Another Government Wagon Auction
Re: Another Government Wagon Auction
Post by DamageWagon » Wed Dec 06, 2017 7:24 pm
I paid $13k for my '11
FordyceCreekTrail
Post by FordyceCreekTrail » Thu Dec 07, 2017 7:37 am
That seems pretty reasonable. Thats the trick with auctions, sometimes things go low, sometimes high. Just have to know your limit.
2018 Flame Red, Moon Roof, Dual Alternators, Ram Boxes, Luxo Package with 8.4 UConnect, Enter and Go with remote start, Auto Wipers and Lights. Ordered missing skids and White Knuckle sliders.
2018 The NEW Best Year!
Post by olyelr » Thu Jan 18, 2018 5:21 am
Retired BLM Rig wrote:
Thu Jan 18, 2018 2:07 am
A clean looking 08 in El Dorado Hills, CA.
Closes on 1/20/18. Maybe I should buy it for spare parts! :idea: :lol: :run:
Almost looks like it just rolled off the assembly line.... nice!!
Post by Retired BLM Rig » Sun Jan 21, 2018 12:06 am
The government shutdown caused all these auctions to be put on hold. :doh:
If I was one of the bidders... :angry: :box:
EasyDoesIt
Post by EasyDoesIt » Mon Feb 26, 2018 1:28 pm
I bid on several before I bit the bullet on my 2018. I really wanted a 2012 but bids kept going over $20k which was too much in my mind.
I wonder what the 2014s will go for once they start showing up?
Live: Las Vegas NV, Drive: 2018 PW & 2011 Tacoma (Wifes)
Post by Retired BLM Rig » Tue Feb 27, 2018 8:39 am
I bet that 2010 goes pretty cheap. It looks a little rough around the edges and has 153K on the clock, I'll be surprised if it hits $10K. It's ready for retirement and civilian life (someone to give it a little TLC). :patriot:
Post by Retired BLM Rig » Thu Mar 08, 2018 12:42 am
An 07 in Sparks, NV. Sold for $13200.00
A 12 in San Antonio, NM. Sold for $8241.00
Both auctions end on 3/14. :patriot:
Last edited by Retired BLM Rig on Tue Apr 03, 2018 7:17 am, edited 1 time in total.
Post by DamageWagon » Thu Mar 08, 2018 12:50 am
That 2012 is an exact copy of my 2011 and came from only a few hours away from where mine did. I guess they like PW’s in New Mexico
Post by Retired BLM Rig » Thu Mar 08, 2018 9:21 am
That one needs a T-case too. :sick: There must be some connection. ;)
Post by Retired BLM Rig » Mon Mar 19, 2018 1:13 am
This 2005 is in Brewerton, NY, so you east coast guys have a chance on this one.
It says that the battery is dead and may need other repairs. With only 83285 miles, I bet if you put a battery in, it would drive away. If nothing else it could be a good parts truck for someone.
Current bid $3510.00, ends in 3-1/2 days.
Edit: This ended up selling for $8915.00
Last edited by Retired BLM Rig on Tue Apr 03, 2018 7:12 am, edited 1 time in total.
Post by adeluca73 » Tue Mar 20, 2018 10:15 pm
Says the winch is rusted and cable won’t come out...wonder if a good dousing in PB Blaster would free the winch cable? Current bid $5K...tempting
Post by coder » Wed Mar 21, 2018 11:20 am
If the winch goes in but not out it's most likely the thermal disconnect switch is not working it can be easily bypassed. It's a common problem on early 3rd Gen PW's. I did the bypass as a preventative measure not to long after I got my truck, see my signature below "Winch Thermal Protection Bypass".
Post by adeluca73 » Wed Mar 21, 2018 1:45 pm
It’s now at $5500, much higher and that 13yr old truck suddenly gets far less attractive
yooper68
Post by yooper68 » Thu Mar 22, 2018 11:07 am
Wow! - That 2005 is almost the same as my 2003 except I don't have the PW package.
I do have more rust on the body/fenders but the interior & topper on mine are nicer.
I would say it is worth $5500 if that is the price range someone is looking for.
Trucks: 2003 4x4 Dodge 3/4 ton, 1972 4x4 Ford 3/4 ton (factory hi-boy), shopping for new Power Wagon (or may wait for 2020 model? - 75th year special edition?)
Post by TwinStick » Thu Mar 22, 2018 2:11 pm
If the lockers work, it is worth more than current bid in spare parts !
Post by Retired BLM Rig » Sun Mar 25, 2018 3:18 pm
Next vehicle for your consideration: A 2010 with a lovely three tone paint scheme, high milage and missing parts, in Eldorado Hills, CA. :vomit:
This ended up selling for almost $15K. :jawdrop:
Maybe the brown stripes were just vinyl stickers.
Post by Retired BLM Rig » Sun Apr 08, 2018 12:22 am
Here's a 2012 in West Valley City, UT. with Ramboxes. 135K miles.
I see a winch cradle but no hook or cable.
Post by DamageWagon » Sun Apr 08, 2018 2:02 am
I wasn’t planning on buying another truck but man that could be a solid deal
stooper
Post by stooper » Mon Apr 09, 2018 8:37 am
When i got mine the winch cable was still zip tied to the drum.
Post by Retired BLM Rig » Fri Apr 13, 2018 10:34 pm
Less than 12 hours to go, holding at $9700 for the last couple days.
Post by adeluca73 » Thu Apr 19, 2018 11:03 am
2012 DODGE RAM 2500
Sale-Lot Number:
81QSCI18155015
City, State:
Current Bid:
17,890 USD
Bidders:
13
Close Time:
04/14 12:11 PM CT (Closed)
Time Remaining:
Sold for below fair condition book value...
Post by Retired BLM Rig » Thu Apr 26, 2018 8:59 pm
Another 2010 in Eldorado Hills, CA.
Lower miles than the last one, but it has a dimpled tailgate, tweaked front bumper and a missing console/seat, just to name a few obvious things.
Post by Retired BLM Rig » Sun May 13, 2018 4:12 pm
A 2011 in Taos, NM.
This one may go cheap due to the holes in the body, unless you got creative with stickers, emblems, massive fender flares or a wrap to cover them up.
It looks like one of DamageWagon's siblings.
Or there's this 2012 in Coeur D Alene, ID. that appears to be intact.
