Need more power
Need more power
So i am working to track down the cause of the air plane taking off noise that is coming from under my hood when i am in first gear. I believe it is from the CAT's being clogged and messing with the back pressure of the engine. Has anyone been able to run high flow CAT's and not get a code?
Thanks
JL
Thanks
JL
“Do not go where the path may lead; go instead where there is no path and leave a trail”
-Ralph Waldo Emerson
Re: Need more power
If your cats was clodded. The engine will run, but will stall out when you give it gas. Been there, done that will a other truck.
Need more power
It has not stalled out yet, jut has no power off the line and sounds like a plane taking of in first gear. I wish someone on here lived around Memphis that could take a look at it.
- verdesardog
Re: Need more power
jeepxj13 wrote:It has not stalled out yet, jut has no power off the line and sounds like a plane taking of in first gear. I wish someone on here lived around Memphis that could take a look at it.
Sounds like your cooling fan, maybe the fan clutch is toast.......
- VA_Wagon Man
Re: Need more power
That's what I though. If your fan clutch is locked up, it'll sound like a turbine taking off and suck all your power out.verdesardog wrote:jeepxj13 wrote:It has not stalled out yet, jut has no power off the line and sounds like a plane taking of in first gear. I wish someone on here lived around Memphis that could take a look at it.
Quick test, go try to spin your fan with the motor OFF. If it doesn't turn or is pretty stiff, you need to replace your fan clutch. The Power wagon has a special fan clutch that is heavy duty and actaully kicks in sooner than other clutches for quicker and better cooling.
Long Gone:
Rausch Creek 2010 Fall Run
Rausch Creek 2011 Spring Run
Rausch Creek 2011 Fall Run
Rausch Creek 2012 Spring Run
Re: Need more power
Thanks so much for the help. I'm going to pick one up st lunch tomorrow and I'll keep everyone updated.
Re: Need more power
So I can not find the part number for the special fan clutch. Does anyone on her have it?
Re: Need more power
Dealer only listing but you can just cross reference that OEM PN# to an aftermarket equal, or you could also just use Mopar Wholesale http://www.mopar-wholesale.com/ and get it there. Be sure to have your VIN to order the right one. I believe it is the very same one used on the 2500, snow plow, quad cab w/auto trans.
Re: Need more power
The only problem I've had with my '05 PW was at 9,400 mi. the fan clutch went out and was repaired under warranty.jeepxj13 wrote:So I can not find the part number for the special fan clutch. Does anyone on her have it?
Here is whats on the repair invoice...
Clutch FA 7007001 , FP-NUMBER 52028877-AC
Hope this helps.
- VA_Wagon Man
Re: Need more power
Hmm....if my memory serves me right, I used the heavy duty, W/O snow plow option.
NAPA PN # 271621
NAPA PN # 271621
Long Gone:
Re: Need more power
you could always do what i did and put in a flex-a-lite electric fan, cost me around $425 for the kit that comes with the control unit and the brackets for the coolant/washer jug
06 White POWER WAGON!
Pure Performance control arms
Flexalite e-fan
Rock-rails (by me)
Diablo sport tuner
Rock Monster beadlocks
BFG KM2's
Airflow snorkel
Bed rug
Bilstein 5100's
Thuren coils & shackels
Flexalite e-fan
Rock-rails (by me)
Diablo sport tuner
BFG KM2's
Airflow snorkel
Bed rug
Bilstein 5100's
- VA_Wagon Man
Re: Need more power
I want to do that eventually.twistedpw wrote:you could always do what i did and put in a flex-a-lite electric fan, cost me around $425 for the kit that comes with the control unit and the brackets for the coolant/washer jug
Long Gone:
