SimonandSimonBeast Build
SimonandSimonBeast
Re: SimonandSimonBeast Build
Post by SimonandSimonBeast » Sun Dec 01, 2019 11:48 am
TommyG wrote:We may need a Wagons on OBX event some year. We camped in Frisco woods for years and have rented houses in Frisco, Buxton and Avon. My in-laws talked me into Corolla and Corova a few years ago and we really liked it up there too. Love being there.
SimonandSimon Beast nice truck and choices on your build.
Thanks TommyG. PWs in OBX sounds like a good idea. I usually rent soundside so I have direct water access and great sunsets. Last time in Ocracoke we got a house directly on the sound with a dock. There are Carolina Skiff rentals out of Silver Lake Harbor, you pilot it around to the house and dock it there for the week. Opens up a whole new frontier for the trip.
:rockon: :chug:
TommyG
Post by TommyG » Sun Dec 01, 2019 1:09 pm
Have not been on the water in the sound. We just try to stay near a ramp to the beach so we can drive out and surf/play on the beach all day. It would be cool to explore via the water too. So much to do there you could spend a lifetime and not get bored.
TommyG
Post by TommyG » Sun Dec 01, 2019 1:11 pm
Sun Dec 01, 2019 11:05 am
TommyG wrote:
Sun Dec 01, 2019 9:49 am
My brother been gong there for years. We just started to go with him the last 2. We like it up there too.
Idea. Rent a house in Oct when it's cheaper, and have everyone pitch in.
Fall is the best. Have had some amazing Halloween trips there over the years. Warm water, decent weather, low prices and you have the place to yourself.
Post by RustyPW » Sun Dec 01, 2019 1:14 pm
When we was there in early Oct. Hardly anyone was there during the week. We had the whole section of beach to ourselfs.
SimonandSimonBeast
Post by SimonandSimonBeast » Sat Jan 25, 2020 2:22 pm
Purple Cranium Spider diff guards installed front and rear.ImageImageImage
:rockon: :chug:
ghaugo
Post by ghaugo » Sat Jan 25, 2020 5:26 pm
Looks awesome! I really like that color.
Frame-welded Aluminess Rock Sliders(welded to frame), Cooper STT Pro 315/70/17, ARE Z-Series Topper, FilterMag GP101 (front and rear diffs), DeeZee Tailgate Assist, Skanda Kryptec Typhoon seat covers, Husky X-act Contour Mats, Purple Cranium Diff Covers Front and Rear, Dodge Offroad Steering Brace, K&N air filter, Thuren Track Bar, Thuren Short Arms, Thuren Overland Shocks, Airlifter Ultimate 5000 airbags, Daystar Cradles, High Country Customs Bumper, Dynatrac ball joints, All AMSOIL fluids from Code4Synthetics.com
SimonandSimonBeast
Post by SimonandSimonBeast » Sat Jan 25, 2020 10:05 pm
ghaugo wrote:Looks awesome! I really like that color.
Thanks. It's Hammertone Candy Red powder coat w/another clear powder coat. I figured being in rustylvania I would pay a little extra for more coats. Black decals.
:rockon: :chug:
Post by RustyPW » Sat Jan 25, 2020 11:21 pm
First stone chip and they're done. :roll:
SimonandSimonBeast
Post by SimonandSimonBeast » Mon Jan 27, 2020 3:55 pm
I figure by next year it will be black Rust-Oleum rattle can like everything else under there.
:rockon: :chug:
SimonandSimonBeast
Post by SimonandSimonBeast » Wed Apr 22, 2020 9:42 pm
Carli ball joints on the way from CJC Off-road. To arrive Friday and installed Monday by my awesome local mechanic, Spaniel's in Hatfield, PA. Maple sliders should be on the way too. Maple skid coming later. Trying to keep the these guys in business.
:rockon: :chug:
SimonandSimonBeast
Post by SimonandSimonBeast » Fri Apr 24, 2020 5:06 pm
Just arrived...Carli Ball Joints.Image
:rockon: :chug:
Post by RustyPW » Fri Apr 24, 2020 9:22 pm
I got them. :rockon: 2 things. When installing the bottom ones. Make sure of the position of the grease fitting. You want to be able to get to it with a grease gun. And speaking of grease. Be careful on how much grease you inject. Because you can hydrolock the joint. Making the joint hard to turn.
SimonandSimonBeast
Post by SimonandSimonBeast » Sat Apr 25, 2020 9:31 am
Thanks Russ. CJC has a good video on it. Very detailed. I am also surprised about the detailed COLOR instruction that come with it. My truck is behaving a bit "darty" up front. Seems to be getting worse. I'm hoping this resolves that. Still on the stock joints at 60K+ miles. I've read where people recommend 86ing them at 20K.
:rockon: :chug:
Post by FirerescuePW » Sun Apr 26, 2020 10:19 pm
How is your track bar? That'll make it a bit darty, too.
Is Spaniel's doing the work this week? My shop is about 5 minutes from theirs.
SimonandSimonBeast
Post by SimonandSimonBeast » Mon Apr 27, 2020 12:32 am
Dropped it at Spaniel's last night. Orvilla Rd & Welsh Rd. Will be worked Monday. I have a Thuren bar and Thuren 3" system I put on last year. Bolts are tight. I did notice the axle wasn't centered. It's at least an inch to the left. It seems like the bar needs to be lengthened a bit at the heim. It's confounding though. It didn't seem like that for the better part of the year after I installed it. I'm kind of wondering if they will find something else wrong. There's no clunking, or anything obvious that way.
:rockon: :chug:
Post by RustyPW » Mon Apr 27, 2020 9:04 am
It took me a while in adjusting the trackbar to make everything even. I put a 6ft level up against the tire sidewall and measured off of that.
SimonandSimonBeast
Post by SimonandSimonBeast » Mon Apr 27, 2020 9:15 am
Yesterday I was under there looking at where the boogies line up with the pads on the axle. It's off by at least an inch to the driver side, meaning the track bar should be lengthened to push it to the passenger side. I'm thinking the ball joints are bad too, compounding the problem. So, it's a good time for my mechanic to get the ball joints in, then check how much the track bar is out. Fix that and align. I have him checking brakes and bearings whilst it is all apart...might as well.
:rockon: :chug:
SimonandSimonBeast
Post by SimonandSimonBeast » Mon Apr 27, 2020 9:22 am
The level off the tire sounds like a good idea. Maybe measure to a known point on the frame above the tire. I've read the bodies can be off center, so a frame point would be better for driveability. My mechanic has the scoop though. He'll figure it out and get it squared away. A couple of the guys that work there drool when they see my truck pull in. Big Power Wagon fans.
:rockon: :chug:
SimonandSimonBeast
Post by SimonandSimonBeast » Tue Apr 28, 2020 7:57 pm
Got the truck back today. Everything is much tighter. The trackbar had to be run out quite a bit further than Thuren's recommendation to get the axle centered. Old ball joints had some side to side slop particularly in the lowers. One upper was seized in pretty good due to corrosion. All in all this is a piece of mind to have done.
:rockon: :chug:
SimonandSimonBeast
Post by SimonandSimonBeast » Tue Apr 28, 2020 8:01 pm
Maple sliders coming Thursday. Now I know one of the things I'm doing this weekend. Away with the chrome OE steps, in with the solid steel Maples.
:rockon: :chug:
SimonandSimonBeast
Post by SimonandSimonBeast » Thu Apr 30, 2020 1:53 pm
It's a work from home day...shhh...don't tell anybody it's a work on the truck day. Mapes got here via UPS Freight. Removed the old OE steps to get ready for Sat install...some pics:ImageImageImageImageImage
:rockon: :chug:
Post by Colibri » Thu Apr 30, 2020 5:35 pm
Loving the truck sir, just wanted to mention something about the adjustable track bar, at least on the third gens the thuren/carli recommendation for length did not center the front axle. It had to sit to one side at ride height so that the axles spring perch wouldn’t crash into the trackbar bracket on the frame at full bump. I don’t know about interference issues on your generation of truck specifically, but you might want to check and make sure nothing is going to hit at full stuff with a centered axle
SimonandSimonBeast
Post by SimonandSimonBeast » Thu Apr 30, 2020 6:06 pm
Thanks for the compliment. That's good to know man. I wasn't thinking about that. I think mine was extreme to the left. I could see 1.5" more reveal on my left tire. The left boogie was lined up above the left side of the pumpkin. My Thuren swaybar links were slanted over. It wasn't like that for a while after I originally installed the system. I'm guessing when I did some winter wheeling with the bar disconnected I really had things twisting up. It must have caused things to settle in. I get what your saying though. I think I will have to disconnect and run it up a boulder somewhere to see if there are any clearance issues. Hopefully, we didn't adjust it too far.
:rockon: :chug:
SimonandSimonBeast
Post by SimonandSimonBeast » Sat May 02, 2020 2:29 pm
Sliders done...I need a beer! That's Lucy in the one pic. She thought I put down the blanket for her. These things are stout. Thumbs up to Neil at Maple Off-road ImageImageImageImageImageImageImageImageImage
:rockon: :chug:
Post by Mule007 » Sat May 02, 2020 3:31 pm
:cheers: Looking good! Lucy looks like some pretty good help !
2005 Mineral Gray; #0666: Laramie, Leather, power/heated seats, dual cab control zones, Alpine 9 speaker surround sound, steering wheel cruise, music & volume controls, 6 CD player, AC; dark charcoal & silver interior.
Tools: 60” Extreme High Lift; hand tools, tow straps, shackles, chains, cables, off road rigging, F & R tire chains, spare water & 2 rear wheel well NATO 20 L narrow gas cans.
Updates: New Jasper Remanufactured 5.7 Hemi Engine (3 yr/100’000 mi warranty), Open Range All Terrain 35 x 12.5 x 17 MP3 10 ply E tires; McQuay-Norris Extreme ball joints (upper & lower); fuel pump; 1 ton HEMI transmission cooler; OEM radiator; front axle, driveline U-joints; Denso 180 amp alternator, Interstate Mega-tron 850 CCA HD battery; water pump & serpentine belt; Bilstein 2 5100 shocks & steering damper.
