Reloaderguy's Build Thread - Content Removed
Re: Reloaderguy's Build Thread - 2016 Laramie Power Wagon
Post by Reloaderguy » Sun Nov 04, 2018 10:49 am
removed
Post by Reloaderguy » Fri Nov 16, 2018 7:32 pm
removed
Post by Bill2014 » Fri Nov 16, 2018 8:11 pm
Those tires make your truck look small. :rockon:
Post by RustyPW » Fri Nov 16, 2018 8:54 pm
NICE! :rockon:
Reminds me of a hotwheels truck. :lol:
Russ NRA Benefactor Member
Post by Reloaderguy » Fri Nov 16, 2018 10:11 pm
NICE! :rockon:
The pictures don't do it any justice. The wheel and tire combo makes the truck 6" wider than the 37's I was running. I'm going to weigh a wheel and tire tomorrow but I'm guessing they're 130lbs each. The 37's were under 100lbs each. So far I'm running 27/22 PSI and it feels good, 30 PSI was rock hard. I haven't balanced the tires but I'm not sure it's needed, they're pretty smooth. I put new TPMS sensors in the wheels and truck picked them up seamlessly.
Post by RustyPW » Fri Nov 16, 2018 10:22 pm
What's the spec's on the rims?
I haven't run TPMS's in my tires for years. My light stays on. :lol:
Post by Reloaderguy » Fri Nov 16, 2018 10:26 pm
removed
Post by olyelr » Fri Nov 16, 2018 11:38 pm
Looks like shit. I vote put it back to stock.
Post by DamageWagon » Fri Nov 16, 2018 11:53 pm
It needs a giant American flag in the hitch
Post by TankerZak » Sat Nov 17, 2018 8:36 am
Yer killin me. Can you put the rest of the bumper together and take pics already!
Post by Reloaderguy » Sat Nov 17, 2018 10:21 am
I don't have the rest of the bumper yet. The standard outers don't work with 40's.
Post by TankerZak » Sat Nov 17, 2018 10:30 am
You have a plan? Or is Don making you custom wings?
Post by Reloaderguy » Sat Nov 17, 2018 10:57 am
Don is making outers for 40's.
Post by Reloaderguy » Sat Nov 17, 2018 5:19 pm
NICE! :rockon:
Correction, the 40's and TR Beadlocks are 142lbs each.
Post by olyelr » Sat Nov 17, 2018 5:49 pm
:o
Bet your glad you did 5.13’s!
16PW
Post by 16PW » Mon Nov 19, 2018 3:23 pm
Looks badass! Looking forward to seeing it with the front bumper completed.
Post by Reloaderguy » Mon Nov 19, 2018 9:31 pm
removed
Post by TankerZak » Mon Nov 19, 2018 9:57 pm
Reloaderguy wrote:The factory bundles the front parking sensors (if you have them) with the foglights in the bumper harness. I removed the sensors and converted the truck to rear parking sensors only so there is no longer a need to keep the sensor harness intact. For some reason the connectors in the bumper are potted so I couldn't get them apart. I ended up disassembling the harness and removing the parking sensor wiring. They are separate but in the same harness. I then reassembled the fog light harness using braided harness sleeve and heat shrink. I'll probably redo the harness when the bumper is finished but it works in the meantime. I'm just reusing the temporary Chinesium lights I had in the OEM bumper. Here is what the inside of the harness looks like:
Can you add some details on how you disabled the front sensors?
Post by Reloaderguy » Mon Nov 19, 2018 11:00 pm
AEV references it in their bumper installation instructions. You need to purchase the rear-only parking sensor module and replace yours. The module is at the base of the A-pillar under the door sill guard by the parking brake release. The module is found in almost every Dodge, Jeep, and Ram vehicle with rear parking sensors for the last six or eight years. They're like $100 new, I found one on Ebay for $40 used. The part # is 68204477AD.
Post by TankerZak » Tue Nov 20, 2018 7:56 am
Reloaderguy wrote:AEV references it in their bumper installation instructions. You need to purchase the rear-only parking sensor module and replace yours. The module is at the base of the A-pillar under the door sill guard by the parking brake release. The module is found in almost every Dodge, Jeep, and Ram vehicle with rear parking sensors for the last six or eight years. They're like $100 new, I found one on Ebay for $40 used. The part # is 68204477AD.
and replacing that module disables it in the computer and the switch, etc?
Post by 2wagons1driveway » Tue Nov 20, 2018 8:46 am
Oh man, very very very nice!!!! Those 40’s look right at home
Post by Reloaderguy » Tue Nov 20, 2018 9:36 am
Yes, you will no longer have front sensors and the button will not work. No codes.
Post by TankerZak » Tue Nov 20, 2018 9:38 am
Thanks, nice!
Post by Colibri » Tue Nov 20, 2018 7:02 pm
Looking fantastic with the man tires! You notice much difference in drivability from the 37’s?
