yellowranger1
Post by yellowranger1 » Wed May 16, 2018 5:38 pm
Shit happens when you party on the rocks!
Glad that didn't happen at speed! I wan't thrilled when I re-centered my wheel after the lift and saw how much it was threaded out... Synergy has some prototype steering kits floating around out there for our trucks that should add some strength when available. How long before the ram-assist is installed??? 8-)
Post by Low_Sky » Wed May 16, 2018 5:47 pm
Is that tie rod bent too?
yellowranger1
Post by yellowranger1 » Wed May 16, 2018 6:01 pm
Bent is such an ugly word... "Contoured"
Post by Low_Sky » Wed May 16, 2018 6:46 pm
"Strengthened by cold working"?
Post by Colibri » Wed May 16, 2018 7:59 pm
Navigating the rocks by Braille
Post by olyelr » Wed May 16, 2018 8:14 pm
DOR has a kit out...
http://store.dodgeoffroad.com/Dodge-Off ... p_166.html
In fact, this steering is bigger than what most rock bouncers and monster trucks use.
Post by OffroadTreks » Thu May 17, 2018 12:12 am
It bent like hot butter with a bad line on the Golden Crack this year. I attempted to relocate when I should have stayed put and snapped it. Take a look at this >>>
We pulled a spare unit to get off the trail. Then modified this, sleeved it and reinstalled it to get back home. Have a new replacement.
DOR is currently the only one with a full kit for the 2014+ trucks. Synergy supposedly has a kit coming.... sometime ¯\_(ツ)_/¯
And I do not know if Thuren has any plans.
So right now, I'm researching. I am told, that spot, is where it breaks for A LOT of people.
Post by DamageWagon » Thu May 17, 2018 2:25 am
I once ran a DOR steering kit for two weeks.
Post by DamageWagon » Thu May 17, 2018 2:26 am
Seemed to be the theme this year :doh: :sick:
Chromolykid
Post by Chromolykid » Thu May 17, 2018 12:56 pm
Looks awfully familiar!
“Furiosa”
2016 Power Wagon
White Knuckle Sliders
DOR Steering Brace
Thuren Stage 1 KING 2.5’s
Thuren Coils Front & Rear
AEV Procal
Mule
Post by Mule » Wed May 30, 2018 7:26 pm
Finally got around to drilling out the bolts on the skid plate/frame that Firestone fucked up when they did the fuel pump replacement.
Gave up and drilled two new holes just above the old ones. :\
Got it shoved under, halfway-secured....
...and that's when I realized they broke three more bolts they didn't tell me about. Some more drilling/grinding/swearing...
Glad I picked up some extra bolts at home depot... :( Hopefully all set for a while now.
....especially since I'm playing hide-and-seek with a bad bearing in the moto engine....
Think it's either head/cam (what i'm hoping for, cheap/easy) or counterweight (complete teardown/rebuild). Stator, countershaft, and everything under the clutch cover looks good.
Post by DamageWagon » Wed May 30, 2018 8:44 pm
Do the dirt bikes have the same problems the LC4’s had with the crappy Turkish cam bearings??
Post by Reloaderguy » Thu May 31, 2018 12:21 am
Hydro assist would relieve the stress on the draglink but cranking on the steering in a crack would probably just break something else.
Mule
Post by Mule » Fri Jun 01, 2018 2:57 am
Most of the reason mine has issues is because it's got about 30,000 miles on it :rofl:
Replaced most of the bearings a few years back, one of the crank bearings got replaced 2yrs ago.
If it's a rocker/cam bearing (wouldn't be the first time i've lost one of those), that should be a real easy/inexpensive/quick fix. Anything deeper and I might as well throw in a new piston, run a hone through the cylinder, new gasket set, etc.... Image
Ran the bike out of fuel this morning, thought I killed it... forgot to refuel after yesterday's run into denver. Whoops. :rofl:
Parking garages aren't Power Wagon (won't clear height) or dirt bike (sensors don't detect it) friendly.
After rolling forwards/backwards for about 5mins to find the sweet spot in the entry-gate loop, it was a weird "hold the bike up in this exact position so it detects me" and reach over to press the button on the machine that's just baaaaaarely within arm's reach so it'll shit out a ticket and open the door/gate to let me in...
....going out, I couldn't find the spot where the loop would pick me up so I could stuff the ticket into the machine. Buzzed the attendant, and apparently the mic on the kiosk was broken. "Hello, can you hear me? Hello?" ... finally gave up and just rode around the gate. :thppt:
Aaaaaaaaaaannnnnnnnnnnndddddddddd.... on the way home last night....
He didn't like my license plate. Mounted vertically (if it's horizontal, it gets ripped off in the trees, btdt), and ... well, it's a dirt bike that I ride like a dirt bike, so it's not exactly in pristine condition. I guess there's no laws broken, but being "hard to read" is grounds for a stop... whatever.
Hodgepodge
Post by Hodgepodge » Wed Jun 06, 2018 2:18 pm
Pictures of my neighborhood adventure:
Hodgepodge, Klein, Texas
2016 RAM PowerWagon
37” Toyo Open Country MTs
Amp side steps
PWJouster
Post by PWJouster » Thu Jun 07, 2018 11:03 am
that is so powerwagon
17 Method NV-Toyo RT 35
SPOD
Mule
Post by Mule » Thu Jun 07, 2018 1:56 pm
Crank bearing.
Replaced the original roller bearings with heavy-duty ball bearings at ~6k miles.
Replaced the clutch-side bearing in '16 since it felt crispier than I was comfortable with.
Now it's the stator-side bearing. Suspect I've just found the MTBF on these bearings in this engine.
Aaaaaaaaaaaannnnnnnnnddddddd..... pinion seal on the rear diff of my truck is leaking. :angry:
Post by TwinStick » Mon Jun 11, 2018 1:06 am
Not for nothing but isn't that super early for a bearing failure of that kind ? KTM's ain't cheap. My DR650SE had around 20k when I sold it. No problems like that. Some DR650SE's have gone 140,000 miles with no bearing failures. I know they are apples to oranges compared to a KTM but that just seems too early for that type of failure ?
Traded to 2019 ZR2, Red.
Mule
Post by Mule » Mon Jun 11, 2018 3:48 pm
RFS = Racing Four Stroke. Things are wound up a bit tighter in there than a DR650.
High-50s/low-60s hp numbers on my 525, vs. mid-40's for the DR.
525's 272lbs ready-to-ride, vs. 320+ dry weight on the 650.
Gotta pay for that performance somewhere. "Keeps Taking Money"... :cash:
Still better than the MX bikes; those want an oil change every ride, top-ends once a month. Very short maintenance intervals on those.
And since this is a truck picture thread :lol: ... :box:
New seal, no more gear-oil-fountain. Lost about 1/2qt over the past week or so that it's been leaking(spraying).
Torque spec on the pinion nut should just say "More than you have tools to do". Wrenched down on it and got a vibration 25-40m/h, which is typical if you don't preload the pinion gear with the torque on that nut. Wrenched down on it some more and now the vibration's gone. Still whines a bit, but it's been doing that since I got it and there's no skuzz in the fluid, so :thppt: i'm just going to deal with it.
Post by DamageWagon » Mon Jun 11, 2018 5:27 pm
I just picked up a 950 Adventure, the engineering in these things makes my Yamaha MX bike look like a play toy. And that bike gets an oil change every trip.
For as complicated as the KTM’s are, it’s a good complication. The troubleshooting is excellent and with 53,000 miles on it this thing piers like a kitten...
You know the story... :nopics:
vanished
Post by vanished » Mon Jun 18, 2018 9:20 am
Posing at OBX last week...
Post by Low_Sky » Mon Jun 18, 2018 9:37 pm
This scenery in Alaska sucks.
Post by Colibri » Tue Jun 19, 2018 4:58 am
Horrible
Mule
Post by Mule » Tue Jun 19, 2018 1:41 pm
Not enough snow.
Post by Low_Sky » Tue Jun 19, 2018 4:01 pm
Not enough snow.
Best I can do in late June is ice.
