olyelr wrote: ↑Wed Apr 04, 2018 7:03 pm
I think I read on another forum (that I am not signed up for) that you installed a Pedal Commander and highly recommend it. Is that the case and can you elaborate? If it really makes a big difference then I would like to spend the money for one, but if not then I dont want to even waste my time with it (it can be returned for a refund).
if you have ever felt disconnected from the engine, waiting for even a grunt, kick or gallop from the tires, longing for the stomach churning response of a hemi....you need it.
they work. have had them on turbos, supercharged, and NA vehicles, I6, V6, V8S, V8TT
it doesnt give you more power or make you faster(track proven it can improve times on certain vehicles with terrible transmissions), but makes your truck actually believe you when you say go.
Throttle mapping application can be thought of linear although its multi dimensional. 0-100%
these throttle amplifiers make 10-50% actually read 100$ to the truck. meaning the pedal will be more responsive in regards to being ready to kick down a gear.
with stock throttle mapping on our trucks, if you want to go pedal-to-the-metal and get the truck to kick down a gear, or fully gallop, you have to get lucky to be in the right RPM range in the Right gear at the right speed.....these pedal commanders convince the truck to kick down and get boogieing more so then factory tuning.
its not throttle mapping, and its not a tune but it helps a driver have more control over his transmission interacting with his engine in response to his input. its turns a tortoise into a jackrabbit
