2011BigRed Build
2011bigred
2011BigRed Build
Post by 2011bigred » Tue Feb 28, 2017 6:51 pm
Here is what I've done so far
35" Federal Couragia MTs (I know most people don't like them but they are working so far)
Plasti dip front bumper and grill
Removed plastic piece on bumper
More to come
Whats next
fab a skid plate/light mount under bumper to protect the "Smart Bar"
good quality rock sliders wish there was more options so I don't have to ship from California (White Knuckle)
Thuren Control Arms (little rub at full lock)
2011bigred
Re: 2011BigRed Build
Post by 2011bigred » Tue Feb 28, 2017 7:00 pm
This is where we started
2011bigred
Post by 2011bigred » Tue Feb 28, 2017 7:01 pm
35's look so much better
2011bigred
Post by 2011bigred » Tue Feb 28, 2017 7:02 pm
Blacked out front end
Post by nts007 » Tue Feb 28, 2017 8:09 pm
Looks great!! Never heard anything bad about the federals. Just not that common out here. Were they stud able?
2011bigred
Post by 2011bigred » Tue Feb 28, 2017 11:34 pm
They are not stud able I think that my next set of summer tires will be 37" MTRs then a 35" studded snow tire in the winter
Juday
Post by Juday » Fri Mar 03, 2017 4:51 pm
Nice looking Wagon! You don't see that color very often on the 4Gs.
FYI, I'd rethink the 37" MTRs for the truck. They don't balance worth a $h!t on our heavier trucks. My 315's throw weights all.the.freaking.time. In the looks department, they're awesome! But, they're just not for our truck, unfortunately....
2012 RAM Power Wagon
RamGentry
Post by RamGentry » Fri Mar 03, 2017 5:04 pm
And there is now a ton of 37" options... AT, RT, MT, hybrids and so on from many different manufacturers. Lots of good first hand reviews here. Are you looking for a MT specifically?
Truck looks pretty good with the front end blacked out BTW. I wasn't sure how that would look but I really like it :cheers:
2011bigred
Post by 2011bigred » Sat Mar 04, 2017 7:39 pm
I'm not only after MT tires I am however wanting something that has really good puncture ratings as most of the off roading I do is backwoods lots of broken rock and debris
2011bigred
Post by 2011bigred » Thu Mar 09, 2017 1:51 pm
Just got the shipping confirmation on the thuren control arms
Juday
Post by Juday » Thu Mar 09, 2017 2:17 pm
You're going to love them! Once you see how beefy they are, you'll realize how weak the stock arms on the truck! When you grease them, make sure your truck is at full droop to get the grease spread out.
2011bigred
Post by 2011bigred » Fri Mar 10, 2017 11:22 am
Thanks for the info
2011bigred
Post by 2011bigred » Sun Mar 19, 2017 4:23 pm
Well I attempted the install of the control arms yesterday and the drivers side caster bolt is froze on the control arm so I am going to give it one last go without cutting the bolt off
Post by olyelr » Sun Mar 19, 2017 11:05 pm
Just plan on cutting all the bolts and getting new.
Post by nts007 » Sun Mar 19, 2017 11:30 pm
I believe the caster bolts and nuts were something like $40 for the pair
2011bigred
Post by 2011bigred » Fri Mar 24, 2017 10:24 am
So I have the new bolts what is the best way to cut it out I don't have a torch or plasma cutter I do have a sawzaw and air cut off wheel
Post by DamageWagon » Fri Mar 24, 2017 12:41 pm
Cutoff wheel is best. That should make quick work of it. You will need to support the weight of the truck when you drive them out and probably need a drift punch and a man-sized hammer to get them out.
Sent from my safe space
Post by TankerZak » Fri Mar 24, 2017 9:50 pm
How much was the plastidip? I kinda wanna do all my chrome... both bumpers... mirrors... badges... grill
2016 Granite Crystal Metallic Power Wagon Laramie, graphics delete, debadged, Thuren front and rear coils, Thuren rear swaybar links, Thuren rear trackbar, Traxada rear 1 inch spacers, King 3.0 (Stage 4) front and 2.5 (Stage 3) rear shocks, Boogie front bump stops, Cooper STT Pro 37x13.50R17 on XD Machette 17x9 +18 wheels, DOR steering brace, Thuren King Steering Damper, Synergy Steering Kit, Thuren PW bumper, White Knuckle rock sliders, Dethloff skid plate, Purple Cranium Half Spider front and rear diff guards, Airlift Ultimate airbags with Daystar cradles, Bakflip Revolver X2 tonneau, AMP BedStep, Factor55 Ultrahook with 100ft 7/16 A.R.E. Spidersilk synthetic winch line, Zroadz Grill with slim 20 inch light bar, DDM Tuning LEDs/HIDs, Magnaflow 19200 modified with upgraded resonator and after axle dump, tinted front windows 35%.
2011bigred
Post by 2011bigred » Mon Mar 27, 2017 3:43 pm
retail is anywhere from $7-$10 depending on where you get it from i got it for $5 a can from my work probably looking at 6-8 cans for what your looking at doing
2011bigred
Post by 2011bigred » Sat Apr 22, 2017 9:25 am
Finally got the control arms installed last night in time for Moab pics to follow
