Board index General Member Builds
Re: Power Wagon Parts
Postby jailor97 » Sat Jan 21, 2017 11:23 pm
Forgive my ignorance, but why is it a big deal that the drum rotates in a different direction?
more to come...
jailor97
Postby TwinStick » Thu Feb 02, 2017 12:28 am
I don't think it is, personally. But what made it a big deal is Dodge/Ram wanted one made to "their specs". That way, you have to go to them for service....at least I think that's what they were thinking. Many of the specs on our winches, are the same as the M15000. Some speculate it is just rated lower for liability reasons. Ours do have a LVI (low voltage interupt) and a TPS (thermal protection shutdown) circuits on them. That is also a Dodge/Ram thing---not on the M15000. Liberals, trying to save us from ourselves ? :lol: Or someones idea on how to gouge the customer for more $$$$$ when it fails, later down the road ?
Postby Retired BLM Rig » Thu Feb 02, 2017 8:09 am
jailor97 wrote:Forgive my ignorance, but why is it a big deal that the drum rotates in a different direction?
It's not a big deal, it's done out of necessity so that the cable feeds from the top of the drum rather than the bottom for correct clearance and positioning behind the front bumper for the application. (I think) :run:
Postby TwinStick » Thu Feb 02, 2017 7:02 pm
Postby TwinStick » Wed Mar 22, 2017 6:45 pm
Front driveshaft/Propeller shaft
https://www.napaonline.com/en/search?te ... orm-newveh
NOTE: There IS a difference in length of the d-shaft on a manual transmission & auto transmission. Manual trans front d-shaft is 16.5" (transmission is 3" longerr) than the auto transmission, who's front d-shaft is 13.5".
Postby TwinStick » Sat Jul 29, 2017 10:07 pm
Factory Transfer Case Shift Linkage
http://www.ebay.com/itm/Dodge-Ram-Truck ... 0909487498
Mopar Part # 55366066AB
Or you can make your own set up using a turnbuckle that is closed on both ends & adding your own jam nuts, bolts, washers, nuts & bushings. Like seen here, in the top left corner: https://www.google.com/search?biw=1440& ... cDvJ4gBgVM:
Previous
Return to Member Builds
Who is online
Users browsing this forum: Google [Bot] and 1 guest
