"Frankenwagon" short and sweet.
Re:
Post by Reloaderguy » Wed Aug 24, 2016 11:14 am
When are you going to do a linked rear with coilovers?
Re: "Saggin wagon" short and sweet.
Post by FirerescuePW » Wed Aug 24, 2016 3:37 pm
At the rate he makes changes? September.
Pit Slave
Re: "Frankenwagon" short and sweet.
Post by Pit Slave » Wed Aug 24, 2016 7:25 pm
2wagons1driveway wrote:Hahahaha exactly. Can an admin change this title to frankenwagon? Hahaha
Post by 2wagons1driveway » Wed Aug 24, 2016 9:26 pm
Haha thanks man! Hey Tim a bit of bent tube?!?! And it's in the wrong spot as we discussed already haha but hey it's dropping out okay but some stuff has to be cut and moved "probably"
I'm referring to the bent pipe from
The rear mount up to the main cage beside the shock unfortunately the shock angle and the bypass tube looks like it's going to contact at full bump or before so that will
Probably have to be cut out and a new section made that being said all in all everything looks better with some shock angle etc! ImageImageImageImageImageImage
Sent from Canada
Pit Slave
Post by Pit Slave » Wed Sep 14, 2016 12:18 am
Since Lee is a little too busy to be on here with an update, I'll just leave this bit here....
https://www.instagram.com/p/BKO_YJEAwcK/
azracer
Re:
Post by azracer » Wed Sep 14, 2016 1:54 am
Check your park brake cable and locker as well as ABS wires for being stressed and needing to be extended or rerouted. Also check drive shaft clearance at the skid plate cross brace. I had issues with my wires, park brake cable and drive shaft hitting the cross brace.
Post by 2wagons1driveway » Wed Sep 14, 2016 11:29 pm
azracer wrote:Check your park brake cable and locker as well as ABS wires for being stressed and needing to be extended or rerouted. Also check drive shaft clearance at the skid plate cross brace. I had issues with my wires, park brake cable and drive shaft hitting the cross brace.
because I'm a 6" lift already a lot of that stuff had already been clearanced years ago right cause I previously had about 13" of wheel travel and now I'm around 20" but a lot more up travel than before (approx 3") so a lot is all good that being said with that much travel we got to watch for weird one off shit! Lol I'm posting some videos of testing newest bed cage design! ImageImageImageImageImagehttps://vimeo.com/182802391 and FYI it rides like a fuckin fake titty hahaha just great
Sent from Canada
Re:
Post by nts007 » Thu Sep 15, 2016 12:53 am
Your driver side taillight busted up a bit. Is there a story for that one too?
Post by 2wagons1driveway » Thu Sep 15, 2016 1:29 pm
nts007 wrote:Your driver side taillight busted up a bit. Is there a story for that one too?
yes lol went out with the local
Pre runners club and I was behind leader on a hard charge... Missed a turn that wasn't called out that was 75* and slopped to the downwards left... And it was a right then... So hitting that fresh gravel at 120kmh my rear end locked up and I said fuck it I'll ride it out so turned into the ditch then just kinda gently slid into a fence after sliding for 70' sideways .... Tail light only broke when I put truck into reverse lol
Sent from Canada
Pit Slave
Post by Pit Slave » Thu Sep 15, 2016 1:43 pm
Sent from Canada
Hahaha, now I know you have the same luck as me. Stupid fence post took out my tail light after backing up into it. What made it worse the truck was still brand new when I did it. Now I'm like whatever. lol
Post by 2wagons1driveway » Sun Sep 18, 2016 5:16 am
Sent from Canada
lol exactly at this point eff it. I enjoy the truck too much to worry about little stuff
Sent from Canada
azracer
Re:
Post by azracer » Sun Sep 18, 2016 6:58 am
Ummm! Like the truss! You need a cab cage asap! You have moved into an entirely new level!
Post by 2wagons1driveway » Sun Sep 18, 2016 9:08 pm
azracer wrote:Ummm! Like the truss! You need a cab cage asap! You have moved into an entirely new level!
I don't think I'm going to do one anytime soon. When someone makes a nice WIY kit I would think about it but honestly I'll just pick my lines a bit better and remember I'm
Not in a trophy truck
Sent from Canada
NovA ProspekT
Re:
Post by NovA ProspekT » Mon Sep 19, 2016 4:56 pm
Not in a trophy truck yet
Sent from Canada
Fixed it for you.
You're trucks just about at that point. :rockon:
Post by 2wagons1driveway » Mon Sep 19, 2016 9:12 pm
Lol ya it's pretty fun right now and I'm holding back on super charging it because that would push it alittle over the edge I mean it is what it is it doesn't like to stop or turn now so fuck it would be gnarly with another 150hp hahha ImageImageImageImageImage I really like the d ring mounts they mean business they are massive and doubled up. I am adding a winch fairlead brace plate out of 1/4" between the frame horns to increase the strength and side to side load it may experience during winching at the extremes. I will probably leave the light mount open to access the winch fairlead and block heater etc.
Re:
Post by Colibri » Mon Sep 19, 2016 10:21 pm
Oh shit! So much win right there lee, your front end is going to look killer!!! :rockon:
Post by 2wagons1driveway » Tue Sep 27, 2016 10:29 pm
ImageImageImage painted the bed cage and enjoying it this weekend a bit
Sent from Canada
Sent from Canada
Post by 2wagons1driveway » Sun Oct 02, 2016 5:08 pm
ImageImageImageImageImageImage Thuren bumper on! Long process but mostly waiting for paint to dry and mocking up the fairlead and test fitting a few times! Easy only had to modify the fairlead slightly because the Thuren shackle mounts are ginormous!!!! This bumper is built so smart I love it. Honestly the cad design on it is phenomenal and the structural portion of it is great plus the welding is drop
Dead gorgeous super happy it's gracing my trucks front end now!
Sent from Canada
Post by 2wagons1driveway » Mon Oct 03, 2016 7:11 pm
Fender liners trimmed! Image
Sent from Canada
NovA ProspekT
Re:
Post by NovA ProspekT » Mon Oct 03, 2016 10:58 pm
Meh, it looks OK...needs more clearance though... :rofl:
...but seriously, that's awesome..
Should be quite a difference in weight as well, eh?
Oh, and im sure you left room for an intercooler? You know, for the turbo's. :poke:
Post by 2wagons1driveway » Tue Oct 04, 2016 12:36 am
NovA ProspekT wrote:Meh, it looks OK...needs more clearance though... :rofl:
haha There's a bit of room there?!?! Image ha not really. And there is about 80-100lbs diff I think.
Sent from Canada
Post by 2wagons1driveway » Sat Dec 10, 2016 7:35 pm
https://vimeo.com/195141229 got some boogie time in with the frankenwagon a few weeks ago. Taking atv whoops like a champ. https://vimeo.com/195141385
Sent from Canada
Powerwagonmark
Re:
Post by Powerwagonmark » Mon Dec 12, 2016 11:18 am
Are you in Ontario??
2008 Dodge POWER WAGON
Post by 2wagons1driveway » Wed Jan 04, 2017 7:55 pm
Powerwagonmark wrote:Are you in Ontario??
hey man sorry I'm from Ontario I live in Edmonton now!
