Page 18 of 19
Re: "Frankenwagon" short and sweet.
Posted: Sun Mar 26, 2017 7:58 pm
by 2wagons1driveway
Well I removed the 6" Thuren diesel coils for a set of his 3" Thuren diesel
Soft coils and I am loving the handling increase in the truck. Along with the bed cage and front 3.5's the trucks handling like it's on rails. Also on a side note I did manage to demolish and crack a trail ready bead lock running really low psi and falling into an ice hole at higher speeds then I should have been doing with only 8psi in the tires. Luckily trail ready sent me a new wheel and I am seriously considering running a dual spare set up in the near future cause I go through wheels and tires a lot. Lolol
as you can see with the trucks bed full of running gear for pre running/ any offroading it sits level now with the front.
I did leave AlL my drops in for the 6" lift though so the front end has crazy flat drag link and track bar angles etc. which means it has no bump steer and the turning feels very nice and stable. Because all my drops are still in place and I'm running 12" stroke shocks I did lose quite a bit of up travel so at ride height I only have about 5.5-6" of up travel. And about 5" of droop before the coil is too loose to use.
Re:
Posted: Sun Mar 26, 2017 9:00 pm
by nts007
Holy hell welcome back!!! What caused you to drop the truck to the 3". What did you do to the rear to match. Or do you have super rake!
You must be running half a ton back there to make it level down 3"
Posted: Sun Mar 26, 2017 11:24 pm
by 2wagons1driveway
nts007 wrote:Holy hell welcome back!!! What caused you to drop the truck to the 3". What did you do to the rear to match. Or do you have super rake!
haha ya well I had some help making the leafs happier at 3"
Heigh
poor leafs got a work out while designing bedcage.
Re:
Posted: Mon Mar 27, 2017 12:32 am
by nts007
Nice lol. My pw leaves have sagged. 1" on the passenger and 2 on the driver
Posted: Mon Mar 27, 2017 9:29 am
by 2wagons1driveway
nts007 wrote:Nice lol. My pw leaves have sagged. 1" on the passenger and 2 on the driver
ya man my passenger side is still higher then the driver
Posted: Mon Mar 27, 2017 11:32 am
by DamageWagon
Gas tank, driver and battery all make the drivers side much heavier. Gas tank kills the rear leaf.
Re:
Posted: Mon Mar 27, 2017 12:50 pm
by nts007
Obviously it couldn't be the driver
Posted: Tue Mar 28, 2017 12:41 pm
by 2wagons1driveway
DamageWagon wrote:Gas tank, driver and battery all make the drivers side much heavier. Gas tank kills the rear leaf.
ya especially with soft lt leafs!
Re:
Posted: Tue Mar 28, 2017 11:55 pm
by nts007
You're making me reconsider thuren leaves right now
Posted: Wed Mar 29, 2017 9:01 am
by 2wagons1driveway
Ya wouldn't be good for you. But his old ones are known to sag new ones aren't half as bad but are still similar squat characteristics then mine
Posted: Sun May 14, 2017 5:22 pm
by 2wagons1driveway
Re:
Posted: Tue May 16, 2017 9:42 pm
by RAM4ROKS
AWESOME!!!!! Looks like a great setup!
Posted: Sun May 21, 2017 10:55 am
by 2wagons1driveway
Rebuilt the rr bypass shock today. Was a pain lol and heavy. But finally has pressure and oil again :/
Posted: Fri Nov 02, 2018 1:08 pm
by 2wagons1driveway
Wow it’s been along time since I could log in and post! Thanks mike! I should be a regular again here now. Had an eventful summer, with zero off-roading as I took a trip to Ontario with my girlfriend who became my fiancé after the trip, we then got home to a flooded house! Toilette fresh water line burst and flooded all three levels of our house while we were on vacation
so insurance has been lovely to deal with sending all kinds of idiots to my house to try and repair it and hack it back together. News on the wagon: she’s been sitting: a lot: the rear shocks are pulled and I had them powder coated in gold last week as the winter wheeling killed the factory king coating after a year etc. also had some new shafts made up for them and got some big ass shock boots off of a bmw actually that should help totally eliminate my rock chip issue eating seals etc. still working on spacing my front shocks up as I relocated the factory battery underneath the rear passenger seat and installed some junction boxes for all my electrical stuff up front. The plan here is to space the front 12” stroke king 3.5’s up two full inches at a 3” lift height to produce 11.5-12” of wheel travel at the 3” lift height. Normally 12” shocks are reserved for 6” lifts as the geometry and size of the 12” shock body doesn’t allot it to pull that much travel unless it’s got a much taller tower so I had some spacers machined up that are 2” thick and the exact cad design don uses for his towers. They actually came out pretty nice looking and shouldn’t be brutally obvious. I will probably run into radius swing issues with the large 3.5” shocks and will have a lot of clearance going to do but this should make the truck even faster offroad than it is now. Future plans for the truck are some more horsepower and possibly new thuren LT leafs as my old atlas ones are nice and soft... but sag out brutally over time especially on the drivers side with that big ass fuel tank. I’ll post up some pics of the battery relocate and the shocks after their make over:
i did find a nice pw that matches my shirt at the last car show I went to but it wasn’t for sale... and it was kind of a bastardized pos but still cool lol
my daily/ pull truck got treated to a full thuren overland system minus rear leafs this summer and I am super happy with that. It’s consistently getting 600 miles a tank with the higher power tune from the smarty touch on it and shouldn’t have any issues pulling my power wagon whenever I get a decent wide low boy car hauler for it!
this is my current situation with the shocks I need to either really really really massage those brake lines from the master or just bend up some new ones as my new front shocks set up will hit those brake lines quite badly so I’m hoping I can figure out what size they are and make up some new lines to get going on this project. Then the p.wagon needs some on hoist love, greasing, tightening, and some fluid changes and I should be good to put some miles on it in the spring again
Re:
Posted: Fri Nov 02, 2018 1:25 pm
Nice to see ya around these parts again!
Whats your daily/pull truck?
Posted: Fri Nov 02, 2018 1:43 pm
by 2wagons1driveway
olyelr wrote:Nice to see ya around these parts again!
early 2004 CTD:
Re:
Posted: Fri Nov 02, 2018 9:34 pm
by nts007
Welcome back my friend!!
Re:
Posted: Fri Nov 02, 2018 10:12 pm
by OffroadTreks
Posted: Sat Nov 03, 2018 12:06 pm
by Low_Sky
Welcome back, Lee. I still think those Kings look like baby poop.
Posted: Sat Nov 03, 2018 5:16 pm
by 2wagons1driveway
Low_Sky wrote:Welcome back, Lee. I still think those Kings look like baby poop.
What color did you go with for your Kings?!
Posted: Sat Nov 03, 2018 5:20 pm
by Low_Sky
2wagons1driveway wrote:Low_Sky wrote:Welcome back, Lee. I still think those Kings look like baby poop.
Cheapskate Silver bodies and reservoirs and Broke Blue end caps. AK doesn’t salt roads, so hopefully they will hold up for a long time without needing extra coating.
Posted: Sat Nov 03, 2018 5:22 pm
by 2wagons1driveway
Lol fucker.... I wish. Pretty sure I’ll be redoing this coating in two years too.
Re:
Posted: Thu Nov 15, 2018 12:05 pm
by Colibri
Hey lee! You can have my stock power wagon leafs for the tow pig for free if you want them. Just need to figure out shipping
Posted: Thu Nov 15, 2018 2:42 pm
by 2wagons1driveway
Hey brotha! No worries I actually have my 12’ leafs in Ontario and since I will be moving back there from Alberta in the spring so I’ll probably jam them in then!
Posted: Thu Nov 22, 2018 5:44 pm
by 2wagons1driveway
Who knows what size the lines are from the master to the stability control/ abs module ?!
I need some to finish this front end...
Eventually.... lol
