BUILD THREAD COMMENTS
Locked
Re: BoldAdventures 2015 Power Wagon Build
Post by Reloaderguy » Thu May 12, 2016 11:47 pm
That bumper looks ruined, you better get that Mercenary Offroad bumper ordered ASAP!
It's amazing how loud those Duratracs are isn't it? I think I might need a diff cover now. :D
Post by Will » Fri May 13, 2016 6:40 am
You can get a new bumper shell for $400 or less if you want to keep the factory look. Also, they're not that hard to tweak. The bolt holes that hold the "shell" on have plenty of movement in them for up/down and side to side.
On your rear tire. It looks fine, did you check to make sure it would clear the rear diff cover and full compression, that would be the only thing I can think of the make sure of. Looking good with those tires.
Post by Colibri » Fri May 13, 2016 9:38 am
She's looking good on the new rubber! :rockon:
2011TXPowerWagon
Post by 2011TXPowerWagon » Fri May 13, 2016 10:52 am
How did you get that hook strap?? I want one
Post by FirerescuePW » Fri May 13, 2016 11:06 am
2011TXPowerWagon wrote:How did you get that hook strap?? I want one
Many of us have been trying for years....
Post by Reloaderguy » Fri May 13, 2016 11:20 am
Will wrote:You can get a new bumper shell for $400 or less if you want to keep the factory look. Also, they're not that hard to tweak. The bolt holes that hold the "shell" on have plenty of movement in them for up/down and side to side.
The spare might not clear the diff guards.
My bumper is crooked too. I figure I'll eventually have it off so why bother straightening it.
Post by olyelr » Mon Jul 04, 2016 3:57 pm
Whole bunch of awesomeness right there! So jealous!
Pit Slave
Post by Pit Slave » Mon Jul 04, 2016 7:39 pm
I think I will have to take at least one of those pics to post on my IG page.... :)
14PowerWaggy
Post by 14PowerWaggy » Mon Aug 01, 2016 3:13 pm
Is your 40" light bar the curved series or the regular one?
Post by BoldAdventure » Mon Aug 01, 2016 3:27 pm
Curved.
But I will be honest about my experience. With the LED Highs and HID's plus the dually's down low, there isn't a whole lot of additional light when I turn on the bar.
Chromolykid
Post by Chromolykid » Sat Aug 06, 2016 4:01 am
What all needed to be modified for the LED high beams?
“Furiosa”
2016 Power Wagon
White Knuckle Sliders
DOR Steering Brace
Thuren Stage 1 KING 2.5’s
Thuren Coils Front & Rear
AEV Procal
Post by BoldAdventure » Sat Aug 06, 2016 5:15 pm
Chromolykid wrote:What all needed to be modified for the LED high beams?
Just the LED's and patience. I almost gave up thinking they wouldn't fit, but then they just slipped in. First one I spent like 15 mins trying to figure out how to stuff the thing in there, the back side is pretty big. Lining it up is a bit tricky. But the other light took me maybe 4 mins since I figured out the angle I needed.
Post by olyelr » Wed Jan 11, 2017 10:25 am
Its about time for an update!
I recollect reading a post of yours in a past thread indicating you have onboard air (2 compressors I think?), but I didnt see any info about it here when scanning through.
I would love to see your setup. I need some motivational inspiration!
Post by BoldAdventure » Wed Jan 11, 2017 11:58 am
When it's not snowing, I'll update. Not crawling in the snow to take pictures. :P
Post by olyelr » Wed Jan 11, 2017 3:44 pm
Thanks!
How does staying in a travel trailer work in freezing weather? That has to be a little tricky.
Ours gets drained and put away in a barn before the snow comes around, so i have no experience with that.
Post by coder » Wed Jan 11, 2017 6:17 pm
Congrats on the house!
w2dodge
Post by w2dodge » Wed Jan 11, 2017 9:56 pm
congrats...lots of luck!!
yellowranger1
Post by yellowranger1 » Sat Jan 14, 2017 5:39 pm
I've only been to Idaho once, and it was a turn around trip when I picked up my truck from DD in Caldwell, passing through Boise. I loved it! Looks like a great place to live, lots of awesome scenery. Congrats
Post by olyelr » Thu Feb 09, 2017 11:09 am
Hey MikeKey, heres what your truck would look like with an AEV spacer kit, hutchinson beadlocks, 37s, rcv front and rear axles, dynatrac lockouts, 4.88 gears, 16.5 warn winch...
I know the AEV kit dont do anything for you, but the rest might! Nice truck!
Hammerballs
Post by Hammerballs » Thu Feb 09, 2017 1:57 pm
I like that a lot except the AEV lift. I have a 2016 Laramie PW in white as well. What are the rcv axles and dynatrac lockouts? Complete replacements of our stock axles and lockers?
2016 Laramie Power Wagon
rkgzx9leftcoast
Post by rkgzx9leftcoast » Thu Feb 09, 2017 2:03 pm
I know the Dynatrac lockouts are their front Hub Replacement - free wheel kit. a little spendy for sure, but a nice upgrade from the stock hub/bearing set up. Lets you free wheel front axles, and then have to lock in hubs like in the old days. Maybe someday.....
Post by olyelr » Thu Feb 09, 2017 2:14 pm
Post by BoldAdventure » Thu Feb 09, 2017 2:31 pm
Thanks for spamming my build thread.
Post by olyelr » Thu Feb 09, 2017 3:36 pm
My apologies, MikeKey. Although that was not my intentions, that is exactly what I did. I will delete that add.
Post by BoldAdventure » Fri Feb 10, 2017 5:58 pm
:poke: :thppt:
Locked
