6.1L or upgrades
Saltzbaseball
6.1L or upgrades
Post by Saltzbaseball » Sun Dec 30, 2012 9:48 am
Hey I'm new to this fourm and I'm really looking ro get a power wagon but I haven't decided yet. I just wanted your guy's opinion on do you think that the 5.7 needs some help? Aka does it lack power?
Thanks Brandon
sent from somewhere on a back road in the middle of speed therapy
TrueCowboy426
Re: 6.1L or upgrades
Post by TrueCowboy426 » Sun Dec 30, 2012 4:52 pm
I have a 6spd manual truck, and by all rights, the 5.7 in stock form is more than adequate for me and does what I want out of it. However being as I am someone who can't leave anything stock and I always need more power (insert Tim the Toolman grunt here) I'm going to cam the truck and I might get the heads milled a little while I have it tore apart. I'm going with a KRC 210X, which will add a fairly significant amount of low end torque that will help me out both off road and while pulling my trailers.
Post by TwinStick » Mon Dec 31, 2012 10:17 am
I too have the G56 6-speed manual. I tow at max load of 10,500 lbs. My engine is the old 345 hp Hemi. New ones are like 390 hp. I have no issues so far what-so-ever. Mine is more than adaquate as well---so far. We always want or are looking for more power though, whether we need it or not. It is not the Hemi that is the issue, it is the transmissions. The new ones are 6-speed autos----but IMHO not really, they are actually 4 speeds with 2 overdrives. So, basically it is a 4 speed. There is absolutely no damn reason to do that. It is not just Dodge doing that either, they all do it. Seeing as it is already a "6-speed", all they would need to do to make the best trans EVER, is to have the gear ratio's the same as our G56. Ours are true 6 speeds. We have only one overdrive. Here are the gear ratio's so you can compare.
G56-------1st) 6.29:1----2nd) 3.48:1----3rd) 2.10:1----4th) 1.38:1----5th) 1.0:1----6th)0.79:1----Rev) 5.74:1
6sp auto-1st) 3.23:1----2nd) 1.67:1----3rd) 1.50:1----4th) 1.0:1------5th) .75:1----6th) .67:1---rev) 3.0:1
So it seems that the auto trans are geared for mpg & NOT HD work. This is why many people think they need a diesel to haul 5000 lbs. The Hemi is a VERY capable engine ------IF it is paired with a capable transmission with the proper gear ratios. If Dodge would make a 6-speed auto trans with the G56 gear ratios, it would quickly become the go-to truck & trans for those who want HD capability without the added cost of a CTD.
Throttle 8
Post by Throttle 8 » Tue Jan 01, 2013 5:16 pm
TwinStick wrote:I too have the G56 6-speed manual. I tow at max load of 10,500 lbs. My engine is the old 345 hp Hemi. New ones are like 390 hp. I have no issues so far what-so-ever. Mine is more than adaquate as well---so far. We always want or are looking for more power though, whether we need it or not. It is not the Hemi that is the issue, it is the transmissions. The new ones are 6-speed autos----but IMHO not really, they are actually 4 speeds with 2 overdrives. So, basically it is a 4 speed. There is absolutely no damn reason to do that. It is not just Dodge doing that either, they all do it. Seeing as it is already a "6-speed", all they would need to do to make the best trans EVER, is to have the gear ratio's the same as our G56. Ours are true 6 speeds. We have only one overdrive. Here are the gear ratio's so you can compare.
Agree 100%!!!!! If they made an auto with these ratios I would get one. Until they do I will keep this truck until they bury me in it!
Saltzbaseball
Post by Saltzbaseball » Fri Jan 18, 2013 7:04 am
Thanks for all replies
twistedpw
Post by twistedpw » Sun Jan 20, 2013 8:56 pm
i wish i went for a 6.1l when i had the chance but i could not find one that was a good deal at the time i needed an engine, and the computer won't run the 6.1l properly with out losing the PW program upgrades. but now that i think of it i wish i spent the money for a 6.1 :doh:
06 White POWER WAGON!
Pure Performance control arms
Flexalite e-fan
Rock-rails (by me)
Diablo sport tuner
Rock Monster beadlocks
BFG KM2's
Airflow snorkel
Bed rug
Bilstein 5100's
Thuren coils & shackels
