Rock sliders
Re: Rock sliders
Post by KevinABQ » Wed Mar 14, 2018 12:55 am
I had a quote from a small local fab shop of $750 for sliders on my Avalanche. This included install. Can't compare them to the ones on my PW because I didn't go forward with them, but they had good reviews. The high end commercial shop in town (which mostly builds custom commercial truck bodies and trailers) gave me a price of $2500 for sliders for the same Avalanche, but as I didn't go forward I have no good basis to compare them either. However the reviews of the later firm said their work was great but cost a fortune.
BoldAdventure
Re: Rock sliders
Post by BoldAdventure » Wed Mar 14, 2018 1:36 am
Really no point buying a kit if you’re going to take it to a shop. Might as well buy the bolt on’s.
1/3rd would be paying 350-450 for the materials, bent tube, mounting hardware and you welding it together. Like some of the other kits out there.
If your time is free; then you saved.
Also; I think WK prices did go up. I forgot to mention, I have a discount for PWIM attendees for White Knuckle. PM me.
Re: Rock sliders
Post by RustyPW » Wed Mar 14, 2018 1:46 am
13powerwagon wrote:
Wed Mar 14, 2018 12:23 am
The aluminess sliders are made out of steel. Their main flaw is they mount to the same spot the factory steps do, I believe Ram4roks had them and ended up ripping the mounting holes from repeated abuse, if I remember correctly.
My fault. I have their front bumper and the bottom of it got some nice gouges in it.
Mods to the PW; Nerffed Mopar RockRails, Wheel Well Liners, Bushwacker Pocket Fender Flairs, Garvmin dezl 560LMT GPS, Power Wagon Winch Kit, Line X Ultra Bed Liner, PIAA Headlight Bulbs, PIAA 580 Driving Lights (135 watt), PIAA 520 Fog Lights (135 watt), PIAA 520 ATP Off-Road Lights (135 watt), Locker Bypass, Modifed Rockcrusher Diff Covers, Mopar Utility Bed Rails and Tool Box, Warn Winch Wireless Remote Control, "el-cheapo" Inclinometer, Airaid CAI, Winch TPS Bypass, 35" Toyo's, Mopar Spare Tire Lock, 'T' Steering Linkage, Modifed PSC Steering Brace, P3 Brake Controller, Modifed Fusion "mall crawler" rear bumper , PIAA 1500 Back-Up Lights, 1Ton HEMI Tranny Cooler, Leer 100XR Bed Cap, Factory Tow Mirrors, CenterLine Rims 17x9-5.25 BS, Mag-Hytec Tranny Pan, AutoMeter Gauges, PSC Extreme Hydro Assist Steering, Carli G2 Track Bar, Carli Ball-Joints, Dynatrac FreeSpin Hubs, Snorkel, RCV Axles, EBC Pads & Rotors, Aluminess Front Bumper, BIG Pul-Pal, 60" Extreme Hi-lift Jack, and more riggin' equipment, Carli Long Travel Air Bags, Bilstein 7100 Shocks - Carli Valving, Carli Control Arms, Thuren 3" SoftRide Springs, Thuren Rear Shackles, MagnaFlow Muffler, Crown Stainless Brake Lines, MORE STUFF COMIN'.
Russ NRA Benefactor Member
Adam_C
Re: Rock sliders
Post by Adam_C » Wed Mar 14, 2018 9:37 am
Gotcha, kind of what I figured. Thanks for the input. :cheers: Have fun in Moab. If I wind up keeping my truck I might try to attend next year if there’s another PWIM event. Maybe get a chance to test these RED “sliders” :thppt: :lol: Sorry for the hijack.
Adam
Re: Rock sliders
Post by olyelr » Wed Mar 14, 2018 9:48 am
Adam_C wrote:
Wed Mar 14, 2018 12:44 am
MikeKey wrote:
Wed Mar 14, 2018 12:15 am
Just out of curiosity; would most prefer fully built and ready to install or weld it yourself for 1/3rd the cost?
Im always down for saving money. When you say one third the cost, after finding a competent welder to fab them up, what do you figure the price difference would be? Would it be comparable to fully built ready to install set?
Adam
Mikekey, I feel if he had both of the options he would probably sell them both like hotcakes. But if he only made one, I would go with fully built.
AdamC, if you have to pay someone to weld it up anyway, might as well just buy them that way to begin with. Will probably be cheaper that way.
PWJouster
Re: Rock sliders
Post by PWJouster » Wed Mar 14, 2018 10:01 am
frame mounted sliders are not ideal for mostly road going vehicles.
a higher speed fender bender can turn into frame bending truck totaling fatality.
along with some bumper designs and hitch receivers. unless its an Asian vehicle...then youll implode it.
not sure how likely or often that happens on 2500s but i know the 1500s and jeeps cant take frame mount hardware hits.
2018 Powerwagon
Thuren King 3.0-S3 & 2.5-S2 with King Stab, TBs, Boogies and
Dodge-Off-Road Steering Brace
Method NV 17s
Toyo RT 35x12.5/17
Purple Cranium F&R
S&B Intake
Exhaust
PWJouster
Re: Rock sliders
Post by PWJouster » Wed Mar 14, 2018 10:07 am
but i would never add rock sliders that arent frame mounted. i just dont see how the weight of the truck can be suspended by the body/cab mounts. this just doesnt seem physically possible without major wear and tear. body bushings? im concerned stepping on my side step at the same time as a rear passenger...im 230Lbs and worried...not dumbfounded because Jeep JKU
but i neglected to consider frame twist and WK sliders. do these trucks really flex like i just read on RED website? rock sliders are for slow crawls and you shouldnt be bashing on them as if romping through trails rocking ledges in ultra 4 manner.
a nice drop once in a while shouldnt be an issue right? but can I hi lift jack point on these rails either in the center or extended to either end?
2018 Powerwagon
Method NV 17s
Toyo RT 35x12.5/17
Purple Cranium F&R
S&B Intake
Exhaust
Re: Rock sliders
Post by DamageWagon » Wed Mar 14, 2018 10:53 am
If you get in a fender bender or t-boned I’d 100% rather have sliders than not. It takes a serious hit to permanently deform those sliders or the frame, and if you get that hit I’d rather have sliders theatre going to kee the offending vehicle out of my passenger compartment! There’s pics of a 2011 with aluminess body-mounted sliders that got t-boned in an intersection and it totally destroyed the front of the car while the truck suffered a ding to the door and a bend to the sliders. If you’re taking a hit I’d for sure want more protection.
BoldAdventure
Re: Rock sliders
Post by BoldAdventure » Wed Mar 14, 2018 10:58 am
Didn't GTOMike get hit in the sliders with no damage recently, and a bunch of damage to the offending vehicle?
Also as for frame bend, I've had my entire truck jacked up by the sliders and I've used jack stands on them as well.
DirtyOffroad
Re: Rock sliders
Post by DirtyOffroad » Wed Mar 14, 2018 8:02 pm
Tue Mar 13, 2018 8:50 pm
DirtyOffroad wrote:
Tue Mar 13, 2018 7:22 pm
Just making sure I do my due diligence before spending $2000 on White Knuckle sliders. are there any comparable options? I havent come up with much
$2k? Has the price jumped that much in a few years? Seems like I paid like $1200 plus shipping. That was with the thicker tube and powdercoat.
With shipping sorry, yeah. Just shipping is $440
2018 Ram 2500 Powerwagon
1.5 Thuren - Front
Thuren Rear Track Bar
LED Headlights and Fog
DocPaulo
Re: Rock sliders
Post by DocPaulo » Wed Mar 14, 2018 10:45 pm
It was 210 to phx... decided to pick mine up and drive it home... spent 150$ in gas and a day driving... the joy of bringing it home... priceless...
Too bad ny is too far to drive
Auxbeam 42 curved lightbar
RANCHO 9000XL suspension
EMF ball joints
Re: Rock sliders
Post by Bill2014 » Thu Mar 15, 2018 10:23 am
I have driven from NY to Cali - but not in the Power Wagon - 3 days there - 3 days back :wink:
I had my WK sliders shipped - shipping was cheaper in the old days :lol:
Locker Bypass
BoldAdventure
Re: Rock sliders
Post by BoldAdventure » Thu Mar 15, 2018 10:58 am
Shipping prices have gone up in the past couple years on everyone. They should offer fastnel shipping. It'd be even cheaper. Problem is freight is expensive. And those are heavy SOB's. I was blown away at how heavy they were when I picked them up.
DocPaulo
Re: Rock sliders
Post by DocPaulo » Thu Mar 15, 2018 11:07 am
Mine with the 2x4 rail is almost 300lbs for the pair
EMF ball joints
Re: Rock sliders
Post by olyelr » Thu Mar 15, 2018 12:50 pm
I think mine were 135 pounds a piece. They are the thicker tube ones.
DirtyOffroad
Re: Rock sliders
Post by DirtyOffroad » Thu Mar 15, 2018 2:23 pm
Yea shipping weight for mine is 365 pounds with the flat plates
1.5 Thuren - Front
Re: Rock sliders
Post by adeluca73 » Fri Mar 16, 2018 12:33 am
MikeKey wrote:
Tue Mar 13, 2018 9:43 pm
Adam_C wrote:
Tue Mar 13, 2018 9:35 pm
MikeKey wrote:
Tue Mar 13, 2018 8:22 pm
Mostly because they’re not real sliders.
Interesting....what are they?
NFab calls these Rock Rails:
https://www.autoaccessoriesgarage.com/R ... _418400047
what are they?
Rock ornaments :D
