the wheels, and still be able to tow with it. Working on fine tuning it now.
Family ride is a 2006 Durango with a HEMI. Basically stock except for intake and tuner.
I'm not new to forums, I try to keep my answers short and useful. I'll do what I can to help other members on the site and off the internet.
Thanks,
Jason (06wagon)
Thanks,
Jason (06wagon)
2006 Power Wagon. "Stockish"
Re: New Member
Welcome! Sounds like you already know about the madness of owning one of these things. I look forward to your input.
Sent from an undisclosed location.
Re: New Member
Welcome Jason. You already know about the empty wallet. You're using your PW alittle differently then most of us. Which is a good thing. It gives us another view (eyeballs) on common problems. We also like to fun at each other.
Welcome to the
Welcome to the
Re: New Member
Welcome Jason. What gear/range do you pull in ? Ever pull in 1st gear Lo range & if so, how did it work out ?
Re: New Member
Never pulled in 4 low and first gear. I know that gear is way to slow!!! I tried 2nd a couple times, and that was still too slow.
- VA_Wagon Man
Re: New Member
Welcome to PWR. Looking forward to seeing more of your builds, post up some pics when you get a chance.
Long Gone:
Rausch Creek 2010 Fall Run
Rausch Creek 2011 Spring Run
Rausch Creek 2011 Fall Run
Rausch Creek 2012 Spring Run
Re: New Member
Welcome....i wish i had your time...
Re: New Member
Welcome to finally showing yourself on the forum, We want to hear all about how you pull with your PW? Some of us want to do get into the pulling. I like to do a little of everything, I am the biggest whore on four wheels as I will try it all as many times as I can get it
Welcome again to the site officially!
Power Wagon Registry #47
- Thuren steering upgrade
"The" Wifes Car
"Faith" 2014 Charger RT Max
My Toy
"VISCO" 2013 196CC Tidewater
"The" Wifes Car
My Toy
- AceMan
- Site Admin
Re: New Member
Welcome, Jason! I'm looking forward to seeing pica and videos,too!
Ans I agree with Russ, pulling is a different way to use the PW. Interesting.
And you mentioned that you are aiming for 850 at the wheels with your twin turbo Cummins, and still be able to tow. I didn't realize going up in performance on a smoker takes away towing capabilities, unless I misinterpreted that?
Power Wagon Owner's Club #110
Black '06 PW QC
Black '06 PW QC
Re: New Member
It's a fine line to be able to tow 30K+ at that power and not melt a piston down. I'm trying a twins combo that some have thought of, but not many have tried. I'm a member of competitiondiesel.com. (I would consider it an awesome website for diesel knowledge, one of the best) And no one has tried this.AceMan wrote:Welcome, Jason! I'm looking forward to seeing pica and videos,too!
So it's a major work in progress. I'm hoping to take it to the strip on Friday. Hoping to get a couple "safe" 11 second runs before I go all out. (which is pretty good for a 3500 dually at 8300 lbs)
Re: New Member
That would be an excellent time for an 8300 pound dually What tuning are you running on the Cummins? I think my next truck will be a diesel. Tired of gas trucks. In a couple of years I'd like to get a new(er) 6.7 Cummins and turn it into a strong tow rig/sled puller/DD.06wagon wrote:It's a fine line to be able to tow 30K+ at that power and not melt a piston down. I'm trying a twins combo that some have thought of, but not many have tried. I'm a member of competitiondiesel.com. (I would consider it an awesome website for diesel knowledge, one of the best) And no one has tried this.AceMan wrote:Welcome, Jason! I'm looking forward to seeing pica and videos,too!
2006 QC PW G56
- AceMan
- Site Admin
Re: New Member
Or maybe this 6.4L 392 stroker with 550HP/525lbft for a cool $15k plus $4k more to polish and port both the intake and heads...
http://bouchillonperformance.com/BPE392 ... TTRUCK.asp
That was posted by Twin in DT earlier under robwhattt's thread, Spun a Bearing:
http://www.dodgetalk.com/forums/showthr ... ost4382230
But their 6.1L plug & play crate version is about $9k, but a little more tame at 425 - 450HP and around $8900.
http://bouchillonperformance.com/P5155067.asp
Black '06 PW QC
Black '06 PW QC
Re: New Member
15K dollars for only 550hp?! Wow...this is why I dislike gas engines. With a diesel, you could have a 600hp DD that will tow 20,000 pounds, run 12 sec. in the 1/4 mile, and return north of 20mpg unloaded and last for 250K miles. I've been looking at used diesel F250's lately but the numbers don't make sense for me to justify a trade. I've dumped too much damn money into this pig Maybe I will just take out a loan and trade the 'Wagon in. Very indecisive lately The 11mpg average is killing meAceMan wrote:Or maybe this 6.4L 392 stroker with 550HP/525lbft for a cool $15k plus $4k more to polish and port both the intake and heads...
2006 QC PW G56
- AceMan
- Site Admin
Re: New Member
HP costs $$. And it deserves the new $ smiley, but I don't remember what the $ smiley text equivalent is, since I'm on Tapatalk.
And if you're getting 11, that's way better than I'm getting at 8-9.
Late edit: Here's that cash$$ smiley:
Black '06 PW QC
Black '06 PW QC
- AceMan
- Site Admin
Re: New Member
But Miles, I understand about the advantages of a Diesel. I've been seriously mulling it over, too, such as a 3500 Megacab, single rear wheel, 6.7L short bed. If I do, I'll probably improve the suspension with Carli Radius, or Carli or Thuren non-lift, or a mix, King 3.0 reservoir with Don's clickers, 15k winch, 37" Toyos, and I didn't eve get to the engine yet, but you've already covered that part!
Black '06 PW QC
Black '06 PW QC
- VA_Wagon Man
Re: New Member
I won't make any bones about it, I'd love to have a diesel. But understand, it would be extremely difficult to have a truck that could do it ALL, and do it ALL, WELL. I love to pull, which I would need a diesel for. I also love to wheel in the rocks and mud, which a lighter gas is good for. To meet both of those needs, I guess I have to get another truck.......a diesel. I'm not getting rid of the PW, period.
Long Gone:
- AceMan
- Site Admin
Re: New Member
Yea, a vehicle for each occasion! I can just see that in my driveway! A PW, CTD, and a Jeep SRT8! I'll probably wind up sleeping in one of them!VA_Wagon Man wrote:I won't make any bones about it, I'd love to have a diesel. But understand, it would be extremely difficult to have a truck that could do it ALL, and do it ALL, WELL. I love to pull, which I would need a diesel for. I also love to wheel in the rocks and mud, which a lighter gas is good for. To meet both of those needs, I guess I have to get another truck.......a diesel. I'm not getting rid of the PW, period.
Black '06 PW QC
Black '06 PW QC
- chromedragon
Re: New Member
AceMan wrote:Yea, a vehicle for each occasion! I can just see that in my driveway! A PW, CTD, and a Jeep SRT8! I'll probably wind up sleeping in one of them!VA_Wagon Man wrote:I won't make any bones about it, I'd love to have a diesel. But understand, it would be extremely difficult to have a truck that could do it ALL, and do it ALL, WELL. I love to pull, which I would need a diesel for. I also love to wheel in the rocks and mud, which a lighter gas is good for. To meet both of those needs, I guess I have to get another truck.......a diesel. I'm not getting rid of the PW, period.
Well so long at the CTD is a mega cab you are set you can sleep in the cab and tow the rest around on a trailer....
To the OP welcome aboard
Special Licenses:
FAA Airframe and Power Plant
FCC Technician (Ham) KK6YCI
Robert A. Heinlein
Special Licenses:
Robert A. Heinlein
Re: New Member
Ace I think you're onto something. I would love to add a Jeep SRT8 to my vehicle fleet and maybe a Rubicon. However, I can only afford one truck right now so Power Wagon it is.AceMan wrote:Yea, a vehicle for each occasion! I can just see that in my driveway! A PW, CTD, and a Jeep SRT8! I'll probably wind up sleeping in one of them!VA_Wagon Man wrote:I won't make any bones about it, I'd love to have a diesel. But understand, it would be extremely difficult to have a truck that could do it ALL, and do it ALL, WELL. I love to pull, which I would need a diesel for. I also love to wheel in the rocks and mud, which a lighter gas is good for. To meet both of those needs, I guess I have to get another truck.......a diesel. I'm not getting rid of the PW, period.
- AceMan
- Site Admin
Re: New Member
I'm with you. Maybe just an Abrath as a DD. It's cheap, great on gas at around 40 MPG, and Charlie Sheen seems to do well with one flying around inside his mansion.
Sent from my Nexus using Tapatalk. Please excuse any misspellings from the stupidly advanced spell checker.
Black '06 PW QC
Black '06 PW QC
