Diesel PW Build Thread
Re: Diesel PW Build Thread
Post by nts007 » Sat Apr 29, 2017 5:47 pm
40x40 with 12' ceiling. 3 doors. 12x10, 10x9 and a 9x7 inside between the workshop and the rest of the area.
I hope I wasn't confusing. I have the wagon frame and chassis still here at home. I'm heading 3.5hrs away to get a reg cab Long box 2500 cummins with no motor or tranny.
Post by nts007 » Sat Apr 29, 2017 6:03 pm
I got bored so decided to double up my ditch lights. Only because I had them and they have been sittin for 4 years in their box. But still brand new lol
Post by nts007 » Sat Apr 29, 2017 6:58 pm
This is what happens when I am actually home on a freaking nice day. Was 14°C today. And practically no wind. So it was a productive day.
Post by nts007 » Sun Apr 30, 2017 6:04 pm
New project heading for home
Post by nts007 » Sun Apr 30, 2017 10:53 pm
Made it home. Big shout out to my new pal billy. It's thanks to him that this project will finally get under way.
Quick spec. 07 2500 ctd reg cab 6spd manual. With no engine or transmission or tcase. All good. I will be starting a separate build thread for this one. And thanks to mikekey and you Moab guys I now have instagram and have uploaded the majority of the progress to date. I will also do the new build in instagram as well. Find me under this username or dpw37.
Now we carry on. Off on another road trip tomorrow.
Post by nts007 » Sun May 21, 2017 3:16 pm
Spent time today working on my onboard air setup. I had picked up an air ride compressor and controller awike ago but have done nothin with them. I did all the plumbing today but there was a storm moving in and wind picked up so I didn't get to the wiring or controller.
The way it's set I can either let the pump run the air bags or fill the air tank. Also with the lever adjusted to the tank fill position I can manually fill the bags from the shrader valve. Or fill the air tank from the second shrader valve. The air bags are always in a sealed condition regardless which way the lever is switched. The tank is an old one I've had for years and pretty much had everything i needed to do this with stuff I've collected or bought over the years. The only thing I didn't get to was an air hose quick connect. Which will draw from the air tank only. Hopefully next weekend is good and I can get the test finished up.
I actually started the day planning on doing the leaf spring swap. But after removing the first leaf from the truck I inspected the other leaves and saw that the bushing is really cracked up bad so i put everything back together. Thuren leaves it is. Wife gave me permission if I can sell the old hemi tranny I have here.
Post by nts007 » Wed Jun 07, 2017 3:27 pm
Been awhile since I got anything done on this bad boy. Finally tackled the end of two projects. I eliminated my svc 4wd light and abs light. I also finished wiring up the controller for the air lift pump/gauge
So after a careful disassembly I got the dash cluster out. Only to find no access to most of the bulbs from the back side. No matter I'll just pull the cover off and expose the bulbs and pull them from the front
Well that just got me the stupid circuit board. And then to pull it off you need to take off the gauge needles!! Uh oh this just got more iffy
Well that worked and exposed the lens.....and lo and behold. No bulbs. Leds on the circuit board!!! Ahhhh fuk
So I had to come up with a solution. To block the lens. Tape? No. Sharpie?? No. How about some rustoleum??? Sure. But I couldn't spray it. So I used a piece of shrink wrap as a straw and proceeded to add drops of paint into the lens until it was fully coated. Let it dry and bingo. No light transfers through.
Then I tackled the gauge for the air controller. Used my spare console cubby since I no longer have a electric 4wd switch and decided this was a good place for it. Used a piece of plexi as a cover plate and got it all figured and mounted up. It was less exciting. But it's all done up now and the pump inflates the bags and deflates right from the gauge. It's much slower than the external valves but it works in a pinch
Post by nts007 » Sat Jul 01, 2017 12:23 am
Alright so crazy update. Finally decided to deal with my rocker panel sandblasting issue. And some of the horrible door rust I'm getting on the inside of the door panel bottoms.
Used por15 for a rust encapsulation paint today. Prep took forever. First washed the area all down by hand and wire wheeled all the rust and loose paint. Then used por degreaser cleaner. And then their metal etch prep. And then coated with por15. Turned out really nice. Now this is not the finish coat. I am putting Bedliner now on all the lower exterior and exposed areas. Also cleaned up over the fender spots that tend to rust out on our trucks pretty easily. Tomorrow I plan on doing the Bedliner. Here's some pics
Post by Colibri » Sat Jul 01, 2017 7:38 am
That is a crazy amount of paint damage! Living off the beaten path can take its toll. The por15 looks great, the two tone with bedliner is going to be very nice! Maybe I'm a little crazy, but that lime green tape makes me think a paint stripe of the same color would be wicked! Good job man!
Post by nts007 » Sat Jul 01, 2017 12:00 pm
Thanks colibri! Figured I want at least 5 more years outta this truck so might as well do something that may work. The green stripe isn't that bad lol. I was almost thinking I should just do it in plasti dip so I can change the colour whenever. I got the first coat of Bedliner done. Going to be going extra thick so one more heavy coat. Man does that por15 have a nice glass finish.
Post by nts007 » Sat Jul 01, 2017 2:48 pm
And finished!!2 heavy coats of Bedliner. Under coat of por15. Fingers crossed this works. But I can't drive the truck for 48 hrs now.
Post by nts007 » Sun Jul 02, 2017 10:43 am
There we go. Fenders back on. Door seals back in. One more day before I can drive it.
Post by olyelr » Sun Jul 02, 2017 12:07 pm
Holy shit, the amount of stone chips on those rear quarters is unbelievable. And here i am whining about a half dozen or more of them lol.
Great job!
Post by Colibri » Sun Jul 02, 2017 1:17 pm
Looks great man!
I just realized what the green tape was reminding me of, that single cab concept power wagon on 40's from a few years ago.
Speaking of single cabs, can't wait to see what you're doing with the new truck :rockon:
Post by nts007 » Sat Jul 15, 2017 4:46 pm
Colibri you think very much like me haha.
Small update. Not exactly Pw related but my new transport system to bring down the project wagon and a camper down to Moab and back again. Super stoked on this trailer. The rear 9' is a hydraulic ramp that can lift 10k alone. Trailer is a 32' with tandem twin 12k axles. Rated at 25k. Oh and empty it's 7900lbs hahaha. Lookin forward to putting it to work
Post by nts007 » Wed Jul 26, 2017 8:39 am
So I bought something. Something to help make the truck better and more survivable on my horrible roads. It'll be here in a week......
Post by Colibri » Wed Jul 26, 2017 8:57 am
You're fond of playing "just the tip" eh? Such a tease :rofl:
Post by nts007 » Wed Jul 26, 2017 10:24 am
It's makes life much more exciting. Never knowing which way it's gonna go haha
Post by nts007 » Wed Jul 26, 2017 12:35 pm
On a side note not playing just the tip, by Friday I'll have an order in with mr thuren for a set of king 2.5s........ :D
Post by Colibri » Wed Jul 26, 2017 1:51 pm
Shit yes!!!!! Congratulations man :rockon:
MikeKey
Post by MikeKey » Wed Jul 26, 2017 1:54 pm
Could have gotten 3.0's
Post by nts007 » Wed Jul 26, 2017 2:36 pm
I'm already lookin at about $3500 for the 2.5s. I don't want to spend too much more on this truck. I need the money for a linked rear wnd on the reg cab with 3.0 coilovers....
Post by nts007 » Fri Jul 28, 2017 7:23 pm
Shocks and boogies ordered! I'm already impatient. I want them now not in 2.5 months! Gonna be snow when they get here
Post by nts007 » Tue Aug 01, 2017 10:55 pm
The teasing is over!!
:doh: :doh: :cash:
Post by DamageWagon » Tue Aug 01, 2017 11:02 pm
300 pounds of unsprung weight goodness! [emoji23] can't beat the price though like you said. You going to get me that work visa so I can emigrate to your country and weld it on for you? lol
