Power Wagon Shocks
Heavy Duty Parts for Heavy Duty Trucks
Moderator: Skyd Ram
Locked
Skyd Ram
Power Wagon Shocks
Post by Skyd Ram » Tue Aug 28, 2012 11:47 pm
Hey Guys!
Here is a Bilstein 5100 shock package that we have been doing for the Power Wagons for a few years now. They also work on standard 2500's that have 3-5" of lift.
Because the Power Wagons run longer shocks both due to the additional lift and increased articulation you will need different shocks that most companies or sites will suggest. The rear shocks in this kit have more compression valving in them as compared to the othe Bilstien 5100's that are spec'd for the Dodge 2500/3500 series trucks.
http://www.8lugtruckgear.com/Dodge-Susp ... -p267.html
For something more high performance and better riding than the 5100's we offer the Performance 2.0 shock package ($1330) from Carli that uses custom valved 7100's. Another great option would be the Carli Pintop 2.5 shock pacakge ($2225) witch uses custom King 2.5's with Carli's own in house piston and valving. Both of these packages include the resi mounts, limit strap kit, and all hardware.
Locked
