Not over used. They are a Dodge weak point. The wires are a couple inches too short, so they flex too much when the doors open and close. Already changed out the rear drivers door. I kept the old harness, and saw what the issue was, so I have it on my workbench to fix up for when the next one breaks.darwink1 wrote:Progress report. Got the leather seats wired and working. Swapped pins between the connector I had from the old seat to and the one that came with the laramie seats. Worked out pretty clean. Next step is to try and use some of the unused pin spots in the connector to run the heaters. All else fails Im just gonna hook them up independently using either the stock volkswagen or my 3 way switches...
Woulda had the heat hooked up but while my buddy was messin with the seats I decided to figure out why my pwr door lock on the ds rear door wasnt working. Turns out most of the wires were pretty close to snapping and a couple were snapped under the accordion boot between the b pillar and the door. Po must have used that door a hell of a lot lol. Some solder and heat shrink fixed that but it took a good while.
D
P.S: I moved back to Hanmer a couple years ago after having moved away 25 years ago. Some day we will have to get together for a ride and and some pops.
