DamageWagon's Build - 2011 "AdventureWagon"
Re: DamageWagon's Build - 2011 "AdventureWagon"
Post by DamageWagon » Sun Oct 07, 2018 12:56 am
Retired BLM Rig wrote::jawdrop: Was this on an MDS cylinder?
No MDS, 2011 5.7 in the Wagon
Post by DamageWagon » Sun Oct 07, 2018 1:27 am
Retired BLM Rig wrote:What a bummer! :(
So did this happen on cold start up, cruising along, or wide open throttle racing a Raptor? :popcorn:
Just cruising, about 35, all warmed up. Out of the blue it just started running like crap like a super bad exhaust leak, then died the first time I stopped. Was very hard to keep running but ran moderately rough at 3000rpm. Managed to drive it home about 5 minutes away. I had figured it was a crazy exhaust leak like I broke a manifold bolt. There was no noise like a valvetrain issue.
Post by DamageWagon » Sun Oct 07, 2018 1:32 am
Retired BLM Rig wrote:How do the cam lobe and lifter look?
I had posted that info above just after one of yours.
Cam lobe and lifter seem fine. Pushrod seat in the lifter looks fine. Bearing feels the same as the other 7 on that side with some hand load.
Post by Retired BLM Rig » Sun Oct 07, 2018 1:38 am
Ah yes, the page changed and I missed it. :doh:
Post by coder » Sun Oct 07, 2018 6:15 pm
Any idea what caused the failure?
Post by DamageWagon » Sun Oct 07, 2018 11:09 pm
coder wrote:Any idea what caused the failure?
No indicator of failure. I think 187,000 miles of hard use broke a valve spring, or the top of the valve snapped off.
I’m really surprised the valve seat is completely untouched.
