Body Mount Torque Specs?
NickTF
Post by NickTF » Fri Nov 02, 2018 1:40 pm
I have a 2015 with a long over due body mount pair needing replacement (part of the clunking body mount tsb). What are the torques specs for:
1. The large bolt which travels through the center of the body mount
2. The two nuts which fasten the body mount to the frame perch
Thanks.
Re: Body Mount Torque Specs?
Post by Reloaderguy » Fri Nov 02, 2018 2:10 pm
90lbft and locktite.
NickTF
Post by NickTF » Fri Nov 02, 2018 4:06 pm
Anyone have a spec for the nuts which fasten the mount to the frame perch? If not common sense is the number!
Post by 2wagons1driveway » Fri Nov 02, 2018 5:57 pm
Lol oooo only 90ft lbs :/ I had some loosen off after boogie mode was engaged so I torqued them down to fifty dugadugas
NickTF
Post by NickTF » Thu Nov 08, 2018 8:24 am
Replacement body mounts are in. Solved a whole lot of clunking I was experiencing.
Post by DamageWagon » Thu Nov 08, 2018 4:25 pm
2wagons1driveway wrote:Lol oooo only 90ft lbs :/ I had some loosen off after boogie mode was engaged so I torqued them down to fifty dugadugas
Could you convert that? Most of us here aren’t on the metric system
Post by 2wagons1driveway » Fri Nov 09, 2018 10:51 am
It’s universal
The dugaduga is universal Image
Bigdodge
Post by Bigdodge » Fri Nov 09, 2018 12:45 pm
Can u offer some details about this tsb? I have a 15 and it's the first I've heard of it.
NickTF
Post by NickTF » Fri Nov 09, 2018 12:50 pm
https://www.cumminsforum.com/forum/2013 ... lexes.html
**Bulletin # 23-033-15**
SUBJECT:
Rattle/Clunking/Popping Noise While Driving Vehicle On Uneven Roads
OVERVIEW:
This bulletin involves replacing the frame to body cushion isolators located under the right
and left cab A-pillars.
MODELS:
2014 - 2015 (DJ) Ram 2500 Pickup
NOTE: This bulletin applies to vehicles within the following markets/countries:
NAFTA
NOTE: This bulletin applies to vehicles built on or before April 18, 2015 (MDH
0418XX).
SYMPTOM/CONDITION:
The customer may describe a rattle/clunking noise or popping that can be heard and felt in the floor under the front passenger or driver side when the vehicle is driven on uneven roads, especially from a higher level to a lower level. Noise may be more audible at cold
temperature.
DIAGNOSIS:
If the customer describes the symptom/condition listed above, perform the Repair
Procedure.
PARTS REQUIRED:
Qty. Part No. Description
2 68224164AB CUSHION, Body Hold Down"
NickTF
Post by NickTF » Fri Nov 09, 2018 1:10 pm
Part number is now 68224164AC.
Bigdodge
Post by Bigdodge » Sun Nov 11, 2018 9:42 am
Awesome, thanks for that info.
NickTF wrote:Part number is now 68224164AC.
cb1987
Post by cb1987 » Fri Nov 16, 2018 1:17 pm
book says 80lb on the bolt and 50lb nut
NickTF
Post by NickTF » Fri Nov 16, 2018 2:20 pm
I like to party......
