2017 PW tires
Chrissy
2017 PW tires
Post by Chrissy » Sat May 13, 2017 7:20 am
Does anyone know if you can increase the stock goodyear wrangler 33" tires to M/T 37" grabbers and not have any rubbing. I'm considering upgrading and adding another 2" of offset to widen the stance as well. Also going with M/T headlock rims with black and painted flame red to match the truck. To accommodate the height I'll be replacing the mopar sidestep with a drop down unit so I can still get in. Any help would be greatly appreciated.
Re: 2017 PW tires
Post by Low_Sky » Sat May 13, 2017 10:53 am
Questions like this are better put in the general section where they will be seen. "Member builds" section is for look-what-I-did-to-my-truck threads.
Going to 37" tires on wheels with less backspace, you're probably going to have rubbing at the back of the fender wells that will require some cutting/beating/painting to clearance for.
2015 PW Laramie w/RamBox
Custom rock sliders
Re: 2017 PW tires
Post by DamageWagon » Sun May 14, 2017 10:32 am
These questions are answered directly on Thurens website under the Tech section. And this question has been discussed many times here already. I suggest using the search feature and really spending some time looking.
Re: 2017 PW tires
Post by Reloaderguy » Sun May 14, 2017 6:48 pm
33's are the biggest that will git. You may as well get a lowering kit for your truck.
Re: 2017 PW tires
Post by DamageWagon » Sun May 14, 2017 8:10 pm
Reloaderguy wrote:33's are the biggest that will git. You may as well get a lowering kit for your truck.
[emoji106]
Re: 2017 PW tires
Post by nts007 » Sun May 14, 2017 9:12 pm
:shock: that sounds risky. Might be best to go to a 265/70/17. Will never rub guaranteed :D
