nts007's Build - 2007 2500 Reg Cab Long Bed - BastardWagon
Post by nts007 » Mon May 08, 2017 11:32 pm
Alright guys it's time to start logging this new venture!! This build is going to be updated on Instagram fairly constantly as progress gets headway. #dpw37 #bastardwagon #budgetbuild
Alright let's talk goals
I've always wanted to do a near prerunner/ rock crawler/ hunting truck. Pretty much go anywhere at any time.
Now this is going to be somewhat of a budget build to an extent but at the same time it's gotta be good
Suspension is planned 18-20" rear and 16-18" front. But at ride height no higher than a 3" suspension setup
Rear is going to be a 4 link triangulated
Front will be a long arm possibly triangulated
Steering will be most likely be standard with hydro assist unless full triangulated <---for cost reasons. For now.
Power? As much as possible
Rear will be a spool and front will be a actuated locker of some kind
Tires will be 37"
Winch of course!!
And the truck must be as purely simple and as fun as possible!!!
I have been planning this for some time and have always wanted to do an old school big block powered truck
I picked up a 2500 reg cab long box 2007 for $500. It has no drivetrain other than the axles. Which are in ok condition. Which is fine because I have a set of 08 axles in excellent condition. And I have enough parts lying around to rebuild most of 2 trucks. But it's a base model with crank windows and it will be perfect!!
The engine is going to be a '75 Ford 460.....hold on. What!!!! Yea!! Why??? It was free. Well it was given to me 25 years ago by my father. In which I replaced the water pump, rad, thermostat, did an oil change and parked it with less than 20 miles of blowing down the country roads. Then I parked it and lost the keys. So why??? It's a big block!! And why not. Ford used to be good. Before 1980. Plus it comes with a c6 3spd tranny. With a 1:1 3rd gear. I can work with that. I also picked up an all mechanical Holley 750 carb and a fuel regulator. Why else? If this fits and runs and drives....it's easy to make 500 hp and 500ft/lbs. plus after 25years of sitting and shitty gas it started!!!! Easy to fix and maintain. I'm in
So what's next? Well lots of tube, rear coilover cantilever suspension (to preserve the box) and of course all the major regular issues.
I'm looking at either finding a way to install the nv273 tcase or.... A divorced axletech t600 from #western_canadian_rockwell
I'm going to stay with the 3.73 gear ratio from the diesel as the math using a 37" tire is equavalant to the original 28" tire with a 2.75 axle that the 460 was mated to.
Now comes more fun. This donor truck is a long box... But I have.. And extra short box from a quad cab that's a little dented and has a bunch of bullet holes (speed holes) in it. But it's still in decent shape. Being that I'm doing a link in the rear I have the chance to shorten the wheel base. <----let me know opinions on this one.
Alright enough with the talking. Here's some pictures to get it started. This project isn't going to happen overnight but it will happen. And the diesel build will also continue. And don't worry. No cheby parts :lol: :lol:
Ideas guys. I'm all ears.
That is a big engine
Re: #BastardWagon Build
Post by olyelr » Wed Dec 06, 2017 11:52 pm
Any progress?!
Post by nts007 » Thu Dec 07, 2017 12:44 am
In a sense yes!! I just bought it a new home! And been accumulating parts. Working with damagewagon on rear link design. Once I get set up in the shop better the truck will start coming apart. It's going to get exciting! Thanks for the post bump
Post by Colibri » Thu Dec 07, 2017 8:55 am
I’m so excited for this build!!!! Can’t wait to see some progress sir!
Post by nts007 » Sun Dec 17, 2017 11:36 pm
Got back my set of general grabbers from my dad who's been burning them off on his cummins now for a couple summers. I just wanted my rims back. Carli got some decent Carli parts to get started. Phase one will be a 2"ish carli kit using my old 7100s. This is just for testing of the drivetrain. Once it's all bolted up and working well it's coming back apart for.......links and coil overs!! Yea that's happening. Lots and lots to go but it's not a pipe dream anymore
Post by nts007 » Sat Dec 23, 2017 4:20 pm
Slowly getting the shop together. Dealing with 50years of dirt n dust. Lots of new lighting coming. Also the 35's are almost installed on the bastard haha. Hopefully this next week I'll have it in its new home
gun45boat
Post by gun45boat » Sat Dec 23, 2017 4:58 pm
helluva nice shop man!!!!!
Post by nts007 » Sat Dec 23, 2017 7:46 pm
Thanks dude! I'm just beyond happy having a warm dry place to work now. Too many years laying on my back in the snow.
Post by nts007 » Sat Feb 17, 2018 11:28 pm
Small update. Bastard is coming to its new home soon. Been cleaning and upgrading the shop. Installed half the new lighting. Huge difference!! Picture doesn't do it justice. Replacing 8 halogen 500 watt lights with 4 led 150 watt high bays. Only 2 done. Wow.
NovA ProspekT
Post by NovA ProspekT » Wed Mar 21, 2018 1:19 am
I was gonna give you shit about the Ferd motor, but it's free so what the hell...
Glad to see you finally got a shop, looks like you've got plenty of room for expansion! Did you put that up yourself?
I'd definitely recommend a roll-cage and proper safety gear if you plan on doing alot of crazy, high-speed stuff. I'd probably keep the long-box too, maybe just bob it.
Can't wait to see how this all comes together. :cheers:
[---- 2007 Dodge Power Wagon ----]
Flame Red - 5.7L Hemi V8 - COOPER S/T MAXX (37"x12.5"R17) - Carli High Clearance Control Arms
Aluminess Front Bumper - Back Rack w/ Side-rails - Truxedo LoPro QT Tonneau
JW Speaker TS4000 Driving Lights - Grote 30" LED Off-road Light Bar - Bosch Fog Lights
[---- 2004 Jeep Grand Cherokee Overland ----]
Inferno Red - 4.7L High Output PowerTech V8 - Quadra-Drive - 17" Rubicon Hard Rock wheels
1.5" Lift OME HD Coil Springs - Bilstein 5100 Shocks - JKS HD Trackbar
[---- 1998 Jeep Grand Cherokee 5.9 Limited ----]
Deep Slate - 5.9L Magnum R/T V8 - Quadra-Trac - Bilstein Shocks
Doug Thorley Long-tube headers - MOPAR M1 Intake - BBK Power Plus twin 52mm Throttle Body
[My Flickr]
“The death-knell of the republic had rung as soon as the active power became lodged in the hands of those who sought, not to do justice to all citizens, rich and poor alike, but to stand for one special class and for its interests as opposed to the interests of others.” - Theodore Roosevelt
Post by DamageWagon » Wed Mar 21, 2018 1:43 am
I know someone that makes weld-it-yourself cages for the 3rd gen Dodges. This truck is getting a cage for sure. Suspension is a hard thing to pick on these trucks, and I blame Thuren!! He makes so many good parts, and then when you want to get all warm and fuzzy Don has a few ‘secret menu’ items that never see the light of day that can really get your truck on the fast track. It’s to the point that links are almost not even necessary and can be reserved for purely race-only application. Even the Taquache Motorsports Truck is running leafs from a don and that’s a full race truck!
Post by nts007 » Wed Mar 21, 2018 2:13 am
Can’t say no to a free running engine from the olden days. The shop used to be a lumber yard so it has plenty of space. I’m only using half of it for my “shop” the rest os for the business. I’ve been trying to bang out mods and parts for the diesel wagon to make Moab this year so I haven’t gotten the bastard over here yet. But I have been slowly cleaning and organizing. Getting in trouble all the time since I’m “never home” anymore. Sacrifices right
Post by nts007 » Mon Jul 02, 2018 12:29 pm
Short update. The #bastardwagon is in its new home and ready to go under the knife. Or plasma cutter. The build will commence!!!
Keep tuned for more updates. They will come.
