Custom Carli/Deaver rear leaf springs ?'s
Heavy Duty Parts for Heavy Duty Trucks
Moderator: Skyd Ram
Locked
Post by TwinStick » Tue Oct 02, 2012 8:38 pm
Are the ones made for the diesel stiffer, to support more weight than the ones for the Hemi ? The part #'s are different, so i am thinking there is some kind of difference. What is it ??? :cheers:
Skyd Ram
Re: Custom Carli/Deaver rear leaf springs ?'s
Post by Skyd Ram » Tue Oct 02, 2012 11:30 pm
They're the same leafs. THey have 2 part numbers since the Hemi trucks use 3.5" u-bolts as opposed to the Diesel's 4" u-bolts.
Post by TwinStick » Wed Oct 03, 2012 6:46 pm
Thanks for clearing that up.
Locked
