Rock rail help
Rock rail help
Ok guys I need some helpful ideas. I need to remove my factory rock rails to strip them and paint them, the salt this year has taking its toll on them. The problem happens when I go to remove the 9/16th nuts the bolts just spin and with no access hole to the head of the bolt there no easy way that I can see to get them off and back on. Have you guys found and easy way to do this..
2006 power wagon quad cab (im keeping this one)
2007 BMW 530xi sold (cars just arent me)
2005 power wagon quad cab. silver. #633. sold
2005 quad cab CTD sold
2005 quad cab hemi sold
2003 guad cab hemi sold
Re: Rock rail help
I have a set I havent installed...but to remove them..id have them on stands walk the r.r.s out and and use a vise grip to get the nuts off...and walk the r.r.s out more and wrap some tape around bolts so they dont drop into the frame..
Re: Rock rail help
They are a HUGE PITA to put on & prob 3x as hard to remove after exposed to salt & rust. I also have a brand new set that i have not installed yet. (Sorry-not for sale) Dealer was already in-the-know & told me there was no f'n way they were going to put them on unless i paid by-the-hour for EACH employee & that it would take 2-4 people an entire 8 hr day to install.
IMHO, the best way may be to try to tack-weld the bolt or nut (which ever applies) to the frame first. Originally the square part of the carriage bolts went into the square holes of the frame & that is what kept them from spinning. Impact wrenches can round out that square hole or the square part of the carriage bolt in an instant.
If i had it to do over, I would prob buy aftermarket sliders that bolt around the frame with u-bolts or something similar. After i have mine modified with nerf bar/tree side slider & some diamond plate (to look kinda like a running board) i was thinking of triple powder coat, then bed liner & spray the interior with some Fluid Film.
- Cactus Red
Re: Rock rail help
I don't even want to think about taking them off... As mentioned, they are a nightmare to install, and the removal process would be way worse.
Sent via gigawatt laser...
Re: Rock rail help
TwinStick wrote: If i had it to do over, I would prob buy aftermarket sliders that bolt around the frame with u-bolts or something similar. After i have mine modified with nerf bar/tree side slider & some diamond plate (to look kinda like a running board) i was thinking of triple powder coat, then bed liner & spray the interior with some Fluid Film.
I got a set from White Knuckle Off Road and love them. Well worth the money I paid for them.
White Knuckle Rock rails
2" lift
35" Duratracks
Thuren control arms
2" lift
35" Duratracks
Thuren control arms
Re: Rock rail help
Re: Rock rail help
White knuckle all the way. I got the .188 DOM because I abuse my truck lol
Re: Rock rail help
oh my. i would just let the rust away and NOT remove them.
mike
mike
Gooseneck
SOLD 2012 Power Wagon Laramie
2016 GMC Yukon Denali XL
2016 Volvo XC90
Gooseneck
2016 Volvo XC90
Re: Rock rail help
Scuff and spray bed liner!
Re: Rock rail help
I'd get some visqueen and tape and do the best I could to them and leave them on the truck!
- Cactus Red
Re: Rock rail help
Once it warms up, there are acid based products that convert rust to a stable oxide that can be painted. After that, POR15 would be my choice as a base coat, and it can be applied in place with a brush.
- VA_Wagon Man
Re: Rock rail help
This would be my recommendation. There is no way I would have removed mine, ever. All I ever did was sanded them and sprayed bed liner on them. I usually sanded them down with boulders. 80 Grit would work too......Cactus Red wrote:Once it warms up, there are acid based products that convert rust to a stable oxide that can be painted. After that, POR15 would be my choice as a base coat, and it can be applied in place with a brush.
Long Gone:
Rausch Creek 2010 Fall Run
Rausch Creek 2011 Spring Run
Rausch Creek 2011 Fall Run
Rausch Creek 2012 Spring Run
- Cactus Red
Re: Rock rail help
http://www.amazon.com/PPG-Rust-Converte ... B002ABL3PS
I've used a product similar to this on sliders I've made. Prior to painting, I apply it to the bare steel to acid etch it and convert any rust prior to paint. It works!
