Dash Lights
Dash Lights
I've worn out a keyboard searching but no luck. On my '07 and '03 Rams, you could turn the dash lights completely off with the dimmer switch while the truck was running and the head lights off. On my '10, you can only dim them with the headlights on and when you turn the headlights off, the dash goes to as bright as possible. Has anyone found a way around this? I hog hunt at night and want to be able to turn off all lights including the interior. I've pulled every fuse that says anything about lights and can't figure it out. I've tried tapping into the wires going to the rheostat to put an inline toggle switch but apparently it is part of a circuit of wires and I can't figure out what powers it all.
Re: Dash Lights
Re: Dash Lights
My “solution” is to place a clean article of clothing or towel over the dash lights. Hanging something over the radio screen is trickier. Maddening, isn’t it?
Re: Dash Lights
As much as having to do that pisses me off... it sure works well.
