Diesel PW Build Thread
Re: Diesel PW Build Thread
Post by nts007 » Sun Jan 21, 2018 10:42 am
Sun Jan 21, 2018 9:38 am
nts007 wrote:
Sat Jan 20, 2018 8:19 pm
Sat Jan 20, 2018 7:22 am
WOW, bright! Do they come on when the truck goes in reverse, or wired separately on a switch, or both?
Wired them into the reverse circuit. Seems like work to have to remember to flip a switch lol
Ha. Well I suppose it could be handy once in a while to have the lights on WITHOUT the truck in reverse.
Yes but I had to have the most installed in an hour. No time for fancy wiring then. Later I'm going to change them up. Likely will get a better flood pattern and change the out later. These though have been awesome so far though
Post by nts007 » Sun Jan 28, 2018 4:00 pm
Alright!! Shits getting real. If I'm gonna make Moab this year then it's time!!
Post by olyelr » Sun Jan 28, 2018 6:13 pm
Wowzer weezer whatchya doing, going for one of these?
:lol:
Post by Retired BLM Rig » Sun Jan 28, 2018 6:33 pm
It's nice to see you working on your truck without snow as the primary background in your pictures. :rockon:
Post by nts007 » Sun Jan 28, 2018 10:06 pm
It is ridiculously awesome having the shop now. After so many years lying on my back in a snow suit (cause dodges always break when it's coldest out) finally can just coast around in a sweater. Have some tunes and NO WIND!!!!
:lol:
Nothing near as gaudy as that. Weekly progress just u wait😁
Post by Colibri » Mon Jan 29, 2018 10:25 am
Can’t wait to see what you come up with sir!
Post by Reloaderguy » Mon Jan 29, 2018 11:39 am
Canadian killdozer?
Post by TwinStick » Mon Jan 29, 2018 8:01 pm
:rofl: I remember that movie ! :lol:
Post by nts007 » Tue Feb 20, 2018 1:22 am
Progress!!! The uprights are 5/16 steel and the eventual body will be 3/16. Lots to go but the uprights clear the grill when the hood opens. Barely. Winch has about an inch of clearance behind it before it contacts the ac condenser.
gun45boat
Post by gun45boat » Thu Feb 22, 2018 9:49 am
Holy approach angle;) nice fab work
Post by nts007 » Sun Feb 25, 2018 12:55 am
Well a long day of measuring amd making stuff up here's where we are at as of midnight!! Tomorrow I pretty much need my truck driveable so extra motivation. I'm just hoping this turns out decent. So far I'm pretty happy. For clarification i am mostly making this up as I go!
Post by nts007 » Sun Feb 25, 2018 7:47 pm
Hell yea!!
Post by Bill2014 » Mon Feb 26, 2018 8:49 am
Looks like you are adding a fair amount of weight to that beast...
Post by nts007 » Mon Feb 26, 2018 11:13 am
Yep. Winch and cradle. And 120lbs ish of steel. But no worse than guys running ranch hand bumpers or fab fours
Post by nts007 » Mon Feb 26, 2018 11:16 am
The truck has sank down just under 3/8" total with it all installed. That's on thuren coils
Post by Colibri » Mon Feb 26, 2018 2:43 pm
Very mad max! I likey
gun45boat
Post by gun45boat » Mon Feb 26, 2018 5:09 pm
This is very good Fab work.. Great job man.. HUGE!!!!!!!!!!!!!!!!!!!!!!!
Post by nts007 » Mon Feb 26, 2018 6:06 pm
Thx guys!! Few more things to go but truck is now useable again
Post by nts007 » Fri Mar 02, 2018 10:05 pm
Hello hello!! Probably the only time the paint is going to look new. Ever. But it's done! I'm keeping it like this. Picked up 2 sets of dot/sae fog lights from rigid. One set is set up as proper fogs and the second is tied into the high beam circuit shooting on the same plane as the high beams but playing out to near 90°. They work awesome. I also have a pair of vision x Optimus helping out the basic range of the high beams. They and the secondary rigids are tied into high beams and function only with them. I cut up a spare factory fog light wiring harness and tied the main set of rigid fogs into the factory system. It works flawlessly and the overall patterns are excellent. Especially compared to the factory. Bumper is pretty much done. I still have to drill in 2 holes for the recovery shackles but aside from that it's done for now. The winch is all wired up using the factory pw harness. When it acts up I'll thermal bypass but untill then it's good. The positive cable was too short by 2 inches. So I bought a short 8" connector designed for connecting batteries.
I would estamate the bumper weighs about 150lbs based on a semi rough estimate of plate by the square foot. The winch and cradle is another 150-160ish. You notice the weight but it's made the front ride smoother so I won't complain. The front sagged about 3/8" overall from having no bumper at all.
I am happy!! And hope to never have to do this again.
Well I still have to do the rear bumper..... here's some final pics and some beam shots a single rigid unit
Post by Colibri » Fri Mar 02, 2018 11:17 pm
Great work!
Post by DamageWagon » Sat Mar 03, 2018 3:21 am
You’ve done more in a weekend with cardboard, grinder, flux core than several serious companies have with years of design, CAD, laser cutting and forming.
w2dodge
Post by w2dodge » Sat Mar 03, 2018 10:49 am
:rockon:
Post by nts007 » Fri Mar 16, 2018 1:29 pm
Moab is comin fast. Time to get the rear of the truck cleaned up. List of maitnance is huge lol
BoldAdventure
Post by BoldAdventure » Fri Mar 16, 2018 2:41 pm
Chop Chop buddy
Post by nts007 » Fri Mar 16, 2018 6:22 pm
Chop Chop buddy
The important stuff is done. Passport and those American pesos. Sliders and redoing steering is on the agenda.
