JBM Power Wagon
Post by JBM Power Wagon » Sat Apr 26, 2014 10:40 pm
Hoping to install mine tomorrow!!! Then will have to wait a few weeks until I will have some trail time to test it out.
JBM Power Wagon
Post by JBM Power Wagon » Sun Apr 27, 2014 5:01 pm
It's installed!!!! Great quality product! Great instructions! First small test in the driveway and it works perfect!!! Can't wait to get out on the trail and really test it out!!!! Can you tell I'm a little bit excited?!?!?!?!
oletrucker
Post by oletrucker » Mon Apr 28, 2014 12:25 am
Would like to add my name to your list.
1. myoung84 - 2012
2. 04Ram2500Hemi - 2012
3. BlkWgn 2006
4. TrueBlue13PW
5. HotRod929 - 2013
6. Wingerak92 2012 (next year, need tires first)
7. TwinStick-----3rd Gen 2008 w/G56 (LATER)
8. Hemi46. 05 gen 3 (later)
9.gtomike60-2012
10.glidehm
11. ScottWagon1-later
12. Mexican Import - 2013
13. MSCH2112 - 2013
14. BMWS52-2011
15. Mopar Bob (2012) - Later
16. Juday (2012) - Later
17. Nrooney21 (2012)
18. RustyPW '08 3G (when you get the 3G figured out)
19. Jeep_boy02 (2010)
20. Rgory (3rd Gen) When you get it figured out
21. Bajaben48. (later....tax return )
22. Iamahemi (2012) later
23. BigMike 2009
24. GunniPWguy (2005) worthy mod someday
25. bigblackdodge (2010)
26. blindsquirrel33 (2011)
27. StubiePW 2012 (later)
28. bstefanic-3g 2006
??30. Bigred2007 - 3rd Gen
31. Stickman (2012)
32. blathrop99 (2013)[/quote]
33. oletrucker (09 3rd Gen.) When you get it figured out.
"All too often, people born into a state free of tyranny, never fully realize the price paid in achieving this most rare and precious of gifts. And, thinking that freedom was a normal environment of the People, never understood its fragility or true value until after it was lost."
J.C. Harrison
Big Blue
Post by Big Blue » Wed Apr 30, 2014 7:21 am
Put me on the list if/when you get the third gen ironed out. Mines an '07. Right now I have no lights, lockers don't work and stabilizer does not disconnect, I believe because the smart bar is hosed. I took the connector off of the smart bar and there was some melted plastic around the large pin. Would your solution still work if the smart bar is fried? Seems like it would. Is there any chance your solution would cause my lights to work again (assuming they aren't working due to smart bar issue)? Thanks.
Powerwagon Nut
Post by Powerwagon Nut » Wed Apr 30, 2014 8:09 am
1. myoung84 - 2012
3. BlkWgn 2006
4. TrueBlue13PW
5. HotRod929 - 2013
9.gtomike60-2012
10.glidehm
13. MSCH2112 - 2013
14. BMWS52-2011
23. BigMike 2009
31. Stickman (2012)
33. oletrucker (3rd Gen.) When you get it figured out.
34. Powerwagon Nut (3rd Gen,) When you get it figured out. X2
Joe Cool
Post by Joe Cool » Wed Apr 30, 2014 8:19 am
Would like to add my name to your list. I thought I posted my name on a list in the Vendor section but I can't seem to find it any more.
1. myoung84 - 2012
3. BlkWgn 2006
4. TrueBlue13PW
5. HotRod929 - 2013
9.gtomike60-2012
10.glidehm
13. MSCH2112 - 2013
14. BMWS52-2011
23. BigMike 2009
31. Stickman (2012)
35. Joe Cool (2013)
2013 Copperhead Pear Power Wagon Laramie. 2" Levelling Kit, dual exhaust, Wireless WARN winch remote, myoung's very cool Locker bypass Kit.
Trouble Maker
Post by Trouble Maker » Wed Apr 30, 2014 12:10 pm
Joe Cool wrote:Would like to add my name to your list. I thought I posted my name on a list in the Vendor section but I can't seem to find it any more.
1. myoung84 - 2012
3. BlkWgn 2006
4. TrueBlue13PW
5. HotRod929 - 2013
9.gtomike60-2012
10.glidehm
13. MSCH2112 - 2013
14. BMWS52-2011
23. BigMike 2009
31. Stickman (2012)
35. Joe Cool (2013)
36. Trouble Maker 2009 3rd gen
We really need a separate 3rd gen thread.
Black 09 purchased Dec 21/13
180K kms on the clock
R0NAN
Post by R0NAN » Tue May 13, 2014 10:33 pm
I received my bypass kit today! I hope I can find the time to install and test it soon. Nice work Myoung! I appreciate your workmanship. Looks very professional.
Just a quick question. I read that metal buildup on the magnet in the diff can be an issue in regards to causing a short. Should this concern me now? I plan on cleaning the magnet anyways, whenever I change the diff fluid. I think I read that magnet gap adjustment is no longer critical with your bypass so how does the magnet factor into the equation (if at all) now that I have a bypass. Sorry if this sound dumb or if if it's been explained already. Also, I am guessing that the smart bar only controls the sway bar disconnect after bypass installation.
Many thanks. :D
Post by Will » Wed May 14, 2014 4:36 am
If I may chime in, I purposely didn't change my gear oil nor clean the magnets until after I installed this kit. It worked flawlessly with crude on the magnets. You should be fine. The hardest part about the install is taking your time unplugging the existing connectors. Took me about 1.5 hours and half of that was being careful not to break the old connectors. I placed some photos and spoke more about it here... http://forum.powerwagonregistry.org/vie ... =22&t=1798
R0NAN
Post by R0NAN » Wed May 14, 2014 5:58 am
:wink:
R0NAN
Post by R0NAN » Wed May 14, 2014 6:02 am
Thanks Will! I'll be sure to be careful as breaking one of those diff plugs would be an expensive tragedy.
Post by Will » Wed May 14, 2014 6:25 am
I found spraying the connectors with Corrosion X really eased taking them apart. I suppose WD40 or something similar will work also. It allowed the red lock to slide easier.
myoung84
Post by myoung84 » Wed May 14, 2014 7:58 am
I just use a small flat head screw driver. Works good for me.
RONAN, glad it came in finally. Magnet gap isn't critical with the kit since it doesn't use the sensors (which is why it actually works, LOL). And yes, the smart bar only controls the sway bar now.
chad13powerwagon
Post by chad13powerwagon » Wed May 14, 2014 3:42 pm
I would like to be added to the list let me know how much and how you want paid
Thanks this sounds great
2013 power wagon is my ride
13 Power Wagon
Vararam air grabber, Moe's performance 87mm throttle body in tune with hemifever tune
THEREALDEAL
Post by THEREALDEAL » Fri May 16, 2014 5:59 pm
Which list are you going by, the one on this thread or the one in the vendor section?
10' Power Wagon white and black, mostly stock
R0NAN
Post by R0NAN » Sat May 17, 2014 9:28 pm
Well I hooked up my bypass harness today and it works wonderfully! Locks up very quickly. Very nice work Myoung. My truck is a 2013 and I also mounted the box in the same location as TrueBlue '13 PW, on the front pillar just below the t harness plug on the passengers side near headlight. It was much easier due to the fact that I didn't have to remove the air box and reroute wiring that was in the way. ( see photos page 14)
Have any of you sealed up the connectors with dielectric grease? I was thinking of doing that tomorrow. Thanks again Myoung for your dedication to this project. Your talent is appreciated. :cheers:
myoung84
Post by myoung84 » Sun May 18, 2014 6:24 am
I'm so glad these are all working as planned. That mounting spot was actually my first choice but decided on the other location for two reasons. It's more out of sight for dealer visits and there's far less chance of water getting in the box. Everything is supposed to be water tight, but you never know. It's a great idea to put dielectric grease in all the connectors, especially when mounted in the alternate position.
Post by adeluca73 » Wed May 21, 2014 1:20 pm
Any chance you're still adding names to the list?
I have a 2014 SLT on order.
myoung84
Post by myoung84 » Wed May 21, 2014 1:37 pm
I am. If you'll add your name to the list in the thread below, I'll get in touch when I do the next run.
I'm not sure if these work on the 14s yet. Theoretically they will, but you never know what they changed.
http://forum.powerwagonregistry.org/vie ... php?t=1983
Juday
Post by Juday » Wed Jun 11, 2014 7:07 am
So, when's the next batch going out and are all of them spoken for? If not, I'll take one in the next run. :)
2012 RAM Power Wagon
2012locked
Post by 2012locked » Wed Aug 27, 2014 7:04 am
I would love to purchase one of your kits as well! Please add my name to the list.. Had my truck for two weeks, after owning a wrangler rubicon with a modded bypass, I'm looking forward to this setup on the truck..
Thanks!
rhino
Post by rhino » Fri Aug 29, 2014 2:30 pm
1. myoung84 - 2012
3. BlkWgn 2006
4. TrueBlue13PW
5. HotRod929 - 2013
9.gtomike60-2012
10.glidehm
13. MSCH2112 - 2013
14. BMWS52-2011
23. BigMike 2009
31. Stickman (2012)
35. Joe Cool (2013)
36. rhino (2005)
azracer
Post by azracer » Fri Aug 29, 2014 3:51 pm
1. myoung84 - 2012
3. BlkWgn 2006
4. TrueBlue13PW
5. HotRod929 - 2013
9.gtomike60-2012
10.glidehm
13. MSCH2112 - 2013
14. BMWS52-2011
23. BigMike 2009
31. Stickman (2012)
35. Joe Cool (2013)
36. rhino (2005)
37. azracer (3rd Gen 2009)
What? Another list?
Add me to the list. What list was I on? Sheesh I can't keep up!
pwrwgn13
Post by pwrwgn13 » Fri Aug 29, 2014 4:02 pm
azracer wrote:
1. myoung84 - 2012
3. BlkWgn 2006
4. TrueBlue13PW
5. HotRod929 - 2013
9.gtomike60-2012
10.glidehm
13. MSCH2112 - 2013
14. BMWS52-2011
23. BigMike 2009
31. Stickman (2012)
35. Joe Cool (2013)
36. rhino (2005)
38. pwrwgn13 (2013)
2012locked
Post by 2012locked » Mon Sep 01, 2014 3:39 pm
1. myoung84 - 2012
3. BlkWgn 2006
4. TrueBlue13PW
5. HotRod929 - 2013
9.gtomike60-2012
10.glidehm
13. MSCH2112 - 2013
14. BMWS52-2011
23. BigMike 2009
31. Stickman (2012)
35. Joe Cool (2013)
36. rhino (2005)
38. pwrwgn13 (2013)
39. 2012Locked (2012)
